8 hours ago, Bella Bieber said:
Guys, do you have the beta 2 download link (20A4300b) . It is the version that had worked on me.
https://drive.google.com/file/d/1o9uLbj_ZEgTnu2aqVxd7BpO-ZZ-wDwhU/view?usp=sharing
1 hour ago, origindevx said:
download .dmg files,you torrent files.Do you provide torrent files?
https://www.olarila.com/topic/6278-new-vanilla-olarila-images/
Is .dmg the full image of the installation completed and can be recovered directly to usb disk or hard drive as an installed system? I can't access google drive, I want a torrent, use bt to download the way.
On 11/30/2020 at 8:42 AM, MaLd0n said:
The file in this url is a mirror image of install big sur. I want a mirror that completes the installation and can be restored directly to the hard drive for use.
Previously, I used Apple's official production of an installation image made with the command to install usb disk, and after the installation (one night).
I was on the stuck on waiting for dsmos (I asked you about this error, but it never worked out). Please give a torrent file that has been installed.
Thank you!
only images bro
Hi
I am trying to install Olarila (Opencore) and I am having this issue
I even downloaded vanilla opencore downloading images from Apple with macrecovery to make sure it was not a image problem and in both scenarios this happens
The same error with OS.dmg.root_hash and stucks in the installation
Tks
20201208_100931men.zip
9 hours ago, neverday said:
@MaLd0n open core is stuck on this screen, how do I Show the reboot partition in the open core?
inject device ec
4 hours ago, crisorlandobrsp said:
Hi
check here -OpenCore Vanilla Guide
Hello Friends,
Last week I get my Asus Z87 deluxe/Quad i7-4770K  with 32GB RAM and GTX660TI working with Big Sur following this guide:
. And when I tried to install Kext for bluetooth I had to disable SIP. I Entered in recovery mode and I type: "csrustil disable". And after that never boot  again, even with the installation USB.
I also tried to do a new installation, but aI got always the same error (see attaches). I don't know what can I do. I aso attach my EFI folder.
Anyone could help me?
Thank you so much.
EFI.zip opencore-2020-12-18-113733.txt.zip
9 hours ago, MaLd0n said:
Thank you much!
I followed the guide and the main think, I disabled thunderbolt from the BIOS, But now It stuck in this screen:
IMG_3819.jpg.zip
It is so weird.EFI.zip
opencore-2020-12-18-230611.txt.zip
Edited by jefernandez
no idea what happens
