Hello, i can boot into login screen, but keyboard not working, only wireless mouse, try VoodooPS2 and get KP :(
config.plist.zip
6 hours ago, robdes69 said:
i have same mobo can you send me your efi having problems booting big sur
I had solved my booting problems
On 8/3/2020 at 2:41 AM, MaLd0n said:
yes
Had time to look at it again, I re generated EC on Windows machine (same machine) but I still getting AppleNVME Assert failed: 0
How to clear cache / boot cache ?
Attaching my EFI folder(keeping important folders and files to minimise size)
EFI_1.zip
Add some progress changing EFI plist and now it stuck on RTC line, I have added npci=0x2000
1 hour ago, kayrawlf said:
hi mald0n
u use many renames. dont need it. just use _sta rtc fix, reboot and extract
ok, I used only sta rtc fix
https://drive.google.com/file/d/19qAJpk4l1Bza25JAj89GmT6jxF_HWQDf/view?usp=sharing
run me file
1 hour ago, oldman20 said:
with that version, i cant boot into login screen
-igfxvesa?
On 8/3/2020 at 5:06 AM, MaLd0n said:
device ec injected?
I have same problem, but my device ec name is "EC" no "EC0" anymore. Do I need injected EC again?
2 hours ago, MaLd0n said:
-igfxvesa?
Same, sir!
I managed to start the installer, complete the installation; but now when starting the "macOS installer" to complete the first boot it appears to boot; the graphic screen starts ; I can see the progress bar for about 5s and then it starts to shutdown and reboot.
I can't see any obvious error; the text showing is what I would expect to see if I cleanly shutdown the mac:
Has anyone seen something similar before?
I'm not too sure where to look next.
Have you put the boot args keepsyms=1 and debug=0x100 ?
Have you updated to OC 0.6.1?
yes I added and yes using 6.1 still have same boot issue - AppleNvmen Assert failed (IONVMeController)
Edit
After modifying plist boot arg now I'm stuck on RTC non contiguous device register map entries
Thanks for reply
Edited by wizzy
Edit
Thanks for reply
Add Fix RTC _STA bug
Hmm could you please tell me how and where to add it?
Added still stuck  :(
Edited by wizzy
HI to all, i cant download the dmg and put in your desktop to restore it directly on my ssd, any help is appreciated. thanks
