21 hours ago, Emmanuel Nevil said:
I wanted to know can I change the System settings from imac pro 2017
You can do that by changing your SMBIOS (SystemProductName and other related variables, like SystemSerialNumberMLB, BID, etc.) in your config.plist (use PlistEdit Pro and edit those keys in Root/PlatformInfo/Generic and Root/PlatformInfo/PlatformNVRAM). The correct values that refers to MacPro you can check on Clover Configurator (use it just to see the values that you'll replace in PlistEdit Pro). If u have no idea of how to do this, I suggest u read this guide: https://www.olarila.com/topic/8918-opencore-vanilla-guide-step-by-step-full-dsdt-patched-or-ssdt/
20 hours ago, Emmanuel Nevil said:
Can I change hard disk name from Test to Something else?
I don't think so (insufficient privileges).
Thanks a lot! Big Sur is taking a hell lot of time! Booting time can be adjusted but after that it takes a lot to bring up the doc. then takes a whole bunch of time to respond and then it takes time to even open up finder, folders. But after a while everything becomes fast! Do you know what is the reason? Will it be the EFI i used the pre-made EFI from here.
Can someone help with the booting and startup time. Anyone know the reason???
u need start a fine tune
Did not understand you brother. Start a Fine tune means???
Does it mean I need to play around and make changes in the EFI?
COPY PASTING MY EXACT PROBLEM: [PLEASE HELP]  It would mean the World to me.
So I have installed Big Sur recently and it takes a hell lot of time to boot. It. takes a long time with the codes and the apple logo and the I get the lock-screen entering there sometimes I get to see the wallpaper or sometimes it's black. Then it takes a long time to bring up my folders and stuff. I try to go click about the mac, it never comes up. Then I will try to open the finder it too takes time. I would open safari or any app it takes a lot of time. But after all this is done and I have used the system for while then its superb fast. Apps open up so damn fast, Rendering, FCPX, Android Studio everything.
BUT why is it taking time at the start??? I used a pre made EFI that I got from a guide that helped me to install BIG SUR! Will that be the reason?? Can someone please help I'm stuck here. I don't know why this is happening.
Please don't tell me this is because of the BETA version as I had the same Issue with Sierra. And I have seen Big Sur booting soo quick in several systems. Please help if you know what to do...
Thanks XD
On 6/28/2020 at 9:36 AM, kevin0007 said:
Hi, @MaLd0n thanks for your tutorial...I did same as you mentioned in your post..I used your provided efi without any modification but at first boot I got kernel panic
Did you resolved the issue ?
I am also trying to make the install on the deskmini 110 with a 6700k.
@MaLd0n any tips on getting past this ?
Edited by shremi
all kexts and bootloader is up to date?
Hey!
I get after I start OC this message:
OCS: No schema for BlacklistAppleUpdate at 3 index, context <Security>!
And when I boot BigSur I get this error symbol :(
I Have done everything from your tutorial twice!
 But Thank everyone for the help!
EDIT: Added my EFI folder
https://www.file-upload.net/download-14180403/EFI.zip.html
Another question:
How can I update to beta 2? Can I just install it normally from the Settings like on a real Mac?
Edited by iMonZ
remove it from Misc tab. 0.6 dont have more this option
  • Thanks 1
Thank you!
error is gone and BigSur booted successful!
any news on the beta 2 update?
just update
Okay I try that!
my last question
i know I had a lot of question now but do you know if FileVault is working properly?
19 minutes ago, MaLd0n said:
just update
yes
Bom Dia @ MaLd0n, consegui instalar o BS, parabens pelo belo trabalho!
Dell Inspiron 3543-A30, i5 5200u, ssd120, 8gb ram, hd5500, (versão A11 da BIOS)
use sua pasta BigSur Haswell, faça o download de uma imagem e via perfil beta, e transfira pelo terminal para pen drive, e adicione uma pasta efi OC ?
adcionei meus gráficos, smbios, dsdt, ssdt, tudo funciona bem menos meu WFI DW1550, estou lendo muitas coisas nos fóruns de pré-lançamentos, mas ainda não consegui alterar o SIP, para que eu tente instalar um IO80211family.kext do catálogo, ou talvez adcionar os plugins a IO80211family.kext do BigSur.
vou deixar minha efi para quem está com problemas se quiser testar a vontade, caso contrário DSDT e SSDT-UIAC .... caso seu laptop não seja idêntico ao meu!
https://drive.google.com/file/d/1J3NpqeiNUU8eoZuUOWeJHh853QSZdd5q/view?usp=sharing
Edited by Lfbs
erro de escrita
Hi, i restored Olarila Big Sur to HDD, but inside like this, i thing it's wrong?
And OC 0.5.9 cant boot into it
Here my config.plist (This OC can boot with 10.15.4 fine)
config.plist.zip
Hi, im Dell 3543 too, but cant open your config in propertree
