Hi all,
Please i have a problem with dsdt asus p8z68 deluxe .
This Dsdt dont work speed step.
This dsdt has a problem with the speed step, my multiplier on HwMonitor is blocked to 16x, and the score of geekbench is little. I have a ssdt instead that it works well, if I enclose two rows DSDT to SSDT, can see where is error?
Thanks all and sorry for this stress
SSDT.aml.zip
:mrgreen::mrgreen: Without PC :mrgreen::mrgreen:
There's nothing related to SpeedStep in this SSDT, I don't understand how can it work.
I really don't understand, have no idea.
Why don't you use the SSDT?
Does audio work with this SSDT if not using raid?
yes..if use raid audio work perfect on disk single..but if use raid software dont work.
But if i use dsdt (attached ) audio work on raid , but speed step dont work....very very strange
Unterstound?
If all work fine with single disk, why do you think the problem is in DSDT or SSDT?
Does SpeedStep work with raid and the SSDT you attached?
Yes with this ssdt speed step work perfect...but audio dont work .
Strange , why this dsdt(attached) on raid audio work and speed step no?
:roll:
It doesn't make sense to me.
Compare Chameleon log (bdmesg) using raid and single disk.
Ok ...cassio tomorrow attached bdmesg chameleon on topic , on disk single an raid .
Thank's , now i go to sleep ... ;)
In italy are 23:00 pm
Don't attach the logs, compare them.
Good morning this is a bdmesg in disk single
Customizing SystemID with : 6028001f-c600-0015-0637-14dae9110ef2
efi_inject_get_devprop_string NULL trying stringdata
ACPI table not found: DSDT.aml
Read HFS+ file: [hd(3,2)/Extra/SSDT.aml] 788 bytes.
ACPI table not found: SSDT-1.aml
FADT: Restart Fix applied!
RSDT: Added 1 SSDT table(s)
Added 1 SSDT table(s) into XSDT
Starting Darwin x86_64
Boot Args: boot-uuid=73A0DF7A-68DA-3087-B845-63636956CD43 rd=*uuid -v
