hello there, I have finished almost everything in my laptop Dell G3 15 3590 intel core i7 9750h UHD630, and everything is okay right now followed dortania (Open core guide) with all my ssdts patches including the USB port, the strange problem that I am facing which is in sleep awake functioning
sometimes it sleeps okay and when I am trying to wake it wakes properly, and sometimes it does not wake from sleep at all and then I have to force shut it down with the power button, and it gives me that Report, I wish anyone can help me please as I almost finished everything about 2 months ago and from then I am trying to figure out what makes that issue, please anybody help me please ,
attached image for report on the problem
106596944_3019715381459029_8018424010912925923_n.png.aa9aece1c8772be9d619f5b3b88c5e33.png.zip
@MaLd0n please can you help me, it is my only problem right now , please give it a look
btw also it gives same result when using dsdt I received from this forum which you did for me
ssdt is one pseudo solution, not full solution, but if u like just enjoy this way
first shot, kill all _prw with one simple rename like _prw to zprw
I generated the dsdt with -l and searched for _PRW found about 56 search result , I took it and paste like that (attached screen) , same issue still there and the report also the same
Screen Shot 2020-07-19 at 12.06.07 AM.png.zip
Edited by Amin
1 hour ago, Amin said:
yes. upload again in other service only sendme.zip file
ye
error again lol
same shit , unfortunately ?
extract one ioreg
40 minutes ago, Amin said:
keep in mind that i added it to the OC you sent as it is , so I tried with DSDT only not attached with other ssdts
is correct. dsdt is full solution. ssdt not
what ur bluetooth
u need remap ur usb
run in terminal and paste here
log show --style syslog | fgrep "Wake reason"
