[Guide] Install/Restore BigSur with OpenCore on AMD Ryzen
--Video Tutorial OpenCore Vanilla--
https://tinyurl.com/yyfa7mfa
--Full OpenCore Vanilla Guide--
https://tinyurl.com/ycvcnp8h
--AMD Patches and Credits--
https://github.com/AMD-OSX/AMD_Vanilla
--Full Solution with good fine tune you need post your files, check video and run this app bellow--
Download RunMe.app - https://tinyurl.com/y9562hz7
Let's start
System password is 1234
Work in internal or external HDD/SSD / Don't restore to your Mojave/Catalina macOs SSD
1- Download this .dmg and put in your desktop
Link 1- https://tinyurl.com/ybttsz94
Link 2 - https://tinyurl.com/ydxme7jl
All Credits to vit9696 and Vandroiy
2- Open terminal and mount .dmg
-Run in terminal-
hdid -nomount "/Users/olarila.com/Desktop/macOS_11.dmg"
*change user*
3- Check disks with diskutil list in terminal
***Pay attention, you need restore partition that has EFI partition and 120gb, check image below***
-Run in terminal-
diskutil list
In my case .dmg mounted is disk5 and my NVME is disk1
*mounted .dmg have 120 gb*
4- Unmount Disk
*Make changes according to the result in the terminal*
-Run in terminal-
diskutil unmountDisk /dev/disk1
5- Restore
Restore from disk5 to disk1
-Run in terminal-
sudo dd if=/dev/disk5 of=/dev/disk1 bs=32m
with ctrl + t you can check progress
Restore is done.
c- Go to Kernel tab, Patch and add these patches
Download last release OpenCore and Kexts
--OC vanilla Application--
https://www.olarila.com/topic/10371-oc-vanilla/
Premade EFI Folder AMD RYZEN
https://tinyurl.com/ybr968w3
Boot into system and enjoy!
Resize Disk After restore Thanks to Pavo
To resize the physical disk of BigSur when using this method
*Identify the physical disk
diskutil list
*repair the physical disk partition
sudo diskutil repairDisk diskX
*Resize the physical disk container volume
sudo diskutil apfs resizeContainer diskXs2 0
Credits/Thanks: Acidanthera Team, AlGrey, XLNC, Apple
  • Thanks 1
dd: /dev/disk6 of=/dev/disk5 bs=32m: No such file or directory
Main ASUS ROG Trix B360-G Gaming + CPU Intel i5 9400F + DDRAM4 Trident Z 8gb bus 3000 + VGA Gigabyte RX 580 8Gb+ Wifi TP Link WN823N
Main ASUS X570 CSM Pro + CPU Ryzen 5 3600 + DDRAM4 Corsair 16Gb bus 3000Mhz + VGA Gigabyte RX 5700 XT 8Gb + Wifi Intel 7265AC + USB TPlink Nano T2U V3 + USB TPlink W725N + USB TPlink W823N V3
check ur procedure
1 hour ago, longcoming said:
what is SIGABRT error and how to solve it?
-Boot from USB / Disable booter-fileset-kernel and booter-fileset-basesystem
-Boot from SSD / Enable these options if need
Ola amigo, antes de tudo muito obrigado por tudo!
Eu instalei aqui e deu certo, so o mouse que esta bem estranho, fica travando toda hora.
Voce teria alguma dica? ja procurei em varios lugares e nada. estou atualizando para o beta 2 agora para ver se resolve.
Muito obrigado ?
o sistema é beta e esses patches tb. sempre vários bugs
3 hours ago, low_sperm said:
mas de qualquer forma muito obrigado MaLd0n. ?
falou!
11 minutes ago, othsout said:
can we use Big Sur image from this link?
yes. just change efi folder
Hi MaLd0n
My System:
msi 990fxa-gd65. | AMD FX 8150 | 12GB RAM | Gigabyte RX 560 4Gb
I successfully Installed Big Sur using VMware. Booted with these EfI ( tried with both FAKEsmc and VirtualSMC)
I want to try USB Installer (olarilla iso Big sur dp3).
But its not booting at all. I can use this efi to boot both Usb Installer catalina and Installed catalina disk.
Getting this error
https://photos.app.goo.gl/fAo5ez83t41tLP31A
Edited by iamprabhuantony
u need check if patch for FX is done
theses guys have a amazing work for amd in github
Hi, @MaLd0n I installed beta 3 successfully on my computer but black screen for a while after boot, I had to press ESC for a while (30s) to go to the login screen (MSI RX 5500 XT)
My EFI: https://drive.google.com/file/d/1Ls62lTinMCi9Hd84D0FlJh9rsgXBeo7O/view?usp=sharing
PC: Msi B450 Tomahawk Max, Ryzen 5 3600, Msi Rx 5500 XT 8G Gaming X, RAM 16G, Ethernet Realtek RTL 8111, Audio Realtek ALC892, MacOS 10.16 Beta 3, Opencore 0.6.0 (method USB Installer)
MSI B450 TOMAHAWK MAX, RYZEN R5 3600, MSI RX 5500 XT, WIFI BCM94360cs2 , MacOS 10.16 Beta 9, Opencore 0.6.2
agdpmod=pikera
1 hour ago, MaLd0n said:
agdpmod=pikera
same error ?
5 hours ago, HUYNH ANH said:
same error ?
try with no weg.kext
Hi, @MaLd0n
I have the same issue, I don't know if this is the way to show my login screen, but I have to type my password 2 times with enters several times even my screen is blank,
then usually there is artefac glitch on my screen after. Then after this, my login screen showed up
I have:
AsRock B450Pro4 with 4.20 BIOS Update
Ryzen 3600
RX 5600XT
latest official opencore 0.6.0
EFI.zip
idk what happens
2 hours ago, HUYNH ANH said:
Hi @MaLd0n Amd power gadget support big sur ?
check github if have updates
