2 hours ago, MarceloMustaine said:
Maldon, consegui utilizar o bit sur por esse método com o opencore, agora preciso da sua ajuda para a DSDT
use esse plist co m a ssdt olarila, reinicia e extrai novo sendme
config.plist.zip
7 minutes ago, MarceloMustaine said:
Funcionou tudo! Só o wi-fi que é um modelo que não funciona, apesar de aparecer no sistema. É um qca9377
esse wifi não funciona e nem esse trackpad. não sei se eles conseguiram resolver isso
Acho que não resolveram ainda sobre o trackpad, mas dá pra tentar instalar as novas kext pra teste
Did developer beta 6 changed something? I have been running an Haswell machine ( hp elitedesk g1 ,which EFI I got from here) perfectly. I have been updating from beta to beta through the system updater, no problem what so ever. With beta 6 it broke my Igpu. No acceleration and only get 7MB of Vram. Was working just fine on all previous betas... Help please.
On 8/18/2020 at 8:41 PM, lclerte said:
Hello!! WHo knows how to disable csrutil authenticated-root in BiG Sur beta 4 ?? ( to disable completely SIP in Big Sur beta 4)
my spec: bootargs ! csr-..... 67000000 DATA
Should I write. FF0F0000. or FF070000 or other value for SIP completely disable ?
I did , in the terminal of BS beta 4 installer :
csrutil authenticated-root disable
I reboot ..
and , in terminal :
Last login: Tue Aug 18 20:34:19 on console
~ % csrutil authenticated-root status
Authenticated Root status: enabled
~ % csrutil status
System Integrity Protection status: disabled.
THANKS !!!
very simple : (boot to your USB installer for your beta 4 then: when you are on the first windows : language : click english or other .. then second window : you have , in the menu bar Terminal : click  write :  csrutil authenticated-root disable..... so you did it : But)  you have , I think , two solutions: first is to leave blank your bootarg csr-active-config  in your config plist (after doing in the installer terminal : csruitl disable ; csrutil athenticated-root disable) , or write 67080000....
try also 77080000 (which works for me)   in textmate:
                <key>csr-active-config</key>
                <data>dwgAAA==</data>
1 hour ago, Kaoman said:
getting this error. is it cuz im using an nvme drive?  it goes here and reboot loops everytime
in this case try with vsmcgen=1
Just now, Kaoman said:
did this and it went to pci configuration begins then reboots
reset nvram first time?
yes , i remember you posting that somewhere. now it passes again but it goes and reboots like the first place it used to. but it says ioplatformhaltrestartaction --> applesmc
Edited by Kaoman
try with fakesmc instead
ok ill try that and see if it works
nope same thing, i finished the installer and now im trying to boot the setup but nothing. the installer booted fine , no problems, installed to disk. now trying to boot and nothing, this error is screwing my plans
I think we have the same issue.
Opencore boots fine, I managed to install until 12/13 minutes remaining, after that tries to boot, but crashes.
Then manual rebooting opencore loads fine there's a option for bigsur macos install select this and at the phase that the apple logo is already up the screen it crashes and can't even see the errors, because it's too quickly something with "sigakill: shutdown...!!!.
Been this week trying to figure this thing out, but no show!
Any clues?
EDIT: Since I can't make any usb to boot in my system, i booted from empty internal ssd, only with EFI populated, after that i use the usb  to make the installation to the internal SSD. Could this be the issue?
HP XW6600, 2xXeonE5430, 16 GB, 256GB SSD, Nvidia 710GT.
EDIT2: I was able to get a picture of the final verbose, just before the screen become black. Can anyone make something of this, it's not very clear.
Screenshot 2020-09-11 at 17.33.35.zip
Edited by analise65
Any clues?
similar but different, mine completed the installer fully, no issues there. when i try to boot into the finished product i get my error. ill try and upload the whole video somewhere so you guys can see it and maybe help identify the issue
ok i tried with your config plist but i am now stuck on exitdbslog again
when i use my plist it restarts after booting with the error i posted earlier.
this new plist has more options than mine so maybe its better.
maybe you can take a look at it to see if i went wrong somewhere. hopefully this is solved and i can play with big sur
EDIT: reinstalled and now its working fine. didnt do anything different but maybe a file was left out. kind of slow though, is it because of the nvme drive? even the sound is laggy
Edited by Kaoman
Hi,
What's options did you change, i think you mean quircks, right?
Could you post your config file.
hi, what about Big Sur with AR9285? I cant make it work!
