Hello!! WHo knows how to disable csrutil authenticated-root in BiG Sur beta 4 ?? ( to disable completely SIP in Big Sur beta 4)
my spec: bootargs ! csr-..... 67000000 DATA
Should I write. FF0F0000. or FF070000 or other value for SIP completely disable ?
I did , in the terminal of BS beta 4 installer :
csrutil authenticated-root disable
I reboot ..
and , in terminal :
Last login: Tue Aug 18 20:34:19 on console
~ % csrutil authenticated-root status
Authenticated Root status: enabled
~ % csrutil status
System Integrity Protection status: disabled.
THANKS !!!
Hello, this is my specs:
SPECS:
    Mother board: Broadwell-MB IMC 0RN98T
    CPU: i3-5005U
    GPU: HD5500
    Wireless and Bluetooth: AR9002WB-1NG (I replaced the in-built one)
    Audio Card: ALC255 [ALC256? (branded as ALC3234)] ALC3234 is equivalent to ALC255
    Ethernet: Realtek RTL8139/810x Fast Ethernet Adapter (RTL8111?)
    Touchpad: Synaptics
In Release 0.6 and Big Sur beta x ( i dont remember) i can installed Big Sur but keyboard not working (A). Then i recreater Big Sur public beta with Debug 0.6.1 builded from OCBuilder but always reboot after choose install Big Sur, i found ib OC Wiki said about 2 case: Black screen after picker  and Booting OpenCore reboots to BIOS but nothing wrong!! Even i try with OC folder (A) no lucky
This is log of debug version:
Any ideas? , thanks!
opencore-2020-08-26-231230.txt.zip
Edited by oldman20
compile last opencore and kexts
OCBuilder didnt do it, sir?
u need xcode and command line for that
OpenCore n' Kexts.command.zip
Until now Big Sur Public Beta can be install yet, or must restore, sir?
both work. but restore work ever
On 6/28/2020 at 10:49 PM, Marck00 said:
Hey, everybody, does anyone else get something like this a lot?
Disk1s5s1: device is not readable.
On diskutil it appears as a snapshot
Yes I am getting that is there any solution
Hi, I'm new to the forum and with OpenCore. I managed to install Big Sur but obviously it didn't work out right away. So, as a test, I tried to clone my Catalina partition that I had to another disk (with Clover) and I had no problem, except that obviously I lost some things that worked before. At the moment I am trying to get the audio to work (with AppleALC) and to have the touchpad recognized, which works but is not recognized as such. My laptop is a Lenovo G50-70, if you need more information just ask. I am attaching my EFI folder.
http://www.mediafire.com/file/tzd7egdya2yexs3/EFI.zip/file
Thanks in advance.
check useful links
https://www.olarila.com/topic/6129-useful-links/
Hi Maldon,
Descarreguei a beta5 e restaurei para um ssd interno livre, aparentemente ok.
A minha questão é que quando tento iniciar este disco as únicas opções que tenho são "Preboot" e "Restore 11.00" volumes.
É normal? Ou o restore correu mal? Qual deveria ser o volume que deveria fazer o primeiro boot?
Obrigado!
Paulo
veja se vc fez o restore da partição correta
Olá Maldon,
Obrigado pela sua resposta. Verifique pf. na imagem se está tudo correto.
Vai verificar que um volume não tem nome, é mesmo assim?
Obrigado!
EDIT: Pelo "screenshot 2" um dos volumes, que deveria ser, a raíz acho eu, está com erro.
Screenshot 2020-09-03 at 16.15.37.zip
Screenshot 2.zip
Edited by analise65
im restored method but opencore cant find big sur :(
/dev/disk4 (external, physical):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      GUID_partition_scheme                        *160.0 GB   disk4
   1:                        EFI EFI                     209.7 MB   disk4s1
   2:                 Apple_APFS Container disk5         159.8 GB   disk4s2
/dev/disk5 (synthesized):
   0:      APFS Container Scheme -                      +159.8 GB   disk5
                                 Physical Store disk4s2
   1:                APFS Volume Macintosh HD - Data     1.5 GB     disk5s1
   2:                APFS Volume Preboot                 211.6 MB   disk5s2
   3:                APFS Volume Recovery                749.0 MB   disk5s3
   4:                APFS Volume VM                      1.1 GB     disk5s4
   5:                APFS Volume                         14.8 GB    disk5s5
   6:                APFS Volume Update                  824.2 MB   disk5s6
use beta 5 restore
https://www.olarila.com/topic/9679-olarila-big-sur-beta-5-vanilla-image-restore-mode-easy-way-opencore/
4 minutes ago, MaLd0n said:
of course, that's image i used, sir :(
beta 5 have 45gb mounted
Did developer beta 6 changed something? I have been running an Haswell machine ( hp elitedesk g1 ,which EFI I got from here) perfectly. I have been updating from beta to beta through the system updater, no problem what so ever.
With beta 6 it broke my Igpu. No acceleration and only get 7MB of Vram. Was working just fine on all previous betas and I din't change anything on the EFI.
Help please.
