Ola MaLd0n gostaria de executar o BigSur em um hd interno existe alguma pocibilidade?
Identificador do modelo: iMacPro1,1
Placa Mãe: Asus TUF Z390-PLUS GAMING (WI-FI)
conjunto de chips: Intel Z390
Memoria RAM: 1x16 GB Corsair 3000 MHz DDR4
Processador: Intel Core i7-8700K 3.70GHz
Placa de Video: Sapphire Radeon RX 590 NITRO+ Special Edition Dual, 8GB
Wireless/Bluetooth: BCM943602CS 16000Mbps 802.11AC
5 hours ago, moviemakergr said:
Thanks again..  :superman
if u use this dsdt, remove ssdt olarila
add alcid=7 in nvram
add -lilubetaall
4 hours ago, Frankovich said:
Same here:
try with fakesmc instead
3 hours ago, JhoonCollins said:
tentei fazer a restauração ocorreu td bem, mas na hora de dar boot aparece esse erro
tem de liberar o arquivo
sim. eu restaurei várias vezes
  • Thanks 1
11 minutes ago, JhoonCollins said:
como faço pra liberar o arquivo?
no google drive
18 minutes ago, JhoonCollins said:
aah entendi,upei no mediafire,vc consegue ver agora?
tá usando o dsdt full ou pelo menos uma ssdt pra injetar o básico?
então to usando a ssdt que esta na pasta efi que vc disponibilizou no começo do post, mas tenho uma dsdt que vc fez que uso quando uso o clover pode colocar ela na pasta do opencore tbm junto com a ssdt?
nem sempre
Finally I was able to make the installation.
I am getting constant flickering on my screen it also happens on Catalina I don't have a personal DSDt or anything at all.
I am attaching the file maybe Maldon can help.
https://we.tl/t-aMW4sZqZeZ
Same here
MacPro7,1: Huananzhi 2.49pb | Intel Xeon E5-2690 v1 | 64 GB RAM | Gigabyte RX 590 | Opencore 0.6.5 | KingSpec NVMe SSD (Big Sur 11.1) | Samsung SSD 860 EVO (Windows 10) | Fenvi T919 (BCM94360CD) | Apple Magic Keyboard 2 | Apple Magic Trackpad 2
@MaLd0n
Thanks for refinement to my DSDT. It's working fine under Big Sur but I've annoying problem. If I open Terminal for the first time, it works normal but when I quit and reopen Terminal, it behaves like TextEditor. I mean there's no way to type command. I also noticed that I can't shutdown the system and Control Setting hangs during 3 - 5 seconds. Any tips will be appreciated.
OpenCore option appear but I can't boot into Test, it stops! I'm adding the picture for reference.
Error Image .zip
My System: CPU:
i7 8700 CPU 3.20Ghz
Mother Board: Gigabyte Z370M D3H
Graphics: Rx 580
I'm using an older version of open core. Will that be a problem. I don't know how to upgrade to the latest one. Can someone help me with that please?
Here is my EFI Please HELP
https://drive.google.com/drive/folders/14EnFTYA4mD0TLoYJ1t7ULdxDwojSbLTb?usp=sharing
remove ssdt
59 minutes ago, gaule said:
bugs. need wait next betas ;)
use my efi premade
3 hours ago, MaLd0n said:
remove ssdt
use my efi premade
Thanks I used you EFI and it did the trick! I'm feeling the Mac is a bit too slow at startup than my previous EFI. Also the volume wifi toggles don't respond well, Is it because of Beta version of BIG SUR?? Its a bit laggy when I click the buttons. Catalina on the other side is a bit laggy but not as compared to BIG SUR.
One more question... Can I change the products name iMac Pro(2017) to something new. What should I do to change that in you EFI??
Can't I make it like MacPro the latest one? Thanks xD!!
remove ssdt
use my efi premade
One more thing mate!! I have Catalina and Big Sur on the same partition and when I try to partition down some space from the Catalina, I was able to do so. But the new created volume can't be added to Big Sur partition. Why??
It shows untitled and gives a message it would wipe everything off!! What Should I do?? I have tonnes of extra space on the other partition. Please help me with this too... Thanks
Olá estou com esse erro de apfs e não consigo resolver.
IMG_0890.JPG.zip
IMG_0894.JPG.zip
Edited by talmazi
esse erro é causado pelo _sta no rtc ou a falta do device EC
Brother could you reply to my comments that I have mentioned above? Please?
Edited by Emmanuel Nevil
is a beta system. have several bugs
