11 minutes ago, Striker770 said:
No luck. I tried all.
compile kext and use alcid=x
49 minutes ago, Striker770 said:
Is already done. Can you check the above EFI?
41 minutes ago, jhonnyvey said:
Tem como gravar a imagem pelo Win32diskimager? Estou sem mac instalado aqui.
acho que vi um usuário usando o transmac
2 hours ago, MaLd0n said:
yes. work for all with support. u just need a good opencore folder for ur hardware
How do I get or create this?
I can post machine specs if that will help anyone to get me up and running.
I am really new at this and I have too much on my desktop to wipe it clean so I figured it would be easier to do my laptop.
If it is possible I may be willing to dual boot my Desktop machine if that will be easier.
Desktop specs are attached.
DxDiag.zip
Quick question: Could you help me to make "mount disk" work.
I just got this:
Quote
spctl --master-disable
mount -uw /
mount_apfs: volume could not be mounted: Permission denied
mount: / failed with 66
killall Finder
7 hours ago, khevinpo said:
Anyone have luck hacking on Ryzen CPU?
Yes
patches.plist.zip
6 hours ago, Abbas Mohammed said:
it pass through now i am facing this issue i have attached the image in a zip file and got err 5 reading blknum 625783 (num read errs:48)
what ur hardware? post ur efi folder here
new system, security things. we need wait new betas
  • Thanks 1
Ola MaLd0n bom dia, primeiro quero agradecer pela ajuda depois de muitas tentativas sem sucesso enfim consegui descobrir o problema simplesmente era o HD interno passei para uma case usb e deu certo.
Identificador do modelo: iMacPro1,1
Placa Mãe: Asus TUF Z390-PLUS GAMING (WI-FI)
conjunto de chips: Intel Z390
Memoria RAM: 1x16 GB Corsair 3000 MHz DDR4
Processador: Intel Core i7-8700K 3.70GHz
Placa de Video: Sapphire Radeon RX 590 NITRO+ Special Edition Dual, 8GB
Wireless/Bluetooth: BCM943602CS 16000Mbps 802.11AC
Show! ?
Olá a todos,
Eu instalei o macOS Big Sur seguindo o tutorial da 1º página, mas estou a ter vários problemas, tais como blueetooth intermitente, uma vezes tenho som outras não, por todos esses motivos estou a pensar reinstalar o macOS Big Sur clonando uma instalação feita num Mac mini 2018 do trabalho, será que funciona?
Obrigado desde já...
Olá @talmazi,
Tenho uma motherboard igual á sua e não consigo instalar macOS nela, só mesmo windows 10... contactei o suporte da Asus e foi-me dito que eles só dão apoio á instalação de windows 10, por isso tenho-a encostada a apanhar pó.
Pelos motivos atrás mencionados o que eu queria saber era o seguinte:
1- Qual é a bios que tem na motherboard?
2 - Qual era a bios que a motherboard trazia?
3 - Quais são as configurações da bios que tem e que permitem instalar macOS?
Peço desculpa pelo off topic e se acharem que o post é inapropriado podem apaga-lo.
Obrigado
Edited by MorenoAv
vc precisa de fine tune, um bom dsdt
hackintool e ssdt não resolvem muita coisa, o sistema apenas funciona aparentemente bem
25 minutes ago, JhoonCollins said:
alguem sabe como ta o andamento do processo dos bootloaders em relação ao big sur? alguma novidade por parte dos devs?
OpenCore tá normal
OpenCore tá normal
Mas ja ta dando pra fazer instalação limpa?ou somente restaurando a dmg do inicio do post?
