[HELP] USB WIFI Adapter no working - autoassigned id
Hi! Finally I can install macOS in my laptop, i installed it in a Sandisk Ultra 3.0 USB 64GB because I have a PM981 NVMe SSD but all works fine. The only problem I have is the WIFI Card, it is not not compatible with macOS so I decided to connect a USB Wifi Adapter that I found at home. It is a TP-Link TL-WN725N, I installed the drivers from the official website and it seems that works but when I put my password it doesn't connect or if I can get it connected, I get a autoassigned IP and i cannot use internet. What can I do?
