Yes, excellent work. Installation on my old but still dynamic Z77 DS3H without problem. Imac 14.4. Many thanks to the maestro.
Ola amigo ja estou a dois dias tentando e não consigo executar o BigSur.EFI.zip
Edited by talmazi
Identificador do modelo: iMacPro1,1
Placa Mãe: Asus TUF Z390-PLUS GAMING (WI-FI)
conjunto de chips: Intel Z390
Memoria RAM: 1x16 GB Corsair 3000 MHz DDR4
Processador: Intel Core i7-8700K 3.70GHz
Placa de Video: Sapphire Radeon RX 590 NITRO+ Special Edition Dual, 8GB
Wireless/Bluetooth: BCM943602CS 16000Mbps 802.11AC
39 minutes ago, Alden said:
I’ve put them into EFI but Wifi still remains unchanged. If you have time, please let me know if I could send you some files to fix that.
if don't work i don't have idea ;)
é sobre o usb
Hi all,
I'm back and I was able to install again macOS Big Sur... but I have problems I have no sound and my bluetooth is finicky.
I was wandering if the kext AirportBrcmFixup is able to solve my bluetooth problems.
My audio codec is the ALC1220-VB and I use 7 for my macOS Catalina, but that don't work in macOS Big Sur.
Can anyone help me solve this problems?
Captura de ecrã 2020-06-29, às 22.55.40.zip
26 minutes ago, MorenoAv said:
Hi all
audio, use alcid=xx
what bt u have? broadcom?
2 minutes ago, MaLd0n said:
audio, use alcid=xx
26 minutes ago, talmazi said:
Ola de novo desliguei os cabos usb e agora aparece esse erro
use USBInjectAll.kext / XHCI-unsupported.kext
depois vc cria o usb injector
22 hours ago, MaLd0n said:
audio, use alcid=xx
Yes I Have a Fenvi T-919, and I installed AirportBrcmFixup kext and it appears that is working my magic keyboard, mouse and touchpad are working now... I have in the config plist alcid=7 that works with Catalina, but not in Big Sur...
Edited by MorenoAv
lilubetaall done?
lilubetaall done?
yes... and now all is working synched my AirPods and surprise... I have sound, lol...
obrigado desde Portugal, agradeço de coração pelo teu trabalho...
10 minutes ago, talmazi said:
Ola agora apeteceu esse erro
qual pasta efi vc está usando?
EFI.zip
