Please I need your help. My battery shows cycle count when i use Hp support assistant to check the health of the battery. But that's not the case when i generate battery report using powershell. I have attached the battery report generated using powershell, the screenshot of the hp support assistant battery health tool check and my dsdt. Please take a look at it... If i need to upload something else please tell me and i will do it... In macOS, My battery cycle count is 0 and i want to fix it Please.
Chucks-Files.zip
Edited by Chucks
Replace VirtualSMC and its plugins with FakeSMC+PLUGINS and your battery cycle will show up. You will probably also get couple sensors more and fan speed if you have appropriate files installed.
Unfortunately fakesmc breaks my charger status. I hope Maldon will be able to help me with this soon ?
