9 hours ago, Đặng Anh Đức said:
First of process or some EFI can install but can't boot the language choose screen
What are dsdt or ssdt you put inside? Check your booter quirks also
8 hours ago, samuraikingspin said:
I get apfs module start 2446 when I boot up Big Sur after install. Please help me!
Post the pic of verbose screen
26 minutes ago, JhoonCollins said:
How to enable audio through hdmi rx 5500xt?
whatevergreen
I had been able to boot my Big Sur installer but once I installed it in my hard drive, the installation does not boot or proceed to the desktop. I have used your olarila BS image and yet it does not even boot in my OC. I have done clover as well but all it does is give me MACH reboot or ACPI error. Can you help me with this?
Here is my EFI for OC. You can help me with the clover EFI as well.
https://workupload.com/file/DK7eJ9cZaeF @MaLd0n
9 minutes ago, Bella Bieber said:
I had been able to boot my Big Sur @MaLd0n
check things here
Hi all, I have been trying to install Big Sur Public beta 1since it was released. Til now I had no succeed , I have Asus Prime A Z390. Couldn't find out what is missing or what I am doing wrong, the last try was with Olarila OC EFI for Coffee Lake cpu, I installed big Sur into external HD, when I tried to boot it after it was installed from Preboot It load for 5 seconds with apple logo and it system restarts. Thank you Maldon and all
update kexts and bootloader and try
Add debug=0x100 and keepsyms=1 and try to boot
7 hours ago, JhoonCollins said:
What is the best smbios for my setup?
use iMacPro1,1 or MacPro7,1
Maldon por gentileza me ajuda a esclarecer um problema. Eu fiz tudo novo aqui em relação á restauração do .dmg porque quando faço com a formatação do HDD em APFS ele não é reconhecido no inicio do boot. Mas quando faço em HFS da certo aparece consigo dar o boot certo mas não consigo fazer os updates de jeito nenhum consigo baixar mais na hora de fazer o boot de install da erro. Então Eu pergunto o que precisa fazer pra o boot open core ou clover que consigo usar os dois reconhecer o HD quando é feito o restore .dmg no formato APFS? Minha mobo não usa UEFI uso o boot legacy
Edited by Aloisio
tem de usar os drivers hfsplus e apfs
Estão sendo usados mais ainda sim não aparece. Tem uma outra coisa estou tentando usar em legacy as versões mais atualizadas do boot OC tem dado o erro daquela tela vermelha X64 000000 e varios binarios o que pode ser?  fazendo via USB e HD interno também tem dado.
Edited by Aloisio
não faço idéia. se vc está usando os drivers era pra aparecer
