[Guide] Install/Restore BigSur with OpenCore on AMD Ryzen
is cosmetic
u can edit in system information.app
On 7/23/2020 at 7:46 PM, iamprabhuantony said:
Hi MaLd0n
My System:
msi 990fxa-gd65. | AMD FX 8150 | 12GB RAM | Gigabyte RX 560 4Gb
I successfully Installed Big Sur using VMware. Booted with these EfI ( tried with both FAKEsmc and VirtualSMC)
I want to try USB Installer (olarilla iso Big sur dp3).
But its not booting at all. I can use this efi to boot both Usb Installer catalina and Installed catalina disk.
Getting this error
https://photos.app.goo.gl/fAo5ez83t41tLP31A
Hello iamprabhuantony,
how did you install BigSur in VMware?
Do you have a Description or instructions, maybe a Link?
My System:
AMD FX 6300, MSI GT 710, ASRock 980DE3/U3s3, 16 GB RAM
Greetings from Germany, maclinux
2 hours ago, rodriguem7973 said:
is team orarilla going to work a new cpu ryzen series 4000 and new gpu rx6000
this work about amd is from github. amazing guys
https://github.com/AMD-OSX/AMD_Vanilla
13 minutes ago, Kyaalod said:
Can i used the beta 6 image flashed on my USB to restore on my SSD?
yes. but is very slow with usb
12 hours ago, Kyaalod said:
Can i use the big sur.ios and restore it to my drive??
iso? never try
4 hours ago, Wawan said:
what is the best way to upgrade my oralira ryzen 3600 catalina to big sur ?
update bootloader, kexts and kernel patches
https://github.com/AMD-OSX/AMD_Vanilla/tree/experimental-opencore
15 minutes ago, Wawan said:
Trying to use the EFI when updating from BigSur 20A5364e to Big Sur Beta 8 but fail ( stuck on boot )
many people report problems with BS
A few things with this EFI that I have noticed that should not be there at all.
<key>booter-fileset-basesystem</key>
<data>AA==</data>
<key>booter-fileset-kernel</key>
<data>AA==</data>
These were only needed with OC 0.5.8 because OC could not patch the kc.collections and had to revert back to patching prelinked kernel, with 0.5.9 this has been fixed and no longer need those in the config at all.
The Datahub and PlatformNVRAM sections in the config are not even used with Automatic PlatformInfo is enabled.
Booter > Quirks > EnableWriteUnprotector should not be enabled.
The ACPI > Patch > Olarila Fix Boot Stuck is not needed at all.
ACPI > Quirks > RebaseRegions should not be enabled.
If you are going to provide a pre-made EFI, you should keep it updated with the latest kernel patches and settings that are based off https://dortania.github.io/OpenCore-Install-Guide/AMD/zen.html just my opinion.
this folder is old. i need update
