Can someone else PLEASE host/upload this .dmg file? I tried "adding" it to my google drive account and it just added a shortcut and says the same thing, too many downloads. Not available at this time.
New build ASRock Z390 Phantom Gaming 9 i9-9900K MSI RX580 8GB Big Sur 11.0.1 32GB DDR4
First build ASRock Z270 Gaming K6 i7-7700K MSI RX580 8GB Mojave 10.14.6 32GB DDR4
this way work good
@MaLd0n I was finally able to download the files, thank you. Can I ask for a little advice? I am currently running 10.15.6 Catalina with Clover and I have been wanting to make the switch to OpenCore. My 10.15.6 install is on my 1TB m.2 SSD and I have a spare 500GB SSD in the machine to tinker with. Should I just start a brand new install on the 500GB SSD of Big Sur with OpenCore and get it running, then migrate it to the m.2 when it's fine tuned? Should I use the USB method with beta 3? I just want to be successful with installing beta 3. Thanks as always.
On 7/17/2020 at 5:59 PM, MaLd0n said:
use entire disk
I installed BS from your guide , but I when I boot from USB installer , the first window show diskutility where ONLY external drives are shown ??? Do you know why ?? Thanks
5 hours ago, rocky_mtn said:
beta 3 is a shot in the dark. for me work with efi premade
no idea
some people report it in big sur beta
hey when i try to restore the image to my ssd it goes way over 128gb its at 524 gb now. did i do something wrong?
59089354752 bytes transferred in 4167.751165 secs (14177755 bytes/sec)
sorry thats only 59GB my bad , ill wait until the restore is complete and check back
Edited by Kaoman
@MaLd0n  I've successfully installed Big Sur beta 2 with Opencore 0.6.0 but I now want to upgrade to beta 3. When booting using the installer it gives me the following message and won't continue (no matter how long I wait). See attachment.
Please note that I don't have a Thunderbolt Display if that is relevant to mention.
Thunderbolt 255 PCI - LS=0x7043 LC=0x0040 SS=0x0140 SC=0x0008 PMCSR=0x0000 RT=0xffffffff NLRT=0xffffffff LWRT=0xffffffff PRRT=0xffffffff TRT=0x0000 TNLRT=0x0000 TLWRT=0x0000 TPRRT=0x0000 TLUP=0x0001
Hopefully you can provide some suggestions.
IMG_0594.JPG.zip
9 hours ago, Kaoman said:
is about quirks
try with fakesmc
1 minute ago, Kaoman said:
what quirks should i use? should i upload my config file?
check here
https://opencore.slowgeek.com/
22 minutes ago, Kaoman said:
sorry to bother you again but im getting the same error ?
i need discovery what cause it ;)
my specs are i5 10400
gigabyte vision g z490
16gb ram 3600
is it cuz of the cpu or something?
lemme know if you want the config file
Define premade EFI please? Installed on the target drive or the install USB for this premade EFI? Reason I ask is because beta 3 installs fine on my SSD and works, but the moment I try to install it on my production nvme drive it will NOT install at all. The target nvme drive never shows itself in the opencore bootloader...Thanks!
1 hour ago, Kaoman said:
if yes can you share your efi please
use my folder for z490 vision d and update things for big sur
https://easyupload.io/f4l0ws
u just need a full dsdt patched after that
1 hour ago, rocky_mtn said:
big sur is a shot in the dar for now
ok thank you! it works now finally lol i just need a little help getting it to restart and shutdown properly. also is there a way to update it? when i try to load the updater it hangs on the same dbstart:log
