1 minute ago, Kaoman said:
what quirks should i use? should i upload my config file?
check here
https://opencore.slowgeek.com/
22 minutes ago, Kaoman said:
sorry to bother you again but im getting the same error ?
i need discovery what cause it ;)
my specs are i5 10400
gigabyte vision g z490
16gb ram 3600
is it cuz of the cpu or something?
lemme know if you want the config file
On 7/25/2020 at 4:29 PM, MaLd0n said:
beta 3 is a shot in the dark. for me work with efi premade
Define premade EFI please? Installed on the target drive or the install USB for this premade EFI? Reason I ask is because beta 3 installs fine on my SSD and works, but the moment I try to install it on my production nvme drive it will NOT install at all. The target nvme drive never shows itself in the opencore bootloader...Thanks!
New build ASRock Z390 Phantom Gaming 9 i9-9900K MSI RX580 8GB Big Sur 11.0.1 32GB DDR4
First build ASRock Z270 Gaming K6 i7-7700K MSI RX580 8GB Mojave 10.14.6 32GB DDR4
1 hour ago, Kaoman said:
if yes can you share your efi please
use my folder for z490 vision d and update things for big sur
https://easyupload.io/f4l0ws
u just need a full dsdt patched after that
1 hour ago, rocky_mtn said:
big sur is a shot in the dar for now
ok thank you! it works now finally lol i just need a little help getting it to restart and shutdown properly. also is there a way to update it? when i try to load the updater it hangs on the same dbstart:log
I hear you, but I’ve got it running beta 2. You said you were able to run beta 3 with the “premade efi”. Can you point me in the direction of this premade efi? Beta 3 doesn’t seem to want to install on my nvme drive for some reason, the installer breaks the beta 2 install trying to update to beta 3 from system prefs, or from usb through opencore. I’d really like to get on beta 3 for the fixes. Thanks in advance.
in my mobile fail, desktop work fine
many work these days, no time for check. i'll try tomorrow
5 hours ago, joostiphone said:
@MaLd0n
Do you have more advise?
no
  • Haha 1
On 7/27/2020 at 2:42 PM, joostiphone said:
@MaLd0n  I've successfully installed Big Sur beta 2 with Opencore 0.6.0 but I now want to upgrade to beta 3. When booting using the installer it gives me the following message and won't continue (no matter how long I wait). See attachment.
Please note that I don't have a Thunderbolt Display if that is relevant to mention.
Thunderbolt 255 PCI - LS=0x7043 LC=0x0040 SS=0x0140 SC=0x0008 PMCSR=0x0000 RT=0xffffffff NLRT=0xffffffff LWRT=0xffffffff PRRT=0xffffffff TRT=0x0000 TNLRT=0x0000 TLWRT=0x0000 TPRRT=0x0000 TLUP=0x0001
Hopefully you can provide some suggestions.
I fixed it by doing as follows:
- Mount EFI
- go to folder OC -> and open config.plist with PlistEdit Pro.app
- Unfold "NVRAM, Add, 7c43...." and add "vsmcgen=1" to boot-args.
See attached a screenshot. ?
vsmcgen.png.zip
Hello Maldon,
Asus Z390
am make new restor ur Big Sur then upgrade it to last beta 3 now work very well I think but the sound not working.. Please can I get the last update EFI
http://s000.tinyupload.com/index.php?file_id=49153581154433256576
Motherboard Asus TUF Z390-PLUS GAMING (WI-FI) CPU 3.6 GHz 8-Core Intel Core i5, Ram 32 GB 3000 MHz DDR4, Graphics : AMD Radeon RX 6700 XT 12 GB OS:MacOS Tahoe 26.0 RC (25A353) SERIE 30, 40 (COOFFELAKE / COMETLAKE
58 minutes ago, Kankon said:
Hello Maldon,
use alcid=1
52 minutes ago, Kankon said:
work , thanks
Enjoy!
Thank you kind sir. I just really want to get to the bottom of why I can't install beta 3 on my nvme drive. I really appreciate you letting me know if you're able to get beta 3 on your z390 board with an nvme. ? No rush, just bothers me to no end when I can't get something working and I think I should be on beta 3 if its out, not 2.
thanks! I have problems with boot , boot came to a point after PCI check and Tham crushed and restart...would you please check the log?
a00:000 00:000 AAPL: [EB|#LOG:INIT] 2020-08-01T21:06:54
00:069 00:069 AAPL: [EB|`CFG:DEV] { 0x3
00:108 00:039 AAPL: [EB|`CFG:DEV] Err(0xE) @ GV booter-preboot-kernel
00:141 00:032 AAPL: [EB|`CFG:DEV] Err(0xE) @ GV booter-fileset-basesystem
00:173 00:032 AAPL: [EB|`CFG:DEV] } 0x3
00:206 00:032 AAPL: [EB|#VERSION] bootbase.efi 491~173 (Official), built 2020-06-06T05:45:48-0700
00:238 00:032 AAPL: [EB|#BUILD] BUILD-INFO[298]:{"DisplayName":"bootbase.efi","DisplayVersion":"491~173","RecordUuid":"00CE88A2-7D76-4269-B50E-68A89A28FF4E","BuildTime":"2020-06-06T05:45:48-0700","ProjectName":"efiboot","ProductName":"bootbase.efi","SourceVersion":"491","BuildVersion":"173","BuildConfiguration":"Release","BuildType":"Official"}
00:271 00:032 AAPL: [EB|#H:IS] 0
00:304 00:032 AAPL: [EB|#WL:MODE] 0
00:336 00:032 AAPL: [EB|#CONFIG:SRC] <default>
00:368 00:032 AAPL: [EB|#CONFIG| 0] boot-save-log : 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) <default>
00:401 00:032 AAPL: [EB|#CONFIG| 1] wake-save-log : 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) <default>
00:433 00:032 AAPL: [EB|#CONFIG| 2] console       : 0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) <default>
00:466 00:032 AAPL: [EB|#CONFIG| 3] serial        : 0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) <default>
00:498 00:031 AAPL: [EB|#CONFIG| 4] embed-log-dt  : 0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) <default>
00:530 00:032 AAPL: [EB|#CONFIG| 5] timestamps    : 0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) <default>
00:562 00:031 AAPL: [EB|#CONFIG| 6] log-level     : 0x0000000000000001 (0x0000000000000001 & 0x0000000000000021) <default>
00:594 00:031 AAPL: [EB|#CONFIG| 7] breakpoint    : 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) <default>
00:626 00:032 AAPL: [EB|#CONFIG| 8] kc-read-size  : 0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) <default>
00:658 00:031 AAPL: [EB|#H:IS] 0
00:689 00:031 AAPL: [EB|#WL|0] 0x01 0x01   0 0x00
00:722 00:032 AAPL: [EB|#BRD:NV] Mac-7BA5B2D9E42DDD94
00:755 00:032 AAPL: [EB|#WL|1] 0x01 0x01   2 0x00
00:787 00:032 AAPL: [EB|`BST:IDT] {
00:820 00:032 AAPL: [EB|`BST:IDT] }
00:853 00:032 AAPL: [EB|#WL|2] 0x01 0x01   3 0x00
00:885 00:032 AAPL: [EB|#WL|3] 0x01 0x01   4 0x00
00:918 00:032 AAPL: [EB|#BRD:NV] Mac-7BA5B2D9E42DDD94
00:950 00:032 AAPL: [EB|#WL|4] 0x01 0x01   5 0x00
00:983 00:032 AAPL: [EB|`H:CHK] BM: 0x0000000000000000
01:016 00:032 AAPL: [EB|`H:LV] Err(0xE) @ GV boot-signature
01:048 00:032 AAPL: [EB|#WL|5] 0x01 0x01  23 0x0E
01:080 00:032 AAPL: [EB|`H:LV] Err(0xE) @ GV boot-image-key
01:112 00:031 AAPL: [EB|#WL|6] 0x01 0x01  24 0x0E
01:145 00:032 AAPL: [EB|`H:LV] Err(0xE) at GV? boot-image
01:177 00:032 AAPL: [EB|`H:LV] Err(0xE) @ SV- boot-signature
01:210 00:032 AAPL: [EB|`H:LV] Err(0xE) @ SV- boot-image-key
01:243 00:032 AAPL: [EB|`H:LV] Err(0xE) @ SV- boot-image
01:275 00:032 AAPL: [EB|#H:NOT]
01:307 00:032 AAPL: [EB|`SB:EN] Err(0xE) @ LocP 24B73556-2197-4702-82A8-3E1337DAFBF2
01:342 00:035 AAPL: [EB|#LIMG:DP] Acpi(PNP0A03,0)/Pci(14|0)/Usb(A, 0)/HD(Part2,Sig1A4DC33A-1003-40C4-BB2A-15547B2EF9BD)
01:375 00:032 AAPL: [EB|#LIMG:FP] \System\Library\CoreServices\boot.efi
01:408 00:033 AAPL: [EB|#LIMG:OPT] ()
01:441 00:033 AAPL: [EB|#RPS] R?0 P?0 S?0
01:478 00:036 AAPL: [EB|`OPT:LXF] 'LF (\\System\\Library\\CoreServices\\com.apple.Boot.plist)
01:508 00:030 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: \\System\\Library\\CoreServices\\com.apple.Boot.plist, DP: 0
01:541 00:032 AAPL: [EB|`LD:OFS] Err(0xE) @ OPEN (\\System\\Library\\CoreServices\\com.apple.Boot.plist)
01:574 00:032 AAPL: [EB|`OPT:LXF] Err(0xE) @ 'LF
01:606 00:032 AAPL: [EB|`OPT:LXF] 'LF (Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist)
01:639 00:032 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist, DP: 0
01:676 00:036 AAPL: [EB:#KF] (root-dmg=file:///BaseSystem/BaseSystem.dmg)
01:706 00:030 AAPL: [EB|#MBA:CL] ()
01:739 00:032 AAPL: [EB|#MBA:NV] (-v vsmcgen=1 keepsyms=1 debug=0x100 npci=0x2000 alcid=3 slide=206)
01:772 00:032 AAPL: [EB|#MBA:KF] (root-dmg=file:///BaseSystem/BaseSystem.dmg)
01:804 00:031 AAPL: [EB|#MBA:OUT] (-v vsmcgen=1 keepsyms=1 debug=0x100 npci=0x2000 alcid=3 slide=206 root-dmg=file:///BaseSystem/BaseSystem.dmg)
01:836 00:032 AAPL: [EB|#LOG:VERBOSE] 2020-08-01T21:06:56
01:869 00:032 AAPL: [EB|`CSR:S] csr-active-config = 0x00000067
01:901 00:032 AAPL: [EB|#OPT:BM] 0x4082
01:933 00:032 AAPL: [EB|`OPT:LXF] 'LF (\\System\\Library\\CoreServices\\PlatformSupport.plist)
01:966 00:032 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: \\System\\Library\\CoreServices\\PlatformSupport.plist, DP: 0
02:003 00:037 AAPL: [EB|#B:VAw]
02:033 00:029 AAPL: [EB|`P:DCCPR] Err(0xE) @ GV AAPL,CoProcessorReboot
02:112 00:079 AAPL: [EB|#P:MPI] N
02:144 00:032 AAPL: [EB|`CS:CSKSD] {
02:215 00:071 AAPL: [EB|`CS:CSKSD] Err(0xE) @ GV 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF:boot-info-payload
02:248 00:032 AAPL: [EB|`G:CS] } Ok(0)
02:281 00:033 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: <null string>, DP: 1
02:333 00:052 AAPL: [EB|`B:SBS] SZ: 657976
02:369 00:036 AAPL: [EB|#B:SHA] ab805758fd26e265a69f1c33f3bd11bc87ca9bcf
02:402 00:033 AAPL: [EB|`WL:PWLFNV] Err(0xE) @ GV wake-failure
02:435 00:032 AAPL: [EB|`WL:DT] Err(0xE) @ WL:PWLFNV
02:468 00:032 AAPL: [EB|`WL:PWLFRTC] ! @ RTC:R
02:501 00:032 AAPL: [EB|`WL:DT] Err(0xE) @ WL:PWLFRTC
02:534 00:032 AAPL: [EB|`LD:LKC] BPDK -> (System\Library\KernelCollections\BootKernelExtensions.kc.development)
02:567 00:033 AAPL: [EB|`LD:OFS] Err(0xE) @ OPEN (System\\Library\\KernelCollections\\BootKernelExtensions.kc.development)
02:601 00:033 AAPL: [EB|`LD:LKC] BPDK,!R -> (System\Library\KernelCollections\BootKernelExtensions.kc)
04:943 02:342 AAPL: [EB|`LD:LKFS] } Ok(0)
04:972 00:029 AAPL: [EB|`LD:LKC] } Ok(0)
05:005 00:032 AAPL: [EB|#FWFM] 0xFF9FFF3F
05:037 00:032 AAPL: [EB|#FWFT] 0xFD8FF53E
05:069 00:032 AAPL: [EB|#BST:REV1]
05:102 00:032 AAPL: [EB|#CSR:OUT] 0x00000067
05:139 00:036 AAPL: [EB|`BST:FBS] {
05:170 00:031 AAPL: [EB|`BST:FBS] BA.ADSZ: 0
05:203 00:032 AAPL: [EB|`BST:FBS] BA.KSDSZ: 0
05:235 00:032 AAPL: [EB|#SB:SBGMFNS] (x86legacyap.im4m)
05:268 00:033 AAPL: [EB|#RH:PF] (usr\\standalone\\OS.dmg.root_hash)
05:301 00:032 AAPL: [EB|#RH:MF] (usr\\standalone\\OS.dmg.root_hash.x86legacyap.im4m)
05:334 00:033 AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: usr\\standalone\\OS.dmg.root_hash, DP: 0
05:367 00:032 AAPL: [EB|`LD:OFS] Err(0xE) @ OPEN (usr\\standalone\\OS.dmg.root_hash)
05:400 00:032 AAPL: [EB|`RH:LRH] Err(0xE) @ LF (P)
05:432 00:032 AAPL: [EB|`BST:FBS] Err(0xE) @ PBARVRH
05:466 00:033 AAPL: [EB|`B:WFDW] Err(0xE), 0 @ LocHB 71B4903C-14EC-42C4-BDC6-CE1449930E49
05:497 00:031 AAPL: [EB|#LOG:DT] 2020-08-01T21:07:00
05:530 00:032 AAPL: [EB|#LOG:EXITBS:START] 2020-08-01T21:07:00
what ur hardware?
  • Asus X99-M WS / 12-Core Xeon E5-2670 v3 / HyperX 64GB 2400MHZ DDR4 / Asus Radeon VII
I am getting "AppleNVME assert failed error" no matter which EFI folder I'm using, basically I cloned my MBP (as always) and try to boot from, currently Catalina  is working like that (internal SSD) but now I can't figure out what is the problem.
Thanks Maldon!
device ec injected?
