BRL Posted May 20, 2021 Posted May 20, 2021 I am having this error from a long time....IMG20210520153439.zip IMG20210520153439.zip
clockT Posted May 22, 2021 Posted May 22, 2021 (edited) I can't update bigsur from 11.0.1 to 11.3, when starting opencore I have the Macintosh HD partition but when I select it, it always restarts the pc. why? compressjpeg.zip Edited May 23, 2021 by clockT
BERRY MOOR Posted June 6, 2021 Posted June 6, 2021 On 6/27/2020 at 1:01 AM, MaLd0n said: Link 2 - https://tinyurl.com/ydxme7jl unfortunatelly, this link riched his download limits and google drive bypass tools dont work anymore ? If you don't mind, can you please make a link to some file-sharing site ? or new google link? thanks!!! ??
Lost In Yesterday Posted June 16, 2021 Posted June 16, 2021 (edited) On 7/3/2020 at 10:55 PM, MaLd0n said: lapic or video problem, no? On 7/3/2020 at 6:38 AM, MorenoAv said: Eu estou com o mesmo problema, alguém sabe o que fazer aqui? Modelo e até as specs são as mesmas 15 minutes ago, Lost In Yesterday said: Eu estou com o mesmo problema, alguém sabe o que fazer aqui? Modelo e até as specs são as mesmas No caso se alguém tiver a EFI do Dell Inspiron 15 3000 3567 / i3567 15.6 Eu já ficaria extremamente grato, o problema é que tentei usando um EFI do mesmo modelo só que com i3 E quando foi dar boot parou nessa mesma parte e não saia mas de lá. CPU: Intel Core i5 Kabylake, 7 geração, 7200U, 2.50 GHz Mainboard: Dell 03M86X Display: 15.6”, HD (1366 x 768) GPU: Intel Integrated HD Graphics 620 USB Ports: 1 x USB 2.0, 1 x USB 3.0 Ethernet: RTL810xE PCI Express Fast Ethernet controller Wifi: Intel Dual Band Wireless-AC 3160 Audio Adapter: Realtek ALC256 - High Definition Audio Controller Edited June 16, 2021 by Lost In Yesterday
hershebmx Posted June 24, 2021 Posted June 24, 2021 (edited) Hi @MaLd0n. I need a little help. I am trying to install Big Sur but when there are 12 minutes to finish the installation the system automatically breaks. My system is: core i5 7th gen (kabylake), gigabyte GA h110-m, 16GB ram, nvidia gt 710 gainward. Here is my Efi Folder of OC https://www.dropbox.com/s/4fmuvs6z1g06hwv/EFI Julio.rar?dl=0 Installation files images.rar Edited June 24, 2021 by hershebmx
