Awesome guide @MaLd0n
I managed to dd to a separate SSD but when booting, I get a black screen before what I assume would be the login window.
I have Vega 64 and can boot using the same config into Catalina with no problem (Although I've been using Clover up until now, I manged to build an OC EFI, in preparation for Big Sur). I've tried with and without agpmod=pikera. My Kexts are up to date.
My MB is ASUS Maximus Hero X WIFI AC
I've attached my EFI folder
EFI.zip
Edited by DrDrumm
I managed to install MacOS Big Sur following the guide from 1 st page, but after some time I lost sound, my bluetooth was touch and go, so  I decided to start again, following the guide and it all appeared to go well...
But when I rebooted the machine I only have one entry in OpenCore boot menu macOS Catalina, for some reason I go to disk utility and found that the disk0 was not initialized, I tried to erase it, but no dice it gives error...
How do i solve this?
Captura de ecrã 2020-06-28, às 12.28.03.zip
PS: Solved erased it with terminal...
Edited by MorenoAv
Hey, everybody, does anyone else get something like this a lot?
Disk1s5s1: device is not readable.
On diskutil it appears as a snapshot
17 hours ago, Alden said:
Wifi card is bcm94352z.
inject 43a0
16 hours ago, asapreta said:
OpenCorePKG.command & OlarilaOC.command
deve ser o xcode. ainda não testei no BS
15 hours ago, Soman said:
Gigabyte H77-DS3H, Core i5, 16GB RAM, ATI Radeon Rx560.
work good
15 hours ago, johnnybravo said:
Thanks MaLd0n! Works great!
Enjoy, Johnny!
12 hours ago, Thegn said:
I wish to send you a Big Thank you, MaLd0n!
Enjoy, Thegn!
10 hours ago, SergejSD said:
Thanks MaLd0n! Super!!!
Enjoy, SergejSD!
Era para ter acontecido o que?
Hacks:
Main:
Gigabyte Z390 Gaming X  - Intel i5 9400F - 16 GB DDR4 2666 - Radeon RX 570 4GB - Tahoe 26.0.1
Backup: Gigabyte EP-45-UD3R - Intel Core2Quad 9550 @4.0Ghz - 8 GB DDR2 - GeForce 9800GT - Sierra
9 hours ago, DrDrumm said:
Awesome guide
csm disabled?
5 hours ago, mathewgx said:
@MaLd0n, is it possible to install image on a partiton (e.g. disk1s1) instead of a disk?
restore to entire and clean disk, not partition
4 hours ago, kevin0007 said:
Hi, @MaLd0n thanks for your tutorial...I did same as you mentioned in your post..I used your provided efi without any modification but at first boot I got kernel panic
what ur hardware?
restore to entire disk not partition
não sei se precisa do xcode full ou somente o command line
9 minutes ago, Alden said:
inject via devices properties, ssdt or dsdt
I’m a novice. I’m sorry to bother you but could you instruct me to inject this. I’m still skeptical of it.
what ur hardware?
I already restored the entire disk, the system works perfectly, but before starting it appears many times that message, I have the doubt if it is normal or not
Edited by Marck00
3 minutes ago, Marck00 said:
The operating system works and everything, I only have the doubt if it is normal that when booting, that message appears repeatedly
post one photo
Same happens here but as far as I know everything is working.
Instalei ambos no Big Sur antes de rodar os comandos.
Uma pasta ficou vazia e a outra como eu disse.
Hacks:
Main:
I think so, I had the doubt if the copy was not right or if it is related to OpenCore
37 minutes ago, Alden said:
Here you go.  Thanks
Archive.zip
