27 minutes ago, Paul ViPiMP said:
I got evrytime a USB enumeration Error from the AppleUSBHost.
Just now, Benjamin Ceniza said:
Does anybody have EFI OC for ASUS H97m-E/csm. I am running Catalina flawlessly with Clover 5119 and would like to migrate to OC.
3 hours ago, Paul ViPiMP said:
USB Enumeration Error
check if work, remove ssdt
2 hours ago, Kankon said:
use it, reboot and extract one ioreg for me
http://s000.tinyupload.com/index.php?file_id=80013888162961816941
2 hours ago, rudy33 said:
Are the premade efi is suitable to laptop or I need to make new one?
1 hour ago, juniorairton said:
Worked like a charm.
Enjoy!
5 hours ago, MaLd0n said:
deixe me ver a sua pasta efi
same thing
my folder Vision. add things for Big Sur form first post
https://easyupload.io/x98sks
You are my HERO !! (for many times)
Thanks Thanks Thanks. !!!
Works like charm !
(but we have some differences on PCI section)
Edited by moviemakergr
27 minutes ago, longcoming said:
A fine tune would be very appreciated.
Archive.zip
full solution only via dsdt. ssdt is good, but is not a complete solution
  • Like 2
2 minutes ago, moviemakergr said:
Thanks again we fix it on the final version (is not Necessary this time ) :)
Enjoy!
1- Download this .dmg and put in your desktop
Link 1- https://tinyurl.com/ybttsz94
Link 2 - https://tinyurl.com/ydxme7jl
All Credits to vit9696 and Vandroiy
Can you upload file to another cloud,I'm download from google drive interrupt . only 70% or 90% or error:
Sorry, you can't view or download this file at this time.
Too many users have viewed or downloaded this file recently. Please try accessing the file again later. If the file you are trying to access is particularly large or is shared with many people, it may take up to 24 hours to be able to view or download the file. If you still can't access a file after 24 hours, contact your domain administrator.
Edited by HUYNH ANH
MSI B450 TOMAHAWK MAX, RYZEN R5 3600, MSI RX 5500 XT, WIFI BCM94360cs2 , MacOS 10.16 Beta 9, Opencore 0.6.2
