7 hours ago, oldman20 said:
sr, i dont know what's your mean, sir?
idk = i don't know xD
4 hours ago, Kankon said:
by the way , I have something  wrong when I turn to Windows , the sound not working when the.  flag bot set to EFI
if u need boot to windows use a boot key, opencore for now don't drop quirks and edited tables
if u need boot to windows with opencore, u need use a not full solution, ssdts with darwin properties
  • Haha 1
what about update beta 2 ,  is there any problem or need new EFI
Motherboard Asus TUF Z390-PLUS GAMING (WI-FI) CPU 3.6 GHz 8-Core Intel Core i5, Ram 32 GB 3000 MHz DDR4, Graphics : AMD Radeon RX 6700 XT 12 GB OS:MacOS Tahoe 26.0 RC (25A353) SERIE 30, 40 (COOFFELAKE / COMETLAKE
same. just update kexts and bootloader. just replace files in ur folder
Does the recovery mode already work in the Big Sur Beta2 ?
I have the Recovery option in the OC but click on
only a black picture appears on it, then the OC boot menu comes back. I wanted to
Run csrutil authenticated-root disable for more access to Big Sur.
Thank you for help.
Edited by fritz122
46 minutes ago, osxi7 said:
I would appreciate if you could take a look at my config
some times first try dont work. is a bug i think
try again
not for now
My Friend @MaLd0n can you say me musst remove this: # after install now in my System, is as install from USB to SSD ok.
Do you have an idea how to get more access rights in Big Sur? which value is best in csr-active-config ? 7709000 or 77080000 or other?
And are there more options when you log in as root?
Bild111.zip
Edited by fritz122
1 hour ago, fritz122 said:
77080000
need wait a full solution. need recovery mode now
7708000 is we befor  wih another numbers. csr-active-config status = enabled ! work not. is not disabled.
need we you say recover Mode for deactivated.
Edited by fritz122
5 hours ago, Richard Milciades Agramonte Santiago said:
I send you my EFI folder please take a look, and the photo of the error.
dont have solution for all, need wait
24 minutes ago, osxi7 said:
Anyone help for install of big sur on 390z asrock coffee lake
same folder work
doesnt work here tried over night install tried to install all of today, no luck stuck at boot
any members have a 390 motherboard willing to share config plist to help a fellow hackintosher if people loose heart members will drop away and apple will have won
is this what we want to happen or do we work together to help each other in our hobby
my EFI needs Help
  • Haha 1
Thank you for help.
Boot from BS USB Installer and do the process. Works like a charm.
AMD Ryzen 9 3900X
ASUS ROG STRIX X570-E GAMING
Sapphire Nitro+ Radeon RX 590 8GB
CORSAIR Vengeance LPX 32GB DDR4 3600Mhz
Why u don't install from pen drive (USB). u can't rename partition or try:
Quote
sudo diskutil rename "Test" "macOS Big Sur"
Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
Hello @MaLd0n . I read the following in the read me of airportbrcmfixup GitHub:
Remove injectors for AirPortBrcm4360 and AirPortBrcmNIC from main Info.plist and move them into separate plugins AirPortBrcm4360_Injector and AirPortBrcmNIC_Injector (kexts with plist only).
Under 10.16 (Big Sur) plugin AirPortBrcm4360_Injector.kext must be blocked by MaxKernel 19.9.9 or just removed, otherwise it will block loading of AirPortBrcmNIC since class AirPortBrcm4360 is unsupported.
My question is how I block the injector by MaxKernel 19.9.9 in the config file kernel section? I was looking for some examples but couldn’t find one.
i will testing this in next time. Thank you.
Never mind @MaLd0n. After reading another thread I realized that I just needed to explicitly include the two new plugins of updated AirportBrcmFixup kext, which I did in addition to include your DSDT. I booted again but still no working WiFi. Attached are the zipped screenshot and kext. Could you please advise if I did something wrong?
AirportBrcmFixup.kext.kext.zip IMG_4611.zip
