Olá @MaLd0n,
Obrigado por responder, será que podia dar uma vista de olhos pela minha config.plist e dar-lhe uma boa limpeza?
Obrigado desde já
config.plist.zip
Já agora o meu hardware é o seguinte: MB Gigabyte Z390 I Aorus Pro Wifi, intel i5 9600K, UHD 630, 16GB DDR 4 2600 Corsair, ssd nvme m2 500GB Crucial.
Edited by MorenoAv
3 hours ago, JhoonCollins said:
Mas ja ta dando pra fazer instalação limpa?ou somente restaurando a dmg do inicio do post?
só restore
config não resolve muita coisa. eu só trabalho através de dsdt.
  • Acer Nitro 5 AN515-51-50U2
  • Intel® CoreTM i5-7300HQ
  • Intel HD Graphics 630
After this my notebook reboots.
Working normally with Catalina.
My EFI here
Edited by juniorairton
Hi , I have laptop DELL Inspiron 3567 Core i5-7200u, Intel HD 620 only .
I try  install but it didn't work. Can you send me an EFI. Thanks!
EFI.zip
Edited by HUYNH ANH
MSI B450 TOMAHAWK MAX, RYZEN R5 3600, MSI RX 5500 XT, WIFI BCM94360cs2 , MacOS 10.16 Beta 9, Opencore 0.6.2
in restore
sudo dd if=/dev/disk5 of=/dev/disk4 bs=32m
Last login: Wed Jul  1 14:37:32 on ttys000
gtr@iMac ~ % sudo dd if=/dev/disk5 of=/dev/disk4 bs=32m
Password:
dd: /dev/disk5 of=/dev/disk4 bs=32m: No such file or director
gtr@iMac ~ %
remove SMCBatteryManager.kext
14 hours ago, MorenoAv said:
Ok aqui estão elas, 4 ...
eu preciso da sua pasta efi e um dump extraído com esse app, veja o vídeo
9 hours ago, Marck00 said:
I could mount it in Read/Write mode by following these steps, Before that I modified in opencore the section csr-active-config with the value FFFFFFFF
Thanks but I cannot boot into Recovery Mode with this restore method (It appears the black screen and returns the Opencore bootloader screen. I have no idea why.
I can boot into macOS easily.
I can't get into recovery mode either, I did everything from the system
thank you very much
work very well
My Build: Motherboard: Asus TUF Z390-PLUS GAMING (WI-FI) CPU Core I9-9900K (3.6GHz) VGA: RADEON RX 580 8GB GOORS (XFX) RAM: 32GB , SSD M.2 4TB
Old: MacOS Catalina 10.15.5
New:MacOS Big Sur
Motherboard Asus TUF Z390-PLUS GAMING (WI-FI) CPU 3.6 GHz 8-Core Intel Core i5, Ram 32 GB 3000 MHz DDR4, Graphics : AMD Radeon RX 6700 XT 12 GB OS:MacOS Tahoe 26.0 RC (25A353) SERIE 30, 40 (COOFFELAKE / COMETLAKE
update , first time  in 11.0 sound  work
before at 10.15.5 never working
wifi not working
Bluetooth  working first time also
am using same ur EFI
iMassage not working
Screen-Shot-2020-07-01-at-10-54-53-PM.pn
Screen-Shot-2020-07-01-at-10-58-08-PM.pn
Screen-Shot-2020-07-01-at-10-58-25-PM.pn
Edited by Kankon
13 hours ago, revans said:
Let me know if your guide Big Sur will works for my laptop. Thanks! ?
Yes! Enjoy!
5 hours ago, douglas85rj said:
Previous works on AMD processors ? Ryzen 5 2600 ... :(
yes. have a patch for it now. check amd vanilla
insert value in config.plist, nvram tab and c heck if work
5 hours ago, MorenoAv said:
Olá @MaLd0n,
remove ssdt e add dsdt
reset nvram
4 hours ago, andy2e0raf said:
have installed but i get to a black screen with a mouse cursor
nv_disable=1
-radvesa
-igfxvesa
post one dump here
Obrigado @MaLd0n
Removo as 4 SSDT's e coloco apenas a dsdt ?
Removi as 4 SSDTS e instalei a DSDT e não tenho som na mesma, mas o sistema parece muito mais fluido... entretanto vou correr o RUNME outra vez e já anexo o resultado.
Send me admin.zip
Edited by MorenoAv
45 minutes ago, MorenoAv said:
Obrigado @MaLd0n
deixe me ver a sua pasta efi
20 minutes ago, moviemakergr said:
Anyone have boot with for Z490 Vission D maybe ?
same thing
my folder Vision. add things for Big Sur form first post
https://easyupload.io/x98sks
  • Thanks 1
