System reset 2 seconds after entering 'white screen' LGA775 GA-x48-DQ6 E8400 Geforce 620
Hi Daniel, All,
I am trying to install Olarila Mojave  on this setup;
Mobo; GA-x48-dq6 v1.1
Proc Intel E8400 dualcore
6 GB ddr2 ram
Samsung evo 256 ssd
2 seconds after the installer reached the 'white' screen during startup/install , the system reboots.
I cannot use the send me app because I do not make it to the desktop.Archive.zip
I have added some log files from the efi clover directory.
Any help is ofcourse appreciated. :)
hey
i think is about ur gpu
i think this gpu loose support in mojave
try with -x or nv_disable=1
