20 minutes ago, jzrodriguez98 said:
I booted again but still no working WiFi
post ur dsdt here
18 minutes ago, jzrodriguez98 said:
DSDT included as requested.
i'm using 43a0 dev id and any version AirportBrcmFixup.kext without plugins
Thanks @MaLd0n. So should I go inside the AirportBrcmFixup kext and delete the new two plugins and add in OC config file under device properties the device id?
yes
28 minutes ago, jzrodriguez98 said:
 I uploaded a screenshot of how the card was reported under ioreg in macOS Catalina.
upload ioreg and dsdt
On 7/15/2020 at 5:07 AM, jzrodriguez98 said:
@MaLd0n I just did what you suggested but no WiFi after booting. There should be something else that is tricking me...
@MaLd0n I uploaded a screenshot of how the card was reported under ioreg in macOS Catalina.
Download this https://www.olarila.com/applications/core/interface/file/attachment.php?id=27900 and open it. You will find the latest kexts in Lilu4All/Release.
Then, drag and drop AirportBrcmFixup.kext to Kernel->Add in OpenCore Configurator. Three new options are added, on the right side, disable the AirPortBrcm4360_Injector.kext
I post you an image:
https://drive.google.com/file/d/1Rn9FEjKZskE7wTkwiBT8k3OUY3lxTBMr/view?usp=sharing
Edited by lukakeiton
AMD Ryzen 9 3900X
ASUS ROG STRIX X570-E GAMING
Sapphire Nitro+ Radeon RX 590 8GB
CORSAIR Vengeance LPX 32GB DDR4 3600Mhz
i need files generated by runme.app
21 minutes ago, jzrodriguez98 said:
Hello @MaLd0n. Attached is the Config file, Ioreg and DSDT. Still no luck with the WiFi BCM94331CD in Big Sur beta 2.
IDK id ur card have support
one shot
Archive.zip
one shot
Thanks @MaLd0n. Regarding the config file I shared with you in the previous post, do I have to change something?
Hello @MaLd0n. I was able to finally have WiFi 100% functionally after updating the device properties based on the last DSDT you shared and removed from kernel<add section the plugins in the Config file. Thanks a lot for all your help.
Enjoy!
14 minutes ago, diojoans said:
how to create new partition with EFI on it?
if u format in GUID efi partition is created
is it possible to restore big sur on partition internal harddrive?
use entire disk
Could you share me your dsdt file? I had the same problem with 94331cd.
Sorry, my English is not very good!
49 minutes ago, sonudbm said:
Getting Error: Service exited due to SIGABRT...i used premade efi folder
https://www.olarila.com/topic/9089-olarila-big-sur-vanilla-image-usb-installation/page/4/?tab=comments#comment-111666
