2 hours ago, marcelosms said:
I tried using OC, with 19.1 smbios and I haven't changed but nothing else
Hi,
I'm trying a Big Sur fresh install but i'm stucked (i'm using opencore).
here the debug file and the config
00:000 00:000 OC: OpenCore DBG-064-2020-12-07 is loading in Optional mode (0/0)...
00:024 00:024 OC: Boot timestamp - 2020.12.30 20:46:54
00:047 00:023 OCCPU: MP services threads 4 (enabled 4) - Success
00:071 00:023 OCCPU: MP services Pkg 1 Cores 4 Threads 1 - Success
00:099 00:027 OCCPU: Found Intel(R) Core(TM) i5-6600 CPU @ 3.30GHz
00:123 00:023 OCCPU: Signature 506E3 Stepping 3 Model 5E Family 6 Type 0 ExtModel 5 ExtFamily 0 uCode 39
00:146 00:023 OCCPU: EIST CFG Lock 0
00:170 00:023 OCCPU: Ratio Min 8 Max 33 Current 33 Turbo 39 38 37 36
00:194 00:023 OCCPU: TSC Adjust 0
00:218 00:023 OCCPU: Known Model Core Crystal Clock Frequency    24000000Hz
00:245 00:027 OCCPU: CPUFrequencyFromART  3312000000Hz  3312MHz = 24000000 * 276 / 2
00:269 00:023 OCCPU: Timer address is 1808 from PMC ACPI
00:393 00:124 OCCPU: Detected Apple Processor Type: 06 -> 0605
00:417 00:023 OCCPU: CPUFrequencyFromTSC  3312007206Hz  3312MHz
00:441 00:023 OCCPU: CPUFrequency  3312000000Hz  3312MHz
00:465 00:023 OCCPU: FSBFrequency   100363636Hz   100MHz
00:489 00:023 OCCPU: Pkg 1 Cores 4 Threads 4
00:516 00:027 OC: OcLoadNvramSupport...
00:540 00:023 OC: Not deleting NVRAM 4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14:UIScale, matches add
00:564 00:024 OC: Deleting NVRAM 4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14:DefaultBackgroundColor - Not Found
00:589 00:024 OC: Deleting NVRAM 4D1FDA02-38C7-4A6A-9CC6-4BCCA8B30102:rtc-blacklist - Success
00:613 00:024 OC: Deleting NVRAM 7C436110-AB2A-4BBB-A880-FE41995C9F82:boot-args - Success
00:643 00:029 OC: Setting NVRAM 4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14:DefaultBackgroundColor - Success
02:033 01:390 OC: Setting NVRAM 4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14:UIScale - ignored, exists
02:058 00:024 OC: Setting NVRAM 4D1FDA02-38C7-4A6A-9CC6-4BCCA8B30102:rtc-blacklist - Not Found
02:082 00:024 OC: Setting NVRAM 7C436110-AB2A-4BBB-A880-FE41995C9F82:SystemAudioVolume - ignored, exists
02:113 00:031 OC: Setting NVRAM 7C436110-AB2A-4BBB-A880-FE41995C9F82:boot-args - Success
02:137 00:023 OC: Setting NVRAM 7C436110-AB2A-4BBB-A880-FE41995C9F82:run-efi-updater - ignored, exists
02:161 00:023 OC: Setting NVRAM 7C436110-AB2A-4BBB-A880-FE41995C9F82:csr-active-config - ignored, exists
02:185 00:023 OC: Setting NVRAM 7C436110-AB2A-4BBB-A880-FE41995C9F82:prev-lang:kbd - ignored, exists
02:211 00:026 OC: Current version is DBG-064-2020-12-07
02:240 00:028 OC: OcMiscMiddleInit...
02:264 00:023 OC: LoadHandle BAF9DB98 with BootProtect in None mode
02:288 00:023 OC: OcLoadUefiSupport...
02:312 00:023 OCRTC: Wake log is 0x00 0x00   0 0x00
02:335 00:023 OC: Loading Apple Secure Boot with Default (level 1)
02:364 00:028 OCII: AIFTimerBoostInit Current timer is 549254
02:392 00:027 OCII: AIFTimerBoostInit changed period 549254 to 50000
02:416 00:023 OCII: gST->ConIn BC8C8928 vs found BC8C8928
02:440 00:023 OCABC: ALRBL 0 RTDFRG 1 DEVMMIO 0 NOSU 0 NOVRWR 0 NOSB 0 NOHBMAP 0 SMSLIDE 1 WRUNPROT 1
02:464 00:024 OCABC: FEXITBS 0 PRMRG 0 CSLIDE 0 MSLIDE 0 PRSRV 0 RBMAP 0 VMAP 1 APPLOS 0 RTPERMS 0
02:487 00:023 OCABC: Firmware has 4105889 free pages (704161 in lower 4 GB)
02:511 00:023 OCABC: Awaiting rendezvous with OpenRuntime r11
02:538 00:026 OC: RBVR 1 DDBR 1
02:563 00:024 OC: Got 2 drivers
02:587 00:023 OC: Driver HfsPlus.efi at 0 is being loaded...
02:624 00:037 OCB: Arch filtering 0(37892)->B939F018(37892) caps 4 - Success
02:646 00:022 OC: Driver HfsPlus.efi at 0 is successfully loaded!
02:670 00:023 OC: Driver HfsPlus.efi at 0 needs connection.
02:694 00:023 OC: Driver OpenRuntime.efi at 1 is being loaded...
02:744 00:050 OCB: Arch filtering 0(36868)->B939F018(36868) caps 4 - Success
02:768 00:024 OCABC: Got rendezvous with OpenRuntime r11
02:792 00:023 OCABC: MAT support is 0
02:816 00:023 OC: Driver OpenRuntime.efi at 1 is successfully loaded!
02:840 00:024 OC: Connecting drivers...
02:954 00:113 OC: Connecting drivers done...
02:976 00:022 OCJS: PartitionInfo is Not Found
03:003 00:027 OCJS: Got APFS super block for 5EB57330-3770-2B46-939F-2366635177A7
03:028 00:024 OCJS: Block (P:1|F:0) read req 2D3DA42 -> 169ED210 of 1000 (mask 0, mul 8) - Success
03:053 00:025 OCAV: Real image size: 630136
03:083 00:029 OCAV: Signature verified!
03:107 00:023 OCJS: APFS driver 1412141001000000/20201110 found for 5EB57330-3770-2B46-939F-2366635177A7, required >= 748077008000000/20180621, allow
03:131 00:023 OCJS: Connecting normally APFS driver on handle BAF85498
03:366 00:235 OCC: Installing GOP (Unsupported) on ConsoleOutHandle...
03:390 00:024 OC: Requested resolution is 0x0@0 (max: 1, force: 0) from Max
03:414 00:023 OCC: Requesting 0x0@0 (max: 1) resolution, curr 0, total 8
03:438 00:023 OCC: Mode 0 - 2560x1440:1
03:462 00:023 OCC: Mode 1 - 640x480:1
03:485 00:023 OCC: Mode 2 - 800x600:1
03:509 00:023 OCC: Mode 3 - 1024x768:1
03:559 00:050 OCC: Mode 4 - 1280x1024:1
03:583 00:024 OCC: Mode 5 - 1400x1050:1
03:607 00:023 OCC: Mode 6 - 1600x1200:1
03:631 00:023 OCC: Mode 7 - 1280x960:1
03:655 00:024 OCC: Current mode matches desired mode 0
03:679 00:023 OC: Changed resolution to 0x0@0 (max: 1, force: 0) from Max - Already started
03:707 00:027 OCC: Using builtin text renderer with 1 scale
03:738 00:031 OCC: Install console control (BC5663B8/0/0), current - Success
03:762 00:023 OCC: Setup ASCII Output - Success
03:786 00:023 OC: Requested console mode is 0x0 (max: 0) from
03:819 00:032 OC: Requested not to use audio
03:842 00:023 OC: OcLoadAcpiSupport...
03:866 00:023 OCA: Found 19 ACPI tables
03:894 00:027 OCA: Detected table FACP (50434146) (OEM 00002049204D2041) at BE58DA30 of 268 bytes at index 0
03:918 00:023 OCA: Detected DSDT at BE56C1F8 of 137269 bytes at index 0
03:942 00:024 OCA: Detected table APIC (43495041) (OEM 00002049204D2041) at BE58DB40 of 132 bytes at index 1
03:966 00:023 OCA: Detected table FPDT (54445046) (OEM 00002049204D2041) at BE58DBC8 of 68 bytes at index 2
03:990 00:023 OCA: Detected table FIDT (54444946) (OEM 00002049204D2041) at BE58DC10 of 156 bytes at index 3
04:014 00:024 OCA: Detected table MCFG (4746434D) (OEM 00000049204D2041) at BE58DCB0 of 60 bytes at index 4
04:038 00:023 OCA: Detected table HPET (54455048) (OEM 00000049204D2041) at BE58DCF0 of 56 bytes at index 5
04:088 00:050 OCA: Detected table SSDT (54445353) (OEM 6C62615461746153) at BE58DD28 of 877 bytes at index 6
04:112 00:023 OCA: Detected table LPIT (5449504C) (OEM 00000000004C4B53) at BE58E098 of 148 bytes at index 7
04:136 00:023 OCA: Detected table SSDT (54445353) (OEM 62756872736E6573) at BE58E130 of 584 bytes at index 8
04:160 00:024 OCA: Detected table SSDT (54445353) (OEM 6376654464697450) at BE58E378 of 11182 bytes at index 9
04:184 00:023 OCA: Detected table SSDT (54445353) (OEM 7076525F72656854) at BE590F28 of 3315 bytes at index 10
04:208 00:023 OCA: Detected table DBGP (50474244) (OEM 0000000000000000) at BE591C20 of 52 bytes at index 11
04:235 00:027 OCA: Detected table DBG2 (32474244) (OEM 0000000000000000) at BE591C58 of 84 bytes at index 12
04:259 00:023 OCA: Detected table SSDT (54445353) (OEM 38307076725F6878) at BE591CB0 of 1797 bytes at index 13
04:283 00:023 OCA: Detected table SSDT (54445353) (OEM 0020746473536153) at BE5923B8 of 21226 bytes at index 14
04:307 00:024 OCA: Detected table UEFI (49464555) (OEM 0000000000000000) at BE5976A8 of 66 bytes at index 15
04:331 00:023 OCA: Detected table SSDT (54445353) (OEM 0074647353757043) at BE5976F0 of 3672 bytes at index 16
04:355 00:023 OCA: Detected table BGRT (54524742) (OEM 00002049204D2041) at BE5A7028 of 56 bytes at index 17
04:379 00:024 OCA: Detected table VFCT (54434656) (OEM 00002049204D2041) at BE5985A0 of 60036 bytes at index 18
04:407 00:027 OCA: Allocated new table SSDT at BEA35000
04:431 00:024 OCA: Inserted table SSDT (54445353) (OEM 0000434574647353) of 196 bytes into ACPI at index 19
04:455 00:023 OCA: Allocated new table SSDT at BEA34000
04:479 00:023 OCA: Inserted table SSDT (54445353) (OEM 0067756C50757043) of 112 bytes into ACPI at index 20
04:503 00:024 OCA: Allocated new table SSDT at BEA33000
04:527 00:023 OCA: Inserted table SSDT (54445353) (OEM 7862735574647353) of 217 bytes into ACPI at index 21
04:577 00:050 OCA: FACS signature is 0 (0)
04:600 00:023 OCA: Exposing XSDT table table FACP (50434146) (OEM 00002049204D2041) at BE58DA30 of 268 bytes at index 0
04:624 00:023 OCA: Exposing XSDT table table APIC (43495041) (OEM 00002049204D2041) at BE58DB40 of 132 bytes at index 1
04:648 00:024 OCA: Exposing XSDT table table FPDT (54445046) (OEM 00002049204D2041) at BE58DBC8 of 68 bytes at index 2
04:672 00:023 OCA: Exposing XSDT table table FIDT (54444946) (OEM 00002049204D2041) at BE58DC10 of 156 bytes at index 3
04:696 00:023 OCA: Exposing XSDT table table MCFG (4746434D) (OEM 00000049204D2041) at BE58DCB0 of 60 bytes at index 4
04:720 00:024 OCA: Exposing XSDT table table HPET (54455048) (OEM 00000049204D2041) at BE58DCF0 of 56 bytes at index 5
04:747 00:026 OCA: Exposing XSDT table table SSDT (54445353) (OEM 6C62615461746153) at BE58DD28 of 877 bytes at index 6
04:771 00:023 OCA: Exposing XSDT table table LPIT (5449504C) (OEM 00000000004C4B53) at BE58E098 of 148 bytes at index 7
04:795 00:024 OCA: Exposing XSDT table table SSDT (54445353) (OEM 62756872736E6573) at BE58E130 of 584 bytes at index 8
04:819 00:023 OCA: Exposing XSDT table table SSDT (54445353) (OEM 6376654464697450) at BE58E378 of 11182 bytes at index 9
04:843 00:023 OCA: Exposing XSDT table table SSDT (54445353) (OEM 7076525F72656854) at BE590F28 of 3315 bytes at index 10
04:867 00:024 OCA: Exposing XSDT table table DBGP (50474244) (OEM 0000000000000000) at BE591C20 of 52 bytes at index 11
04:891 00:023 OCA: Exposing XSDT table table DBG2 (32474244) (OEM 0000000000000000) at BE591C58 of 84 bytes at index 12
04:918 00:027 OCA: Exposing XSDT table table SSDT (54445353) (OEM 38307076725F6878) at BE591CB0 of 1797 bytes at index 13
04:942 00:024 OCA: Exposing XSDT table table SSDT (54445353) (OEM 0020746473536153) at BE5923B8 of 21226 bytes at index 14
04:966 00:023 OCA: Exposing XSDT table table UEFI (49464555) (OEM 0000000000000000) at BE5976A8 of 66 bytes at index 15
04:990 00:023 OCA: Exposing XSDT table table SSDT (54445353) (OEM 0074647353757043) at BE5976F0 of 3672 bytes at index 16
05:014 00:024 OCA: Exposing XSDT table table BGRT (54524742) (OEM 00002049204D2041) at BE5A7028 of 56 bytes at index 17
05:038 00:023 OCA: Exposing XSDT table table VFCT (54434656) (OEM 00002049204D2041) at BE5985A0 of 60036 bytes at index 18
05:087 00:049 OCA: Exposing XSDT table table SSDT (54445353) (OEM 0000434574647353) at BEA35000 of 196 bytes at index 19
05:111 00:023 OCA: Exposing XSDT table table SSDT (54445353) (OEM 0067756C50757043) at BEA34000 of 112 bytes at index 20
05:135 00:023 OCA: Exposing XSDT table table SSDT (54445353) (OEM 7862735574647353) at BEA33000 of 217 bytes at index 21
05:159 00:024 OCA: Exposing RSDT table table FACP (50434146) (OEM 00002049204D2041) at BE58DA30 of 268 bytes at index 0
05:183 00:023 OCA: Exposing RSDT table table APIC (43495041) (OEM 00002049204D2041) at BE58DB40 of 132 bytes at index 1
05:207 00:023 OCA: Exposing RSDT table table FPDT (54445046) (OEM 00002049204D2041) at BE58DBC8 of 68 bytes at index 2
05:231 00:024 OCA: Exposing RSDT table table FIDT (54444946) (OEM 00002049204D2041) at BE58DC10 of 156 bytes at index 3
05:259 00:027 OCA: Exposing RSDT table table MCFG (4746434D) (OEM 00000049204D2041) at BE58DCB0 of 60 bytes at index 4
05:283 00:023 OCA: Exposing RSDT table table HPET (54455048) (OEM 00000049204D2041) at BE58DCF0 of 56 bytes at index 5
05:307 00:024 OCA: Exposing RSDT table table SSDT (54445353) (OEM 6C62615461746153) at BE58DD28 of 877 bytes at index 6
05:331 00:023 OCA: Exposing RSDT table table LPIT (5449504C) (OEM 00000000004C4B53) at BE58E098 of 148 bytes at index 7
05:355 00:023 OCA: Exposing RSDT table table SSDT (54445353) (OEM 62756872736E6573) at BE58E130 of 584 bytes at index 8
05:379 00:024 OCA: Exposing RSDT table table SSDT (54445353) (OEM 6376654464697450) at BE58E378 of 11182 bytes at index 9
05:403 00:023 OCA: Exposing RSDT table table SSDT (54445353) (OEM 7076525F72656854) at BE590F28 of 3315 bytes at index 10
05:430 00:026 OCA: Exposing RSDT table table DBGP (50474244) (OEM 0000000000000000) at BE591C20 of 52 bytes at index 11
05:453 00:023 OCA: Exposing RSDT table table DBG2 (32474244) (OEM 0000000000000000) at BE591C58 of 84 bytes at index 12
05:477 00:023 OCA: Exposing RSDT table table SSDT (54445353) (OEM 38307076725F6878) at BE591CB0 of 1797 bytes at index 13
05:501 00:024 OCA: Exposing RSDT table table SSDT (54445353) (OEM 0020746473536153) at BE5923B8 of 21226 bytes at index 14
05:525 00:023 OCA: Exposing RSDT table table UEFI (49464555) (OEM 0000000000000000) at BE5976A8 of 66 bytes at index 15
05:549 00:023 OCA: Exposing RSDT table table SSDT (54445353) (OEM 0074647353757043) at BE5976F0 of 3672 bytes at index 16
05:599 00:049 OCA: Exposing RSDT table table BGRT (54524742) (OEM 00002049204D2041) at BE5A7028 of 56 bytes at index 17
05:623 00:023 OCA: Exposing RSDT table table VFCT (54434656) (OEM 00002049204D2041) at BE5985A0 of 60036 bytes at index 18
05:647 00:024 OCA: Exposing RSDT table table SSDT (54445353) (OEM 0000434574647353) at BEA35000 of 196 bytes at index 19
05:671 00:023 OCA: Exposing RSDT table table SSDT (54445353) (OEM 0067756C50757043) at BEA34000 of 112 bytes at index 20
05:695 00:023 OCA: Exposing RSDT table table SSDT (54445353) (OEM 7862735574647353) at BEA33000 of 217 bytes at index 21
05:719 00:024 OC: OcLoadPlatformSupport...
05:743 00:024 OCDH: Setting DataHub 64517CC8-6561-4051-B03C-5964B60F4C7A:name (9) - Success
05:771 00:027 OCDH: Setting DataHub 64517CC8-6561-4051-B03C-5964B60F4C7A:Model (18) - Success
05:795 00:024 OCDH: Setting DataHub 64517CC8-6561-4051-B03C-5964B60F4C7A:SystemSerialNumber (26) - Success
05:819 00:024 OCDH: Setting DataHub 64517CC8-6561-4051-B03C-5964B60F4C7A:system-id (16) - Success
05:843 00:024 OCDH: Setting DataHub 64517CC8-6561-4051-B03C-5964B60F4C7A:board-id (21) - Success
05:867 00:024 OCDH: Setting DataHub 64517CC8-6561-4051-B03C-5964B60F4C7A:StartupPowerEvents (8) - Success
05:891 00:023 OCDH: Setting DataHub 64517CC8-6561-4051-B03C-5964B60F4C7A:InitialTSC (8) - Success
05:919 00:027 OCDH: Setting DataHub 64517CC8-6561-4051-B03C-5964B60F4C7A:FSBFrequency (8) - Success
05:944 00:024 OCDH: Setting DataHub 64517CC8-6561-4051-B03C-5964B60F4C7A:DevicePathsSupported (4) - Success
05:968 00:024 OCDH: Setting DataHub 64517CC8-6561-4051-B03C-5964B60F4C7A:REV (6) - Success
05:992 00:024 OCDH: Setting DataHub 64517CC8-6561-4051-B03C-5964B60F4C7A:RBr (8) - Success
06:016 00:024 OCDH: Setting DataHub 64517CC8-6561-4051-B03C-5964B60F4C7A:RPlt (8) - Success
06:040 00:023 OCSMB: Found DMI Anchor BFED0000 v3.0 Table Address BFECD000 Length 11D8
06:064 00:024 OCSMB: Found DMI Anchor BFECF000 v3.0 Table Address BFECD000 Length 11D8
06:114 00:049 OC: Current SMBIOS: System manufacturer model System Product Name
06:138 00:024 OC: New SMBIOS: Acidanthera model iMac17,1
06:161 00:023 OCSMB: Number of CPU cache entries is 4
06:186 00:024 OCSMB: Applying 2418 (1) prev BFED0000 (4568/31), BFECF000 (4568/24)
06:210 00:024 OCSMB: Patched BD30B000 v3.2 Table Address BD30C000 Length 0972 1E D1
06:234 00:024 OC: Setting HW_BID Mac-DB15BD556843C820 - Success
06:258 00:024 OC: Setting HW_ROM 11:22:33:44:55:66 - Success
06:286 00:028 OC: Setting ROM 11:22:33:44:55:66 - Success
06:311 00:024 OC: Setting HW_MLB C02615701J9GPF7JA - Success
06:335 00:024 OC: Setting MLB C02615701J9GPF7JA - Success
06:359 00:024 OC: Setting system-id ED6EE7C1-ACC2-41AA-9E25-BF8D12FE3678 - Success
06:384 00:024 OC: Setting FirmwareFeatures FC0FE137 - Success
06:408 00:024 OC: Setting ExtendedFirmwareFeatures 00000000FC0FE137 - Success
06:436 00:028 OC: Setting FirmwareFeaturesMask FF1FFF3F - Success
06:469 00:032 OC: Setting ExtendedFirmwareFeaturesMask 00000000FF1FFF3F - Success
06:493 00:023 OC: OcLoadDevPropsSupport...
06:517 00:023 OC: Setting devprop PciRoot(0x0)/Pci(0x1b,0x0):layout-id - Success
06:541 00:024 OC: OcMiscLateInit...
06:565 00:023 OC: Translated HibernateMode None to 0
06:589 00:023 OC: Hibernation detection status is Not Found
06:638 00:049 OC: Panic log does not exist
06:662 00:024 OC: OcLoadKernelSupport...
06:686 00:023 OC: All green, starting boot management...
06:710 00:023 OC: Ready for takeoff in 0 us
06:734 00:024 OCB: Adding fs BAF9DB98 (E:1|L:1|P:Success) - PciRoot(0x0)/Pci(0x14,0x0)/USB(0x3,0x0)/HD(1,GPT,53878C16-1DC3-424A-A013-33A26F568CEE,0x28,0x64000)
06:758 00:023 OCB: Adding fs BACBD898 (E:0|L:0|P:Success) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x2,0xFFFF,0x0)/HD(1,GPT,D5C2463E-19B0-418B-AE9E-1E40B7C02DAC,0x28,0x64000)
06:786 00:027 OCB: Adding fs BAF85718 (E:0|L:0|P:Success) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(1,GPT,DAEDB200-210A-4A43-8BF5-0037D509277F,0x28,0x64000)
06:810 00:023 OCB: Adding fs BAF9D898 (E:1|L:0|P:Success) - PciRoot(0x0)/Pci(0x14,0x0)/USB(0x3,0x0)/HD(2,GPT,0EBA4F92-3E31-43DD-9DE7-0F5853063629,0x64028,0x1D4F6B0)
06:834 00:023 OCB: Adding fs BACBD698 (E:0|L:0|P:Success) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x2,0xFFFF,0x0)/HD(2,GPT,BF9EC4C6-653F-4A9B-8CA5-89C56F7BF9A4,0x64028,0x1BE80460)
06:858 00:024 OCB: Adding fs B9367398 (E:0|L:0|P:Success) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,813647947B3EC64F9B99377828A0A8DE)
06:882 00:023 OCB: Adding fs B9230F18 (E:0|L:0|P:Success) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,649FB058A1E6213390740084977DEEB3)
06:906 00:023 OCB: Adding fs B9230A18 (E:0|L:0|P:Success) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,5B2CE12F6C7CB64A9F3FC916072BF826)
06:930 00:024 OCB: Adding fs B9230518 (E:0|L:0|P:Success) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,2DC6231E27272949B8E8F993835E7D2D)
06:956 00:026 OCB: Adding fs B9230018 (E:0|L:0|P:Success) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,02CD980139FF114E8F830BDF9CBA0611)
06:980 00:023 OCB: Found 10 potentially bootable filesystems
07:005 00:024 OCB: BootOrder/BootNext are not present or unsupported
07:029 00:023 OCB: Processing blessed list
07:053 00:023 OCB: Adding bless entry on disk - PciRoot(0x0)/Pci(0x14,0x0)/USB(0x3,0x0)/HD(1,GPT,53878C16-1DC3-424A-A013-33A26F568CEE,0x28,0x64000)
07:077 00:024 OCBP: Blessed file is missing
07:101 00:023 OCBP: Blessed folder is missing
07:150 00:049 OCBP: Predefined <nil> \System\Library\CoreServices\boot.efi is missing - Not Found
07:174 00:023 OCBP: Predefined <nil> \EFI\Microsoft\Boot\bootmgfw.efi is missing - Not Found
07:198 00:023 OCBP: Predefined <nil> \EFI\BOOT\BOOTX64.EFI was found
07:222 00:024 OCB: Adding entry type (T:1|F:0|G:1) - PciRoot(0x0)/Pci(0x14,0x0)/USB(0x3,0x0)/HD(1,GPT,53878C16-1DC3-424A-A013-33A26F568CEE,0x28,0x64000)/\EFI\BOOT\BOOTX64.EFI
07:246 00:023 OCB: Discarding discovered OpenCore bootloader
07:270 00:023 OCBP: APFS recovery volume handle missing - \EFI\BOOT\
07:297 00:026 OCB: APFS recovery is not present - Not Found
07:321 00:023 OCB: Adding bless entry on disk - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x2,0xFFFF,0x0)/HD(1,GPT,D5C2463E-19B0-418B-AE9E-1E40B7C02DAC,0x28,0x64000)
07:345 00:023 OCBP: Blessed file is missing
07:369 00:024 OCBP: Blessed folder is missing
07:393 00:023 OCBP: Predefined <nil> \System\Library\CoreServices\boot.efi is missing - Not Found
07:417 00:023 OCBP: Predefined <nil> \EFI\Microsoft\Boot\bootmgfw.efi is missing - Not Found
07:441 00:024 OCBP: Predefined <nil> \EFI\BOOT\BOOTX64.EFI is missing - Not Found
07:469 00:027 OCB: Adding bless entry on disk - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(1,GPT,DAEDB200-210A-4A43-8BF5-0037D509277F,0x28,0x64000)
07:493 00:023 OCBP: Blessed file is missing
07:517 00:024 OCBP: Blessed folder is missing
07:541 00:023 OCBP: Predefined <nil> \System\Library\CoreServices\boot.efi is missing - Not Found
07:566 00:025 OCBP: Predefined <nil> \EFI\Microsoft\Boot\bootmgfw.efi is missing - Not Found
07:591 00:025 OCBP: Predefined <nil> \EFI\BOOT\BOOTX64.EFI was found
07:615 00:023 OCB: Adding entry type (T:1|F:0|G:1) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(1,GPT,DAEDB200-210A-4A43-8BF5-0037D509277F,0x28,0x64000)/\EFI\BOOT\BOOTX64.EFI
07:664 00:048 OCB: Trying to get label from \EFI\BOOT\.contentDetails
07:689 00:025 OCB: Trying to get label from \EFI\BOOT\.disk_label.contentDetails
07:714 00:025 OCB: Trying to detect Microsoft BCD
07:739 00:025 OCB: Registering entry EFI (T:1|F:0|G:1|E:0) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(1,GPT,DAEDB200-210A-4A43-8BF5-0037D509277F,0x28,0x64000)/\EFI\BOOT\BOOTX64.EFI
07:763 00:023 OCBP: APFS recovery volume handle missing - \EFI\BOOT\
07:787 00:023 OCB: APFS recovery is not present - Not Found
07:814 00:027 OCB: Adding bless entry on disk - PciRoot(0x0)/Pci(0x14,0x0)/USB(0x3,0x0)/HD(2,GPT,0EBA4F92-3E31-43DD-9DE7-0F5853063629,0x64028,0x1D4F6B0)
07:844 00:029 OCBP: BlessedFileHEX (1/3 150) - 02 01 0C 00 D0 41 03 0A 00 00 00 00 01 01 06 00 00 14 03 05 06 00 03 00 04 01 2A 00 02 00 00 00 28 40 06 00 00 00 00 00 B0 F6 D4 01 00 00 00 00 92 4F BA 0E 31 3E DD 43 9D E7 0F 58 53 06 36 29
07:866 00:022 OCBP: BlessedFileHEX (2/3 150) - 02 02 04 04 50 00 5C 00 53 00 79 00 73 00 74 00 65 00 6D 00 5C 00 4C 00 69 00 62 00 72 00 61 00 72 00 79 00 5C 00 43 00 6F 00 72 00 65 00 53 00 65 00 72 00 76 00 69 00 63 00 65 00 73 00 5C 00
07:890 00:023 OCBP: BlessedFileHEX (3/3 150) - 62 00 6F 00 6F 00 74 00 2E 00 65 00 66 00 69 00 00 00 7F FF 04 00
07:914 00:023 OCBP: BlessedFileDP - PciRoot(0x0)/Pci(0x14,0x0)/USB(0x3,0x0)/HD(2,GPT,0EBA4F92-3E31-43DD-9DE7-0F5853063629,0x64028,0x1D4F6B0)/\System\Library\CoreServices\boot.efi
07:938 00:024 OCBP: Blessed file is valid
07:962 00:023 OCB: Adding entry type (T:2|F:0|G:0) - PciRoot(0x0)/Pci(0x14,0x0)/USB(0x3,0x0)/HD(2,GPT,0EBA4F92-3E31-43DD-9DE7-0F5853063629,0x64028,0x1D4F6B0)/\System\Library\CoreServices\boot.efi
07:989 00:027 OCB: Trying to get label from \System\Library\CoreServices\.contentDetails
08:014 00:024 OCB: Trying to get label from \System\Library\CoreServices\.disk_label.contentDetails
08:041 00:027 OCB: Registering entry Install macOS Big Sur (T:2|F:0|G:0|E:1) - PciRoot(0x0)/Pci(0x14,0x0)/USB(0x3,0x0)/HD(2,GPT,0EBA4F92-3E31-43DD-9DE7-0F5853063629,0x64028,0x1D4F6B0)/\System\Library\CoreServices\boot.efi
08:063 00:022 OCBP: APFS recovery volume handle missing - \System\Library\CoreServices\
08:088 00:024 OCB: APFS recovery is not present - Not Found
08:112 00:023 OCB: Adding bless entry on disk - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x2,0xFFFF,0x0)/HD(2,GPT,BF9EC4C6-653F-4A9B-8CA5-89C56F7BF9A4,0x64028,0x1BE80460)
08:162 00:049 OCBP: Blessed file is missing
08:186 00:023 OCBP: Blessed folder is missing
08:210 00:023 OCBP: Predefined <nil> \System\Library\CoreServices\boot.efi is missing - Not Found
08:234 00:024 OCBP: Predefined <nil> \EFI\Microsoft\Boot\bootmgfw.efi is missing - Not Found
08:258 00:023 OCBP: Predefined <nil> \EFI\BOOT\BOOTX64.EFI is missing - Not Found
08:282 00:023 OCB: Adding bless entry on disk - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,813647947B3EC64F9B99377828A0A8DE)
08:306 00:024 OCBP: APFS Volume Info - B9315898 (131072, 94473681-3E7B-4FC6-9B99-377828A0A8DE, 16)
08:333 00:027 OCBP: APFS Container Info - B9315818 (1, 3073B55E-7037-462B-939F-2366635177A7)
08:360 00:026 OCBP: BlessedFileHEX (1/4 248) - 02 01 0C 00 D0 41 03 0A 00 00 00 00 01 01 06 00 00 17 03 12 0A 00 05 00 FF FF 00 00 04 01 2A 00 02 00 00 00 28 40 06 00 00 00 00 00 60 04 EC 1B 00 00 00 00 45 45 8C A1 F6 1A D8 49 9C EE 0C 11
08:384 00:023 OCBP: BlessedFileHEX (2/4 248) - CB B6 9C 15 02 02 04 03 24 00 F7 FC 74 BE 7C 0B F3 49 91 47 01 F4 04 2E 68 42 81 36 47 94 7B 3E C6 4F 9B 99 37 78 28 A0 A8 DE 04 04 8A 00 5C 00 35 00 38 00 42 00 30 00 39 00 46 00 36 00 34 00
08:408 00:023 OCBP: BlessedFileHEX (3/4 248) - 2D 00 45 00 36 00 41 00 31 00 2D 00 33 00 33 00 32 00 31 00 2D 00 39 00 30 00 37 00 34 00 2D 00 30 00 30 00 38 00 34 00 39 00 37 00 37 00 44 00 45 00 45 00 42 00 33 00 5C 00 63 00 6F 00 6D 00
08:432 00:024 OCBP: BlessedFileHEX (4/4 248) - 2E 00 61 00 70 00 70 00 6C 00 65 00 2E 00 69 00 6E 00 73 00 74 00 61 00 6C 00 6C 00 65 00 72 00 5C 00 62 00 6F 00 6F 00 74 00 2E 00 65 00 66 00 69 00 00 00 7F FF 04 00
08:456 00:023 OCBP: BlessedFileDP - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,813647947B3EC64F9B99377828A0A8DE)/\58B09F64-E6A1-3321-9074-0084977DEEB3\com.apple.installer\boot.efi
08:480 00:023 OCBP: Blessed file is valid
08:508 00:027 OCBP: 10 filesystems for APFS - Success
08:532 00:023 OCBP: APFS Volume Info - B9315798 (131072, 94473681-3E7B-4FC6-9B99-377828A0A8DE, 16)
08:556 00:024 OCBP: APFS Container Info - B9315698 (1, 3073B55E-7037-462B-939F-2366635177A7)
08:580 00:023 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 6 of 10 - 1
08:603 00:023 OCBP: Missing partition 94473681-3E7B-4FC6-9B99-377828A0A8DE on preboot - Not Found
08:628 00:024 OCBP: No APFS booter 6 of 10 for 94473681-3E7B-4FC6-9B99-377828A0A8DE - Not Found
08:677 00:049 OCBP: APFS Volume Info - B9315618 (131072, 58B09F64-E6A1-3321-9074-0084977DEEB3, 64)
08:701 00:023 OCBP: APFS Container Info - B9315718 (1, 3073B55E-7037-462B-939F-2366635177A7)
08:725 00:024 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 7 of 10 - 1
08:749 00:023 OCBP: Found partition 58B09F64-E6A1-3321-9074-0084977DEEB3 on preboot
08:773 00:023 OCBP: Want predefined list for APFS 16 at 58B09F64-E6A1-3321-9074-0084977DEEB3
08:798 00:025 OCBP: Predefined 58B09F64-E6A1-3321-9074-0084977DEEB3 \System\Library\CoreServices\boot.efi is missing - Not Found
08:822 00:023 OCBP: Predefined 58B09F64-E6A1-3321-9074-0084977DEEB3 \EFI\Microsoft\Boot\bootmgfw.efi is missing - Not Found
08:850 00:027 OCBP: Predefined 58B09F64-E6A1-3321-9074-0084977DEEB3 \EFI\BOOT\BOOTX64.EFI is missing - Not Found
08:874 00:024 OCBP: No APFS booter 7 of 10 for 58B09F64-E6A1-3321-9074-0084977DEEB3 - Not Found
08:898 00:023 OCBP: APFS Volume Info - B9315518 (131072, 2FE12C5B-7C6C-4AB6-9F3F-C916072BF826, 4)
08:921 00:023 OCBP: APFS Container Info - B9315718 (1, 3073B55E-7037-462B-939F-2366635177A7)
08:946 00:024 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 8 of 10 - 1
08:969 00:023 OCBP: Missing partition 2FE12C5B-7C6C-4AB6-9F3F-C916072BF826 on preboot - Not Found
08:997 00:027 OCBP: No APFS booter 8 of 10 for 2FE12C5B-7C6C-4AB6-9F3F-C916072BF826 - Not Found
09:021 00:023 OCBP: APFS Volume Info - B9315618 (131072, 1E23C62D-2727-4929-B8E8-F993835E7D2D, 8)
09:045 00:023 OCBP: APFS Container Info - B9315218 (1, 3073B55E-7037-462B-939F-2366635177A7)
09:069 00:024 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 9 of 10 - 1
09:094 00:025 OCBP: Missing partition 1E23C62D-2727-4929-B8E8-F993835E7D2D on preboot - Not Found
09:118 00:023 OCBP: No APFS booter 9 of 10 for 1E23C62D-2727-4929-B8E8-F993835E7D2D - Not Found
09:151 00:032 OCBP: APFS Volume Info - B9315298 (131072, 0198CD02-FF39-4E11-8F83-0BDF9CBA0611, 1)
09:199 00:048 OCBP: APFS Container Info - B9315318 (1, 3073B55E-7037-462B-939F-2366635177A7)
09:223 00:023 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 10 of 10 - 1
09:247 00:024 OCBP: Found partition 0198CD02-FF39-4E11-8F83-0BDF9CBA0611 on preboot
09:271 00:023 OCBP: Want predefined list for APFS 16 at 0198CD02-FF39-4E11-8F83-0BDF9CBA0611
09:296 00:024 OCBP: Predefined 0198CD02-FF39-4E11-8F83-0BDF9CBA0611 \System\Library\CoreServices\boot.efi was found
09:320 00:024 OCBP: Found APFS booter 10 of 10 for 0198CD02-FF39-4E11-8F83-0BDF9CBA0611 (B3FA9620)
09:344 00:023 OCBP: APFS bless for 3073B55E-7037-462B-939F-2366635177A7:<null string> is Success
09:372 00:027 OCB: Adding entry type (T:2|F:0|G:0) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,813647947B3EC64F9B99377828A0A8DE)/\58B09F64-E6A1-3321-9074-0084977DEEB3\com.apple.installer\boot.efi
09:396 00:024 OCB: Trying to get label from \58B09F64-E6A1-3321-9074-0084977DEEB3\com.apple.installer\.contentDetails
09:420 00:023 OCB: Trying to get label from \58B09F64-E6A1-3321-9074-0084977DEEB3\com.apple.installer\.disk_label.contentDetails
09:445 00:025 OCB: Registering entry macOS Installer (T:2|F:0|G:0|E:0) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,813647947B3EC64F9B99377828A0A8DE)/\58B09F64-E6A1-3321-9074-0084977DEEB3\com.apple.installer\boot.efi
09:469 00:023 OCBP: APFS Container Info - B9315598 (1, 3073B55E-7037-462B-939F-2366635177A7)
09:493 00:023 OCBP: 10 filesystems for APFS - Success
09:520 00:026 OCBP: APFS Volume Info - B9315398 (131072, 94473681-3E7B-4FC6-9B99-377828A0A8DE, 16)
09:543 00:023 OCBP: APFS Container Info - B9315318 (1, 3073B55E-7037-462B-939F-2366635177A7)
09:567 00:023 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 6 of 10 - 1
09:591 00:024 OCBP: Missing partition 94473681-3E7B-4FC6-9B99-377828A0A8DE on preboot - Not Found
09:615 00:023 OCBP: No APFS booter 6 of 10 for 94473681-3E7B-4FC6-9B99-377828A0A8DE - Not Found
09:639 00:023 OCBP: APFS Volume Info - B9315398 (131072, 58B09F64-E6A1-3321-9074-0084977DEEB3, 64)
09:663 00:024 OCBP: APFS Container Info - B9315318 (1, 3073B55E-7037-462B-939F-2366635177A7)
09:713 00:049 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 7 of 10 - 1
09:737 00:024 OCBP: Found partition 58B09F64-E6A1-3321-9074-0084977DEEB3 on preboot
09:761 00:023 OCBP: Want predefined list for APFS 16 at 58B09F64-E6A1-3321-9074-0084977DEEB3
09:785 00:023 OCBP: Predefined 58B09F64-E6A1-3321-9074-0084977DEEB3 \System\Library\CoreServices\boot.efi is missing - Not Found
09:809 00:024 OCBP: Predefined 58B09F64-E6A1-3321-9074-0084977DEEB3 \EFI\Microsoft\Boot\bootmgfw.efi is missing - Not Found
09:833 00:023 OCBP: Predefined 58B09F64-E6A1-3321-9074-0084977DEEB3 \EFI\BOOT\BOOTX64.EFI is missing - Not Found
09:856 00:023 OCBP: No APFS booter 7 of 10 for 58B09F64-E6A1-3321-9074-0084977DEEB3 - Not Found
09:883 00:026 OCBP: APFS Volume Info - B9315198 (131072, 2FE12C5B-7C6C-4AB6-9F3F-C916072BF826, 4)
09:907 00:023 OCBP: APFS Container Info - B9315298 (1, 3073B55E-7037-462B-939F-2366635177A7)
09:931 00:023 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 8 of 10 - 1
09:955 00:023 OCBP: Missing partition 2FE12C5B-7C6C-4AB6-9F3F-C916072BF826 on preboot - Not Found
09:979 00:023 OCBP: No APFS booter 8 of 10 for 2FE12C5B-7C6C-4AB6-9F3F-C916072BF826 - Not Found
10:003 00:023 OCBP: APFS Volume Info - B9315198 (131072, 1E23C62D-2727-4929-B8E8-F993835E7D2D, 8)
10:031 00:027 OCBP: APFS Container Info - B9315298 (1, 3073B55E-7037-462B-939F-2366635177A7)
10:055 00:023 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 9 of 10 - 1
10:079 00:024 OCBP: Missing partition 1E23C62D-2727-4929-B8E8-F993835E7D2D on preboot - Not Found
10:103 00:024 OCBP: No APFS booter 9 of 10 for 1E23C62D-2727-4929-B8E8-F993835E7D2D - Not Found
10:127 00:023 OCBP: APFS Volume Info - B9315198 (131072, 0198CD02-FF39-4E11-8F83-0BDF9CBA0611, 1)
10:151 00:023 OCBP: APFS Container Info - B9315298 (1, 3073B55E-7037-462B-939F-2366635177A7)
10:175 00:024 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 10 of 10 - 1
10:224 00:049 OCBP: Found partition 0198CD02-FF39-4E11-8F83-0BDF9CBA0611 on preboot
10:249 00:024 OCBP: Want predefined list for APFS 16 at 0198CD02-FF39-4E11-8F83-0BDF9CBA0611
10:272 00:023 OCBP: Predefined 0198CD02-FF39-4E11-8F83-0BDF9CBA0611 \System\Library\CoreServices\boot.efi was found
10:296 00:023 OCBP: Found APFS booter 10 of 10 for 0198CD02-FF39-4E11-8F83-0BDF9CBA0611 (0)
10:320 00:024 OCBP: APFS bless for 3073B55E-7037-462B-939F-2366635177A7:58B09F64-E6A1-3321-9074-0084977DEEB3\com.apple.installer\ is Success
10:344 00:023 OCBP: APFS Volume Info - B9315598 (131072, 58B09F64-E6A1-3321-9074-0084977DEEB3, 64)
10:372 00:027 OCBP: APFS Container Info - B9315418 (1, 3073B55E-7037-462B-939F-2366635177A7)
10:396 00:023 OCBP: APFS recovery info 0/10 due to 00000000-0000-0000-0000-000000000000/3073B55E-7037-462B-939F-2366635177A7/0 - Not Found
10:420 00:023 OCBP: APFS recovery info 1/10 due to 00000000-0000-0000-0000-000000000000/3073B55E-7037-462B-939F-2366635177A7/0 - Not Found
10:444 00:024 OCBP: APFS recovery info 2/10 due to 00000000-0000-0000-0000-000000000000/3073B55E-7037-462B-939F-2366635177A7/0 - Not Found
10:468 00:023 OCBP: APFS recovery info 3/10 due to 00000000-0000-0000-0000-000000000000/3073B55E-7037-462B-939F-2366635177A7/0 - Not Found
10:492 00:023 OCBP: APFS recovery info 4/10 due to 00000000-0000-0000-0000-000000000000/3073B55E-7037-462B-939F-2366635177A7/0 - Not Found
10:516 00:024 OCBP: APFS Volume Info - B9315598 (131072, 94473681-3E7B-4FC6-9B99-377828A0A8DE, 16)
10:543 00:027 OCBP: APFS Container Info - B9315398 (1, 3073B55E-7037-462B-939F-2366635177A7)
10:567 00:023 OCBP: APFS recovery info 5/10 due to 3073B55E-7037-462B-939F-2366635177A7/3073B55E-7037-462B-939F-2366635177A7/10 - Success
10:591 00:024 OCBP: APFS Volume Info - B9315398 (131072, 58B09F64-E6A1-3321-9074-0084977DEEB3, 64)
10:615 00:023 OCBP: APFS Container Info - B9315598 (1, 3073B55E-7037-462B-939F-2366635177A7)
10:639 00:023 OCBP: APFS recovery info 6/10 due to 3073B55E-7037-462B-939F-2366635177A7/3073B55E-7037-462B-939F-2366635177A7/40 - Success
10:663 00:024 OCBP: APFS Volume Info - B9315598 (131072, 2FE12C5B-7C6C-4AB6-9F3F-C916072BF826, 4)
10:687 00:023 OCBP: APFS Container Info - B9315398 (1, 3073B55E-7037-462B-939F-2366635177A7)
10:737 00:049 OCBP: APFS recovery info 7/10 due to 3073B55E-7037-462B-939F-2366635177A7/3073B55E-7037-462B-939F-2366635177A7/4 - Success
10:760 00:023 OCFS: Filename \58B09F64-E6A1-3321-9074-0084977DEEB3\ has trailing slash
10:784 00:023 OCFS: Filename \58B09F64-E6A1-3321-9074-0084977DEEB3\ has trailing slash
10:809 00:024 OCB: Matched fs B9230A18
10:833 00:023 OCB: Adding entry type (T:1|F:1|G:0) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,5B2CE12F6C7CB64A9F3FC916072BF826)/\58B09F64-E6A1-3321-9074-0084977DEEB3\
10:857 00:023 OCB: Trying to get label from \58B09F64-E6A1-3321-9074-0084977DEEB3\.contentDetails
10:884 00:027 OCB: Trying to get label from \58B09F64-E6A1-3321-9074-0084977DEEB3\.disk_label.contentDetails
10:908 00:023 OCB: Trying to get recovery from \58B09F64-E6A1-3321-9074-0084977DEEB3\SystemVersion.plist
10:932 00:023 OCB: Registering entry Recovery (T:4|F:1|G:0|E:0) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,5B2CE12F6C7CB64A9F3FC916072BF826)/\58B09F64-E6A1-3321-9074-0084977DEEB3\
10:956 00:024 OCB: Adding entry type (T:2|F:0|G:0) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,813647947B3EC64F9B99377828A0A8DE)/\0198CD02-FF39-4E11-8F83-0BDF9CBA0611\System\Library\CoreServices\boot.efi
10:980 00:023 OCB: Trying to get label from \0198CD02-FF39-4E11-8F83-0BDF9CBA0611\System\Library\CoreServices\.contentDetails
11:005 00:024 OCB: Trying to get label from \0198CD02-FF39-4E11-8F83-0BDF9CBA0611\System\Library\CoreServices\.disk_label.contentDetails
11:030 00:025 OCB: Registering entry HighSierra (T:2|F:0|G:0|E:0) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,813647947B3EC64F9B99377828A0A8DE)/\0198CD02-FF39-4E11-8F83-0BDF9CBA0611\System\Library\CoreServices\boot.efi
11:057 00:027 OCBP: APFS Container Info - B9315318 (1, 3073B55E-7037-462B-939F-2366635177A7)
11:082 00:024 OCBP: 10 filesystems for APFS - Success
11:106 00:023 OCBP: APFS Volume Info - B9315018 (131072, 94473681-3E7B-4FC6-9B99-377828A0A8DE, 16)
11:130 00:024 OCBP: APFS Container Info - B9315098 (1, 3073B55E-7037-462B-939F-2366635177A7)
11:154 00:023 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 6 of 10 - 1
11:178 00:023 OCBP: Missing partition 94473681-3E7B-4FC6-9B99-377828A0A8DE on preboot - Not Found
11:228 00:049 OCBP: No APFS booter 6 of 10 for 94473681-3E7B-4FC6-9B99-377828A0A8DE - Not Found
11:252 00:023 OCBP: APFS Volume Info - B9315018 (131072, 58B09F64-E6A1-3321-9074-0084977DEEB3, 64)
11:275 00:023 OCBP: APFS Container Info - B9315098 (1, 3073B55E-7037-462B-939F-2366635177A7)
11:300 00:024 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 7 of 10 - 1
11:323 00:023 OCBP: Found partition 58B09F64-E6A1-3321-9074-0084977DEEB3 on preboot
11:347 00:023 OCBP: Want predefined list for APFS 16 at 58B09F64-E6A1-3321-9074-0084977DEEB3
11:371 00:024 OCBP: Predefined 58B09F64-E6A1-3321-9074-0084977DEEB3 \System\Library\CoreServices\boot.efi is missing - Not Found
11:396 00:024 OCBP: Predefined 58B09F64-E6A1-3321-9074-0084977DEEB3 \EFI\Microsoft\Boot\bootmgfw.efi is missing - Not Found
11:419 00:023 OCBP: Predefined 58B09F64-E6A1-3321-9074-0084977DEEB3 \EFI\BOOT\BOOTX64.EFI is missing - Not Found
11:443 00:024 OCBP: No APFS booter 7 of 10 for 58B09F64-E6A1-3321-9074-0084977DEEB3 - Not Found
11:467 00:023 OCBP: APFS Volume Info - B9315098 (131072, 2FE12C5B-7C6C-4AB6-9F3F-C916072BF826, 4)
11:491 00:023 OCBP: APFS Container Info - B9315018 (1, 3073B55E-7037-462B-939F-2366635177A7)
11:515 00:024 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 8 of 10 - 1
11:539 00:023 OCBP: Missing partition 2FE12C5B-7C6C-4AB6-9F3F-C916072BF826 on preboot - Not Found
11:566 00:027 OCBP: No APFS booter 8 of 10 for 2FE12C5B-7C6C-4AB6-9F3F-C916072BF826 - Not Found
11:590 00:024 OCBP: APFS Volume Info - B9315098 (131072, 1E23C62D-2727-4929-B8E8-F993835E7D2D, 8)
11:614 00:023 OCBP: APFS Container Info - B9315018 (1, 3073B55E-7037-462B-939F-2366635177A7)
11:638 00:023 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 9 of 10 - 1
11:662 00:023 OCBP: Missing partition 1E23C62D-2727-4929-B8E8-F993835E7D2D on preboot - Not Found
11:686 00:023 OCBP: No APFS booter 9 of 10 for 1E23C62D-2727-4929-B8E8-F993835E7D2D - Not Found
11:735 00:048 OCBP: APFS Volume Info - B9315098 (131072, 0198CD02-FF39-4E11-8F83-0BDF9CBA0611, 1)
11:759 00:023 OCBP: APFS Container Info - B9315018 (1, 3073B55E-7037-462B-939F-2366635177A7)
11:783 00:023 OCBP: APFS match container 3073B55E-7037-462B-939F-2366635177A7 vs 3073B55E-7037-462B-939F-2366635177A7 for 10 of 10 - 1
11:815 00:032 OCBP: Found partition 0198CD02-FF39-4E11-8F83-0BDF9CBA0611 on preboot
11:839 00:023 OCBP: Want predefined list for APFS 16 at 0198CD02-FF39-4E11-8F83-0BDF9CBA0611
11:863 00:023 OCBP: Predefined 0198CD02-FF39-4E11-8F83-0BDF9CBA0611 \System\Library\CoreServices\boot.efi was found
11:887 00:024 OCBP: Found APFS booter 10 of 10 for 0198CD02-FF39-4E11-8F83-0BDF9CBA0611 (0)
11:912 00:025 OCBP: APFS bless for 3073B55E-7037-462B-939F-2366635177A7:0198CD02-FF39-4E11-8F83-0BDF9CBA0611\System\Library\CoreServices\ is Success
11:936 00:024 OCBP: APFS Volume Info - B9315318 (131072, 0198CD02-FF39-4E11-8F83-0BDF9CBA0611, 1)
11:960 00:023 OCBP: APFS Container Info - B9315298 (1, 3073B55E-7037-462B-939F-2366635177A7)
11:984 00:023 OCBP: APFS recovery info 0/10 due to 00000000-0000-0000-0000-000000000000/3073B55E-7037-462B-939F-2366635177A7/0 - Not Found
12:008 00:024 OCBP: APFS recovery info 1/10 due to 00000000-0000-0000-0000-000000000000/3073B55E-7037-462B-939F-2366635177A7/0 - Not Found
12:032 00:023 OCBP: APFS recovery info 2/10 due to 00000000-0000-0000-0000-000000000000/3073B55E-7037-462B-939F-2366635177A7/0 - Not Found
12:056 00:023 OCBP: APFS recovery info 3/10 due to 00000000-0000-0000-0000-000000000000/3073B55E-7037-462B-939F-2366635177A7/0 - Not Found
12:083 00:026 OCBP: APFS recovery info 4/10 due to 00000000-0000-0000-0000-000000000000/3073B55E-7037-462B-939F-2366635177A7/0 - Not Found
12:107 00:023 OCBP: APFS Volume Info - B9315318 (131072, 94473681-3E7B-4FC6-9B99-377828A0A8DE, 16)
12:131 00:023 OCBP: APFS Container Info - B9315018 (1, 3073B55E-7037-462B-939F-2366635177A7)
12:155 00:024 OCBP: APFS recovery info 5/10 due to 3073B55E-7037-462B-939F-2366635177A7/3073B55E-7037-462B-939F-2366635177A7/10 - Success
12:179 00:023 OCBP: APFS Volume Info - B9315018 (131072, 58B09F64-E6A1-3321-9074-0084977DEEB3, 64)
12:203 00:023 OCBP: APFS Container Info - B9315318 (1, 3073B55E-7037-462B-939F-2366635177A7)
12:253 00:050 OCBP: APFS recovery info 6/10 due to 3073B55E-7037-462B-939F-2366635177A7/3073B55E-7037-462B-939F-2366635177A7/40 - Success
12:277 00:023 OCBP: APFS Volume Info - B9315318 (131072, 2FE12C5B-7C6C-4AB6-9F3F-C916072BF826, 4)
12:301 00:024 OCBP: APFS Container Info - B9315018 (1, 3073B55E-7037-462B-939F-2366635177A7)
12:325 00:023 OCBP: APFS recovery info 7/10 due to 3073B55E-7037-462B-939F-2366635177A7/3073B55E-7037-462B-939F-2366635177A7/4 - Success
12:349 00:023 OCFS: Filename \0198CD02-FF39-4E11-8F83-0BDF9CBA0611\ has trailing slash
12:373 00:024 OCFS: Filename \0198CD02-FF39-4E11-8F83-0BDF9CBA0611\ has trailing slash
12:397 00:023 OCB: Adding entry type (T:1|F:1|G:0) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,5B2CE12F6C7CB64A9F3FC916072BF826)/\0198CD02-FF39-4E11-8F83-0BDF9CBA0611\
12:425 00:027 OCB: Trying to get label from \0198CD02-FF39-4E11-8F83-0BDF9CBA0611\.contentDetails
12:449 00:024 OCB: Trying to get label from \0198CD02-FF39-4E11-8F83-0BDF9CBA0611\.disk_label.contentDetails
12:474 00:024 OCB: Trying to get recovery from \0198CD02-FF39-4E11-8F83-0BDF9CBA0611\SystemVersion.plist
12:498 00:024 OCB: Registering entry Recovery 10.15.7 (T:4|F:1|G:0|E:0) - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,5B2CE12F6C7CB64A9F3FC916072BF826)/\0198CD02-FF39-4E11-8F83-0BDF9CBA0611\
12:522 00:024 OCB: Adding bless entry on disk - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,649FB058A1E6213390740084977DEEB3)
12:546 00:024 OCBP: APFS Volume Info - B9315098 (131072, 58B09F64-E6A1-3321-9074-0084977DEEB3, 64)
12:574 00:027 OCBP: APFS Container Info - B9313898 (1, 3073B55E-7037-462B-939F-2366635177A7)
12:598 00:024 OCB: Adding bless entry on disk - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,5B2CE12F6C7CB64A9F3FC916072BF826)
12:622 00:024 OCBP: APFS Volume Info - B9313898 (131072, 2FE12C5B-7C6C-4AB6-9F3F-C916072BF826, 4)
12:647 00:024 OCBP: APFS Container Info - B9315098 (1, 3073B55E-7037-462B-939F-2366635177A7)
12:671 00:024 OCB: Adding bless entry on disk - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,2DC6231E27272949B8E8F993835E7D2D)
12:695 00:024 OCBP: APFS Volume Info - B9315098 (131072, 1E23C62D-2727-4929-B8E8-F993835E7D2D, 8)
12:719 00:024 OCBP: APFS Container Info - B9313898 (1, 3073B55E-7037-462B-939F-2366635177A7)
12:769 00:049 OCB: Adding bless entry on disk - PciRoot(0x0)/Pci(0x17,0x0)/Sata(0x5,0xFFFF,0x0)/HD(2,GPT,A18C4545-1AF6-49D8-9CEE-0C11CBB69C15,0x64028,0x1BEC0460)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842,02CD980139FF114E8F830BDF9CBA0611)
12:793 00:024 OCBP: APFS Volume Info - B9313898 (131072, 0198CD02-FF39-4E11-8F83-0BDF9CBA0611, 1)
12:817 00:023 OCBP: APFS Container Info - B9315098 (1, 3073B55E-7037-462B-939F-2366635177A7)
12:841 00:024 OCB: Adding fs 2007C5F5 for 1 custom entries and nvram reset (aux shown)
12:865 00:024 OCB: Adding custom entry OpenShell.efi (tool) -> OpenShell.efi
12:889 00:024 OCB: Registering entry OpenShell.efi (T:128|F:0|G:0|E:0) - <nil>
12:913 00:024 OCB: Adding system entry Reset NVRAM
12:941 00:027 OCB: Registering entry Reset NVRAM (T:256|F:0|G:0|E:0) - <nil>
12:965 00:024 OCB: Showing menu...
20:627 07:662 OCB: Should boot from 2. Install macOS Big Sur (T:2|F:0|G:0|E:1|DEF:0)
20:652 00:024 OCB: Perform boot Install macOS Big Sur to dp PciRoot(0x0)/Pci(0x14,0x0)/USB(0x3,0x0)/HD(2,GPT,0EBA4F92-3E31-43DD-9DE7-0F5853063629,0x64028,0x1D4F6B0)/\System\Library\CoreServices\boot.efi (0/0)
20:728 00:075 OCI4: Manifest (2800) for 65666962 parse fail with code 1
20:758 00:030 OCI4: Verifying digest 48 (C5444E9A) override 0 48 (00000000)
20:791 00:032 OCSB: Verified IMG4 without issues
20:815 00:024 OCB: Arch filtering B9123018(723512)->B9123018(723512) caps 4 - Success
20:839 00:024 OCB: Matching <> args on type 2 0
20:863 00:024 OCABC: VMware Mac installed on B9313A18 - Success
20:894 00:030 OCABC: Patching safe mode sur-1 at off 1CC8B
20:918 00:024 AAPL: #[EB|LOG:INIT] 2020-12-30T20:47:15
20:942 00:024 AAPL: #[EB|VERSION] <"bootbase.efi 495.60.1~4 (Official), built 2020-11-23T06:28:08-0800">
20:992 00:049 AAPL: #[EB|BUILD] <"BUILD-INFO[304]:{"DisplayName":"bootbase.efi","DisplayVersion":"495.60.1~4","RecordUuid":"02584802-F48C-4E06-A7EE-8B40DB1D21EF","BuildTime":"2020-11-23T06:28:08-0800","ProjectName":"efiboot","ProductName":"bootbase.efi","SourceVersion":"495.60.1","BuildVersion":"4","BuildConfiguration":"Release","BuildType":"Official"}">
21:016 00:024 AAPL: #[EB|CFG:DEV] r2 0x0 0x0
21:040 00:024 AAPL: #[EB|H:IS] 0
21:065 00:024 AAPL: #[EB|WL:MODE] 0
21:089 00:024 AAPL: #[EB|CFG:ARG] boot-save-log 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) default
21:113 00:024 AAPL: #[EB|CFG:ARG] wake-save-log 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) default
21:141 00:027 AAPL: #[EB|CFG:ARG] console       0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) default
21:164 00:023 AAPL: #[EB|CFG:ARG] serial        0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) default
21:189 00:024 AAPL: #[EB|CFG:ARG] embed-log-dt  0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) default
21:213 00:024 AAPL: #[EB|CFG:ARG] timestamps    0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) default
21:237 00:023 AAPL: #[EB|CFG:ARG] log-level     0x0000000000000001 (0x0000000000000001 & 0x0000000000000021) default
21:261 00:024 AAPL: #[EB|CFG:ARG] breakpoint    0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
21:285 00:024 AAPL: #[EB|CFG:ARG] kc-read-size  0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) default
21:312 00:026 AAPL: #[EB|H:IS] 0
21:336 00:024 AAPL: #[EB|WL] 0 0 0x01 0x01   0 0x00
21:360 00:024 AAPL: #[EB|BRD:NV] Mac-DB15BD556843C820
21:384 00:024 OCOS: OS set: <null> macOS 11.0
21:408 00:024 OCOS: OS set: Apple Inc. macOS 11.0
21:432 00:024 AAPL: #[EB|WL] 0 0 0x01 0x01   2 0x00
21:456 00:024 AAPL: #[EB.BST.IDT|+]
21:507 00:050 AAPL: #[EB.BST.IDT|-]
21:531 00:023 AAPL: #[EB|WL] 0 0 0x01 0x01   3 0x00
21:555 00:024 AAPL: #[EB|WL] 0 0 0x01 0x01   4 0x00
21:579 00:024 AAPL: #[EB|BRD:NV] Mac-DB15BD556843C820
21:603 00:023 AAPL: #[EB|WL] 0 0 0x01 0x01   5 0x00
21:627 00:023 AAPL: #[EB.H.CHK|BM] 0x0000000000000000
21:654 00:027 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
21:678 00:024 AAPL: #[EB|WL] 0 0 0x01 0x01  23 0x0E
21:702 00:024 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
21:726 00:024 AAPL: #[EB|WL] 0 0 0x01 0x01  24 0x0E
21:750 00:024 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
21:775 00:024 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
21:799 00:024 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
21:828 00:028 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
21:852 00:024 AAPL: #[EB|H:NOT]
21:876 00:024 AAPL: #[EB|SB:P] 0x1
21:900 00:024 AAPL: #[EB.B.MN|BM:+SB]
21:924 00:024 AAPL: #[EB|LIMG:DP] Acpi(PNP0A03,0)/Pci(14|0)/Usb(3, 0)/HD(Part2,Sig0EBA4F92-3E31-43DD-9DE7-0F5853063629)
21:948 00:024 AAPL: #[EB|LIMG:FP] \System\Library\CoreServices\boot.efi
21:972 00:024 AAPL: #[EB|LIMG:OPT]
22:022 00:049 AAPL: #[EB|RPS] 0 0 0
22:050 00:028 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
22:072 00:021 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\com.apple.Boot.plist"> <"0">
22:096 00:024 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
22:120 00:024 AAPL: #[EB.OPT.LXF|LF!] Err(0xE)
22:144 00:024 AAPL: #[EB.OPT.LXF|F] <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist">
22:180 00:036 AAPL: #[EB.LD.LF|IN] 0 1 <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist"> <"0">
22:210 00:029 AAPL: #[EB|KF] <"root-dmg=file:///BaseSystem/BaseSystem.dmg">
22:232 00:022 AAPL: #[EB|MBA:CL] <"">
22:256 00:024 AAPL: #[EB|MBA:NV] <"-v debug=0x100 keepsyms=1 alcid=1">
22:280 00:024 AAPL: #[EB|MBA:KF] <"root-dmg=file:///BaseSystem/BaseSystem.dmg">
22:304 00:023 AAPL: #[EB|MBA:OUT] <"-v debug=0x100 keepsyms=1 alcid=1 root-dmg=file:///BaseSystem/BaseSystem.dmg chunklist-security-epoch=0 -chunklist-no-rev2-dev">
22:328 00:024 AAPL: #[EB|LOG:VERBOSE] 2020-12-30T20:47:17
22:353 00:025 AAPL: #[EB|OPT:BM] 0x200082
22:378 00:024 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\PlatformSupport.plist">
22:402 00:024 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\PlatformSupport.plist"> <"0">
22:431 00:028 AAPL: #[EB|B:VAw]
22:453 00:022 AAPL: #[EB|P:CPR] N
22:477 00:024 AAPL: #[EB|P:MPI] N
22:527 00:049 AAPL: #[EB|P:BPI] N
22:551 00:024 AAPL: #[EB|KMR] 317693952
22:575 00:023 AAPL: #[EB.CS.CSKSD|+]
22:599 00:024 AAPL: #[EB.CS.CSKSD|!] Err(0xE) <- RT.GV boot-info-payload 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF
22:623 00:024 AAPL: #[EB.G.CS|-?] Ok(0)
22:650 00:026 AAPL: #[EB.LD.LF|IN] 0 1 <"<null string>"> <"1">
22:717 00:066 AAPL: #[EB.B.SBS|SZ] 723512
22:750 00:033 AAPL: #[EB|B:SHA] <e48017093582dade95e5d935479d716c605ba4c9>
22:779 00:029 AAPL: #[EB.WL.PWLFNV|!] Err(0x5) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
22:806 00:026 AAPL: #[EB.WL.DT|!] Err(0x5) <- EB.WL.PWLFNV
22:835 00:029 AAPL: #[EB.LD.LKC|D] <"System\Library\KernelCollections\BootKernelExtensions.kc.development">
22:866 00:030 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\KernelCollections\\BootKernelExtensions.kc.development"> <"0">
22:896 00:030 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"System\\Library\\KernelCollections\\BootKernelExtensions.kc.development">
22:925 00:028 AAPL: #[EB.LD.LKC|R.2] <"System\Library\KernelCollections\BootKernelExtensions.kc">
22:959 00:033 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\KernelCollections\\BootKernelExtensions.kc"> <"0">
23:207 00:247 OC: Kext reservation size info 558000 exe 347000
23:229 00:022 OC: Trying 64-bit XNU hook on System\Library\KernelCollections\BootKernelExtensions.kc
30:598 07:369 OC: Result of 64-bit XNU hook on System\Library\KernelCollections\BootKernelExtensions.kc (13D72B0B) is Success
30:628 00:030 OCAK: Read kernel version 20.2.0 (200200)
30:655 00:026 OCAK: Replacing _xcpm_core_scope_msrs data 226 76
30:705 00:049 OCAK: Replacing _xcpm_core_scope_msrs data 226 406416
30:729 00:023 OCAK: Replacing _xcpm_core_scope_msrs data 226 16384
30:753 00:024 OCAK: Not matching _xcpm_core_scope_msrs data 46 422876
30:779 00:026 OCAK: 64-bit XcpmCfgLockRel replace count - 2
30:822 00:043 OCAK: 64-bit PanicKextDump replace count - 1
30:846 00:024 OCAK: Patch success kext dump
30:879 00:032 OCAK: 64-bit PowerStateTimeout replace count - 1
30:907 00:027 OCAK: Patch success power state
30:933 00:026 OCAK: Found jettisoning fileset
31:028 00:095 OCAK: Local relocs 784 on FFFFFF8003FC5000
31:054 00:025 OC: Prelinked injection Lilu.kext () - Success
31:080 00:026 OCAK: Patching invalid size 2000 with 18EE000 for com.apple.iokit.IOACPIFamily
31:113 00:032 OCAK: Local relocs 504 on FFFFFF800404B000
31:143 00:030 OC: Prelinked injection VirtualSMC.kext () - Success
31:174 00:031 OCAK: Patching invalid size 28000 with 1399000 for com.apple.iokit.IOPCIFamily
31:212 00:037 OCAK: Local relocs 5252 on FFFFFF8004074000
31:257 00:044 OC: Prelinked injection AppleALC.kext () - Success
31:284 00:027 OCAK: Patching invalid size 17000 with 1632000 for com.apple.iokit.IONetworkingFamily
31:321 00:037 OCAK: Local relocs 641 on FFFFFF80041F6000
31:347 00:025 OC: Prelinked injection IntelMausi.kext () - Success
31:402 00:055 OCAK: Local relocs 337 on FFFFFF8004235000
31:427 00:024 OC: Prelinked injection SMCProcessor.kext () - Success
31:458 00:030 OCAK: Local relocs 1890 on FFFFFF8004244000
31:492 00:034 OC: Prelinked injection SMCSuperIO.kext () - Success
31:525 00:032 OCAK: Local relocs 1716 on FFFFFF8004269000
31:555 00:029 OC: Prelinked injection WhateverGreen.kext () - Success
31:579 00:023 OC: Prelink size 68861952 kext offset 65425408 reserved 3436544
31:607 00:027 OCAK: KC TEXT is 65536 bytes with 50560 Mach-O headers need 624
31:661 00:054 OCAK: Patching invalid size 8D000 with 1067000 for com.apple.iokit.IOUSBHostFamily
31:686 00:024 OCAK: 64-bit RemoveUsbLimitIoP1 replace count - 1
31:710 00:024 OCAK: Patch success port com.apple.iokit.IOUSBHostFamily
31:737 00:027 OCAK: Patching invalid size 4E000 with EC9000 for com.apple.driver.usb.AppleUSBXHCI
31:761 00:024 OCAK: 64-bit RemoveUsbLimitV2 replace count - 1
31:788 00:026 OCAK: Patch success com.apple.driver.usb.AppleUSBXHCI
31:815 00:027 OCAK: Patching invalid size 28000 with E72000 for com.apple.driver.usb.AppleUSBXHCIPCI
31:839 00:024 OCAK: Skipping legacy port patch AppleUSBXHCIPCI on 200200
31:873 00:033 OC: Prelinked status - Success
32:410 00:537 AAPL: #[EB|SB:P] 0x1
32:436 00:025 AAPL: #[EB|SB:SBGMFNS] j137ap.im4m
32:466 00:029 AAPL: #[EB|SB:MF] System\\Library\\KernelCollections\\BootKernelExtensions.kc.j137ap.im4m
32:522 00:056 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\KernelCollections\\BootKernelExtensions.kc.j137ap.im4m"> <"0">
32:558 00:036 OCI4: Verifying digest 48 (13D72B0B) override 1 48 (13D72B0B)
33:084 00:526 OCI4: Matching override 25A6E73D with 25A6E73D - success
33:109 00:024 AAPL: #[EB|SB:MKRN]
33:142 00:033 AAPL: #[EB.LD.LKFS|-?] Ok(0)
33:167 00:025 AAPL: #[EB.LD.LKC|-?] Ok(0)
33:194 00:026 AAPL: #[EB|FWFM] 0x00000000FF1FFF3F
33:223 00:028 AAPL: #[EB|FWFT] 0x00000000FC0FE137
33:248 00:024 AAPL: #[EB|BST:REV1]
33:273 00:025 AAPL: #[EB|CSR:IN] 0x00000067
33:299 00:025 AAPL: #[EB|CSR:OUT] 0x00000067
33:327 00:028 AAPL: #[EB.BST.FBS|+]
33:351 00:023 AAPL: #[EB.BST.FBS|ADSZ] 0
33:379 00:028 AAPL: #[EB.BST.FBS|KSSZ] 0
33:405 00:025 AAPL: #[EB|SB:SBGMFNS] j137ap.im4m
33:432 00:026 AAPL: #[EB|RH:PF] usr\standalone\OS.dmg.root_hash
33:460 00:027 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.j137ap.im4m">
33:488 00:027 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0">
33:516 00:028 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash">
33:542 00:026 AAPL: #[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF
33:595 00:052 AAPL: #[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH
33:619 00:024 OCSMC: SmcReadValue Key 4D535463 Size 1
33:643 00:024 OCSMC: SmcReadValue Key 4D534163 Size 2
33:669 00:025 AAPL: #[EB.B.WFDW|!WF] Err(0xE) 0
33:695 00:026 AAPL: #[EB|LOG:DT] 2020-12-30T20:47:28
33:722 00:026 AAPL: #[EB|LOG:EXITBS:START] 2020-12-30T20:47:28
can anyone help me?
config.plist.zip
Pl Help Very New to Hacknitosh :
 I have Downloaded Olarila BIG SUR 11.1 RAW Image from https://tinyurl.com/y7c7dhp7
System Specs Are :
Gigabyte H61M-S (BIOS BUILD F3a) , I7-3770 CPU, 8gb * 2 Corsair XMS 1600Mhz DDR3 RAM, Atheros AR9271 USB WLAN, VIA USB3 PCIE CARD Which has 4 USB3 Out, WD M2 based SSD Attached to a Generic PCIE CARD, ACER P166HQL VGA Monitor.
[ NEED OpenCore EFI For This as Per a Youtube Video Tutorial to be Copy Pasted in EFI Partition of USB ]
If Somebody Can Help i Will be so much Thankfull to him. Thanks a Lot.
Edited by mdl052020
2 hours ago, MaLd0n said:
Brother i am very new to Hacknitosh. Please if you can build EFI for me i will be very thankfull to you.
or Suggest me in brief how to create EFI for my system specs that i have posted in my first post on this forum.
Just check tutorials above bro
thank you bro i got to know without gpu card gtx 1050 ti it will never install because installation needs HDMI port as mandatory .
CPU based IGPU vga will fail to install.
successfully installed today . great tutorial , thanks a lot.
Buenos días,
Después de intentarlo muchas veces he podido instalar Big Sur 11.1, con el último opencore folder. Antes tenía que instalar Catalina y actualizar a Big Sur. He seguido el manual de opencore que recomiendan y creo ha quedado perfecto. Únicamente un problemilla, que ya tenía en Clover, en menor medida: Porqué se para (deja de funcionar) el reloj de la placa base Gigabyte Z390 Aorus Pro ?. Tengo que resetear la bíos uefi, pero dura poco, que deja de funcionar de nuevo el reloj.  He cambiado tres placas base, del mismo modelo, y en todas pasa lo mismo.
Saludos y gracias.
i cant download this file
Link 2 - https://tinyurl.com/ydxme7jl
Quote
Sorry, you can't view or download this file at the moment.
Recently, too many users have viewed or downloaded this file. Please access this file again later. If the file you visit is very large or shared with multiple people, it can take you up to 24 hours to view or download it. If you still can't access this file after 24 hours, contact your domain administrator.
Help please
Lucas segue a config do meu Dell, i5 de 4th, intel HD4400, versao da bios a12, instalei o Big Sur mas ficou lento sabe, com legs, reconheceu a placa de video mas o sistema não ficou liso, vou tentar com sua efi, vc tem alguma dica pra mim fazer essa instalação ?
bom dia Maldon.
estou tentando fazer uma instalacao limpa do Big Sur com opencore no meu laptop que ja tem o catalina mas na hora do boot fica assim foto em anexo. desde ja agradeço a atenção .
IMG_5281.jpg.zip
6 minutes ago, MKR said:
bom dia Maldon
Check Olarila Tutorials and Useful Links!
-OpenCore Vanilla Guide
https://tinyurl.com/w3d4yrk
-Clover Vanilla Guide
https://tinyurl.com/hxu2v9wm
-Useful Links
https://tinyurl.com/43t5m6d4
-Premium Users
https://tinyurl.com/ecmhv5ke
On 6/27/2020 at 5:31 PM, blu24 said:
@MaLd0n
clear and simple instructions. I found it very easy to install!!!
Thank you for the tutorial ?
Hi, I have a Lenovo Ideapad s540 with i5 8265U Coffee Lake chipset with Intel UHD 620. I tried all the available resources for building my EFI but failed for 2 months straight. So please could you help me out with my EFI. I have encountered all the possible errors in the past. I have a robust and stable Catalina installed using Clover 5119, but I failed upgrading up to big Sur with Clover and OC as well. I even tried to go through a bootable USB but didn't work out. So anyone's help would be Superb...????
Thanks.
The DSDT.aml file?
Because my laptop just keeps shutting down everytime I try to boot it. I am using Big Sur 11.3. I will attach the efi for reference.  This is an EFI for my stable Catalina 10.15.7 with Clover 5119. EFI file is going upto 40 MB so attaching only the config.
config_catalina.zip
