Hello, previously I had problems with my system, and I didn't find a solution, so I did a fresh installation, almost everything it's working now, just that I'm having problems right now with sleep the system, when I did the installation with de Olarila Catalina 10.15.5 EFI folder, sleep worked fine, so after I made my EFI folder, starts the problem, I debug trough log and solved almost, just that right now I don't know what to do.
I'm attaching the logs
sudo pmset -g assertions:
2020-07-04 00:19:48 -0400
Assertion status system-wide:
   BackgroundTask                 0
   ApplePushServiceTask           0
   UserIsActive                   1
   PreventUserIdleDisplaySleep    0
   PreventSystemSleep             0
   ExternalMedia                  0
   InternalPreventDisplaySleep    1
   PreventUserIdleSystemSleep     0
   NetworkClientActive            0
Listed by owning process:
   pid 150(hidd): [0x0000001d0009809e] 00:00:00 UserIsActive named: "com.apple.iohideventsystem.queue.tickle serviceID:10000041f name:AppleUserHIDEventSe product:USB Keyboard eventType:3"
	Timeout will fire in 600 secs Action=TimeoutActionRelease
   pid 109(powerd): [0x0000001600108001] 00:02:12 InternalPreventDisplaySleep named: "com.apple.powermanagement.delayDisplayOff"
	Timeout will fire in 168 secs Action=TimeoutActionTurnOff
Kernel Assertions: 0x4=USB
   id=500  level=255 0x4=USB mod=31/12/69 20:00 description=com.apple.usb.externaldevice.14700000 owner=USB Keyboard
Idle sleep preventers: IODisplayWrangler
here pid 109(powerd): [0x0000001600108001] 00:02:12 InternalPreventDisplaySleep named: "com.apple.powermanagement.delayDisplayOff"  it's the problem
log show --style syslog | fgrep "Wake reason":
2020-07-02 13:18:03.131015-0400  localhost powerd[67]: [powerd:sleepWake] Wake reason: "<private>"  identity: "<private>"
2020-07-02 13:18:22.132494-0400  localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: RTC (Alarm)
2020-07-02 13:18:22.132496-0400  localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: RTC (Alarm)
2020-07-02 14:38:55.485172-0400  localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: RTC (Alarm)
2020-07-02 14:38:55.485173-0400  localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: RTC (Alarm)
2020-07-02 18:11:46.004449-0400  localhost powerd[67]: [powerd:sleepWake] Wake reason: "<private>"  identity: "<private>"
2020-07-02 18:12:35.620154-0400  localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN XDCI
2020-07-02 18:12:35.620155-0400  localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN XDCI
2020-07-03 02:08:20.038636-0400  localhost powerd[69]: [powerd:sleepWake] Wake reason: "<private>"  identity: "<private>"
2020-07-03 02:20:03.134797-0400  localhost powerd[69]: [powerd:sleepWake] Wake reason: "<private>"  identity: "<private>"
2020-07-03 10:44:57.106632-0400  localhost powerd[109]: [powerd:sleepWake] Wake reason: "<private>"  identity: "<private>"
2020-07-03 11:41:53.381539-0400  localhost powerd[109]: [powerd:sleepWake] Wake reason: "<private>"  identity: "<private>"
2020-07-03 12:06:19.924343-0400  localhost powerd[109]: [powerd:sleepWake] Wake reason: "<private>"  identity: "<private>"
2020-07-03 13:43:09.701366-0400  localhost powerd[109]: [powerd:sleepWake] Wake reason: "<private>"  identity: "<private>"
2020-07-04 00:19:02.366190-0400  localhost powerd[109]: [powerd:sleepWake] Wake reason: "<private>"  identity: "<private>"
Today is, 07/04/2020 so 2020-07-04 00:19:02.366190-0400  localhost powerd[109]: [powerd:sleepWake] Wake reason: "<private>"  identity: "<private>", it's the remaining problem, the older I already fixed it
sudo pmset -g
System-wide power settings:
Currently in use:
 standby              1
 Sleep On Power Button 1
 womp                 1
 halfdim              1
 hibernatefile        /var/vm/sleepimage
 proximitywake        1
 powernap             1
 autorestart          0
 networkoversleep     0
 disksleep            10
 standbydelayhigh     86400
 sleep                1
 hibernatemode        3
 ttyskeepawake        1
 displaysleep         10
 highstandbythreshold 50
 standbydelaylow      86400
and finally I attach a txt file of the command: log show --style syslog | fgrep "PreventUserIdleSystemSleep"
RAW Text file LogSystem - PreventingSleep -> Pastebin
Hope somebody can help me
I forgot to mention, my specs:
MOBO: Asus Prime P-II Z370
CPU: Core i5 9400F
Smbios used: 19,1
GPU: Radeon RX580
Bootloader: OpenCore 5.9
I had a DSDT that @MaLd0n helped me previously. I already patch USB ports through ssdt, I followed a tutorial here on Olarila for that.
What I found it's that, but I'm not completely sure:
[powerd:assertions] Process coreaudiod.176 Released PreventUserIdleSystemSleep "com.apple.audio.context145.preventuseridlesleep"
It's the cause of preventing to sleep, but I don't know how to fix it.
what problem with sleep? auto wake?
Yes, when it’s going to sleep the screen turn off but, the fans and the cpu still on, and working. I think it’s something in the dsdt, cause that doesn’t happen with the EFI folder of the installation of Catalina 15.5.5 Olarila, when I use it, the sleep it’s working perfectly, I have to make a send_me file?
I had problem finishing the process of RunMeApp, while the Dump of IORegistry, so I took manually a Dump and add it to the .zip file
Send Me File
u don't need any ssdt with use my dsdt. is a full patched
ssdt dont solve much problems, only basic
For the patch of USB ports, followed this tutorial
[Guide] Native USB Fix for Notebooks - No Injector/Kext Required
and I applied the USB ports patch directly on my DSDT, I Just have 4 ports 3.0 and 6 ports USB 2.0, 4 of them 2.0, are the front USB ports of the case, so I applied "Internal" for that ports. I don't know if that could be a problem, but my ports are working fine and the speed too.
I gave it a try just with the DSDT, and still it's the problem of never going to sleep, just screen off, but the CPU still working, I'm attaching a log
2020-07-04 20:45:26 -0400
   BackgroundTask                 0
   UserIsActive                   1
   ExternalMedia                  0
   PreventUserIdleSystemSleep     1
   pid 150(hidd): [0x0000001e0009809d] 00:00:00 UserIsActive named: "com.apple.iohideventsystem.queue.tickle serviceID:100000430 name:AppleUserHIDEventSe product:USB Keyboard eventType:3"
   pid 229(coreaudiod): [0x000000750001816f] 00:00:13 PreventUserIdleSystemSleep named: "com.apple.audio.AppleHDAEngineOutput:1F,3,0,1,2:0.context.preventuseridlesleep"
	Created for PID: 558.
   pid 109(powerd): [0x0000001600108001] 00:01:16 InternalPreventDisplaySleep named: "com.apple.powermanagement.delayDisplayOff"
	Timeout will fire in 223 secs Action=TimeoutActionTurnOff
And the
2020-07-04 20:44:13.200287-0400  localhost powerd[109]: [powerd:sleepWake] Wake reason: "<private>"  identity: "<private>"
It's remaining the same "WakeReason"
Here is more detailed log for "Sleep"
Timestamp                       (process)[PID]
2020-07-04 20:43:17.051427-0400  localhost kernel[0]: (AppleACPIPlatform) <AppleACPIPlatform`AppleACPIPlatformExpert::resolveSystemStateSupport()> ACPI: sleep states S3 S4 S5
2020-07-04 20:43:17.056334-0400  localhost kernel[0]: PMRD: setSleepSupported(1)
2020-07-04 20:43:36.959326-0400  localhost kernel[0]: PMRD: SleepWake UUID queued: 2405A91F-1CD8-4476-92DE-37B3ACC52559
2020-07-04 20:43:37.393676-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:37.393865-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 20:43:37.393877-0400  localhost kernel[0]: PMRD: sleep timer expired
2020-07-04 20:43:37.393878-0400  localhost kernel[0]: PMRD: System sleep prevented by kPMSystemRestartBootingInProgress
2020-07-04 20:43:37.395956-0400  localhost kernel[0]: PMRD: setDisableClamShellSleep(0)
2020-07-04 20:43:37.431119-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:37.633550-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 20:43:37.633663-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 20:43:38.381445-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 20:43:38.397084-0400  localhost kernel[0]: PMRD: prevent idle sleep list: IODisplayWrangler+ (1)
2020-07-04 20:43:38.397136-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 20:43:38.399362-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 20:43:38.520660-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 20:43:38.520955-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:38.521075-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 20:43:38.547223-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:38.555408-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::setIdleAudioSleepTime(unsigned long long)> + IOAudioDevice[<private>]::setIdleAudioSleepTime: sleepDelay = ffffffffffffffffffffffff
2020-07-04 20:43:38.555409-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::setIdleAudioSleepTime(unsigned long long)> - IOAudioDevice[<private>]::setIdleAudioSleepTime: sleepDelay = ffffffffffffffffffffffff
2020-07-04 20:43:38.559769-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::setIdleAudioSleepTime(unsigned long long)> + IOAudioDevice[<private>]::setIdleAudioSleepTime: sleepDelay = ffffffffffffffffffffffff
2020-07-04 20:43:38.559770-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::setIdleAudioSleepTime(unsigned long long)> - IOAudioDevice[<private>]::setIdleAudioSleepTime: sleepDelay = ffffffffffffffffffffffff
2020-07-04 20:43:38.560629-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:38.571163-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:38.574072-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:38.579314-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:38.585001-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:38.587770-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:39.150506-0400  localhost kernel[0]: PMRD: setSleepSupported(1)
2020-07-04 20:43:39.183742-0400  localhost kernel[0]: PMRD: setSleepSupported(1)
2020-07-04 20:43:39.191171-0400  localhost kernel[0]: PMRD: setSleepSupported(1)
2020-07-04 20:43:39.198585-0400  localhost kernel[0]: PMRD: setSleepSupported(1)
2020-07-04 20:43:39.205937-0400  localhost kernel[0]: PMRD: setSleepSupported(1)
2020-07-04 20:43:39.947479-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:39.951284-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:41.074082-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::setIdleAudioSleepTime(unsigned long long)> + IOAudioDevice[<private>]::setIdleAudioSleepTime: sleepDelay = ffffffffffffffffffffffff
2020-07-04 20:43:41.074083-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::setIdleAudioSleepTime(unsigned long long)> - IOAudioDevice[<private>]::setIdleAudioSleepTime: sleepDelay = ffffffffffffffffffffffff
2020-07-04 20:43:41.091045-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::setIdleAudioSleepTime(unsigned long long)> + IOAudioDevice[<private>]::setIdleAudioSleepTime: sleepDelay = ffffffffffffffffffffffff
2020-07-04 20:43:41.091046-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::setIdleAudioSleepTime(unsigned long long)> - IOAudioDevice[<private>]::setIdleAudioSleepTime: sleepDelay = ffffffffffffffffffffffff
2020-07-04 20:43:41.366371-0400  localhost kernel[0]: PMRD: SleepWake debug buffer size:0x28000 spindump offset:0x9c
2020-07-04 20:43:41.366380-0400  localhost kernel[0]: PMRD: No sleep wake failure string
2020-07-04 20:43:43.941693-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 20:43:43.941915-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 20:43:44.525038-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:44.525322-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 20:43:44.525337-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 20:43:44.525562-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 20:43:45.627896-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:45.628074-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 20:43:55.262841-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 20:43:55.263007-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 20:43:55.551822-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:55.551997-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 20:43:55.669084-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 20:43:55.669294-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 20:43:55.671845-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:43:55.672036-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 20:44:13.196014-0400  localhost kernel[0]: PMRD: user inactive 0 min, time to idle sleep 1 min
2020-07-04 20:44:13.196161-0400  localhost kernel[0]: PMRD: sleep reason Software Sleep
2020-07-04 20:44:13.196263-0400  localhost kernel[0]: PMRD: prevent idle sleep list: IODisplayWrangler- (0)
2020-07-04 20:44:13.196823-0400  localhost kernel[0]: PMRD: SleepWake UUID queued: 62AC723E-05CD-4B65-B5C0-6B7FF2A8329B
2020-07-04 20:44:13.197010-0400  localhost kernel[0]: PMRD: tellChangeDown::userActivityAtSleep 0
2020-07-04 20:44:13.198940-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 20:44:13.199115-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 20:44:14.534399-0400  localhost kernel[0]: PMRD: tellChangeDown::userActivityAtSleep 0
2020-07-04 20:44:15.553246-0400  localhost kernel[0]: PMRD: System sleep prevented by kPMCPUAssertion
2020-07-04 20:44:18.595933-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:44:28.203188-0400  localhost kernel[0]: (AppleACPIPlatform) <AppleACPIPlatform`AppleACPIPlatformExpert::queryPlatformCanSleep()> System sleep prevented by SBUS
2020-07-04 20:44:28.203192-0400  localhost kernel[0]: (AppleACPIPlatform) <AppleACPIPlatform`AppleACPIPlatformExpert::queryPlatformCanSleep()> System sleep prevented by SBUS
2020-07-04 20:44:28.203194-0400  localhost kernel[0]: PMRD: System sleep prevented by kPMPCIUnsupported
2020-07-04 20:44:36.914838-0400  localhost kernel[0]: PMRD: display wrangler tickled1 1 lastSleepReason 103
2020-07-04 20:44:36.914891-0400  localhost kernel[0]: PMRD: display wrangler tickled1 2 lastSleepReason 103
2020-07-04 20:44:36.916099-0400  localhost kernel[0]: PMRD: prevent idle sleep list: IODisplayWrangler+ (1)
2020-07-04 20:44:36.916213-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 20:44:38.479712-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 20:44:38.479898-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 20:44:41.951220-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:44:41.951410-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 20:45:13.144152-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 20:45:13.144351-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 20:51:48.549722-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:51:48.549894-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 20:51:49.743474-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> + IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 20:51:49.743477-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> - IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 20:57:10.226903-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 20:57:10.227069-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 20:57:16.126420-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:57:16.126582-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 20:57:17.288331-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> + IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 20:57:17.288333-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> - IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 20:59:38.775622-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 20:59:38.775883-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 20:59:39.352532-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 20:59:39.352829-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 21:04:30.099941-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 21:04:30.100132-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 21:04:35.146031-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 21:04:35.146194-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 21:04:36.418179-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> + IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 21:04:36.418181-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> - IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 21:04:38.291402-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 21:04:38.291576-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 21:04:39.712360-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 21:04:39.712525-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 21:04:40.894527-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> + IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 21:04:40.894530-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> - IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 21:04:47.022106-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 21:04:47.022350-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 21:04:58.941386-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 21:04:58.941547-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 21:05:00.213485-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> + IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 21:05:00.213488-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> - IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 21:05:43.817807-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 21:05:43.817966-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 21:05:47.163122-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 21:05:47.163284-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 21:05:48.277833-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> + IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 21:05:48.277835-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> - IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 21:07:41.090476-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 21:07:41.090642-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 21:07:42.209570-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 21:07:42.209727-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 21:07:43.507693-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> + IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 21:07:43.507695-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> - IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 21:10:02.675412-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 21:10:02.675575-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 21:10:49.093811-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 21:10:49.093991-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 21:10:50.232396-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> + IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 21:10:50.232399-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> - IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 21:11:03.622670-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 21:11:03.622877-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
2020-07-04 21:11:05.075380-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 1
2020-07-04 21:11:05.075537-0400  localhost kernel[0]: PMRD: idle sleep timer enabled
2020-07-04 21:11:06.224579-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> + IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 21:11:06.224580-0400  localhost kernel[0]: (IOAudioFamily) <IOAudioFamily`IOAudioDevice::scheduleIdleAudioSleep()> - IOAudioDevice[<private>]::scheduleIdleAudioSleep: idleSleepDelayTime = ffffffffffffffffffffffff
2020-07-04 21:11:30.749995-0400  localhost kernel[0]: PMRD: setAggressiveness(0) kPMMinutesToSleep = 0
2020-07-04 21:11:30.750190-0400  localhost kernel[0]: PMRD: idle sleep timer disabled
What I understand is something with IOAudioFamily, if I'm right?
I was reading, and I don't know if could be that, I'm using a HDMI port with my display, and in Hackintool shows two devices, the Realtek , and the HDMI port too.
hibernate disabled?
u can use, but cause some problems in many cases like corrupted files, etc
