Hi Brothers/sisters,
i have installed Catalina 10.15 Olarila premade image, and it works. but when my PC going to sleep and try to wake up. black screen appear ( Hardware turning on ). and PC is freezing and i have to reload again. is there any fix please.
my specs. ( DESKTOP )
CPU :Intel i7-4790
Motherboard : Gigabyte H81-S2PT
GPU :Amd 570 4G
RAM :16G
EFI : https://drive.google.com/file/d/1MlIct_EAsvPooxcwSFIXDODU5QFA_AIp/view?usp=sharing
Edited by Ahmed Elmeddany
Extract tables with F4 key in Clover boot screen, boot into system and run this app
i have done that i not solved, steps i followed :
extracted the contect of runme.zip
ran runme and allowed the permissions
rebooted the system
tried to make sleep and wakeup and not solved.
below link contains the output of runme
https://drive.google.com/file/d/1yud5DGOGn1YW3PkAYXRj91Z1Fy8vClIP/view?usp=sharing
u need share file in ur google drive
same
efi folder from Olarila image is just for installation
go to menu file, save as
sorry but i am new to this, i do not want to screw up things. so should i open the app, then on IOSERVICE. apply save as ( what should i name the file ?, DSDT.aml ? ) then copy this file under /EFI/CLOVER/ACPI/patched/
are these steps are OK ?
also should i apply the same steps on IOACPplan , IOPOWER .. and so on ?
