Donation with BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
Donation with PicPay @danielnmaldonado
Donation with Mercado Livre https://tinyurl.com/y9evkj5u
--Big Sur Beta 5 Restore Tutorial--
https://tinyurl.com/yxhhaf7e
--OpenCore Vanilla Video Guide--
https://tinyurl.com/yyfa7mfa
--OpenCore Vanilla Guide--
https://tinyurl.com/ycvcnp8h
--Full Solution with good fine tune you need post your files, check video and run this app bellow--
Download RunMe.app - https://tinyurl.com/y9562hz7
Let's start
System password is 1234
Work in internal or external HDD/SSD / Don't restore to your Mojave/Catalina macOs SSD
1- Download this .dmg and put in your desktop
Link 1- https://tinyurl.com/ybttsz94
Link 2 - https://tinyurl.com/ydxme7jl
All Credits to vit9696 and Vandroiy
2- Open terminal and mount .dmg
-Run in terminal-
hdid -nomount "/Users/olarila.com/Desktop/macOS_11.dmg"
*change user*
3- Check disks with diskutil list in terminal
***Pay attention, you need restore partition that has EFI partition and 120gb, check image below***
-Run in terminal-
diskutil list
In my case .dmg mounted is disk5 and my NVME is disk1
*mounted .dmg have 120 gb*
4- Unmount Disk
*Make changes according to the result in the terminal*
-Run in terminal-
diskutil unmountDisk /dev/disk1
5- Restore
Restore from disk5 to disk1
-Run in terminal-
sudo dd if=/dev/disk5 of=/dev/disk1 bs=32m
with ctrl + t you can check progress
Restore is done.
Download last release OpenCore and Kexts
--OC vanilla Application--
https://www.olarila.com/topic/10371-oc-vanilla/
Premade EFI Folder Serie 100/200/300/400
https://tinyurl.com/ybr968w3
*in some cases we need uncheck DevirtualiseMmio in Booter/Quirks*
Boot into system and enjoy!
Resize Disk After restore Thanks to Pavo
To resize the physical disk of BigSur when using this method
*Identify the physical disk
diskutil list
*repair the physical disk partition
sudo diskutil repairDisk diskX
*Resize the physical disk container volume
sudo diskutil apfs resizeContainer diskXs2 0
Credits/Thanks: Acidanthera Team, Apple
  • Like 6
  • Thanks 6
You are the Man, MaLdon ??
Thanks!!!
Gigabyte Aorus Z790 Elite AX / Raptor Lake 13th Intel® Core™  13900K / AMD AORUS RX 6900 XT  2 rev. / Lenovo E470 i5-7200-U Kaby Lake iGPU intel HD620 64 GB Ram / ASUS Prime B365M-K Desktop intel i3-Coffe Lake / ASUS Sapphire Nitro+ AMD RX 580 4GB / Gigabyte B360 i5-Coffe Lake / RX 64 Vega OC Gigabyte / Gigabyte B660 Raptor Lake 13th Intel® Core™ i7-13700K  / Nvidia GeForce GTX 3060 Gainward 12GB /  Gigabyte Z170 XP SLi  Intel® Core™ i7  iGPU /  Mac mini M4 Pro 12/16  24 GB Ram  512 GB Nvme /   MacBook Air 2020 10th Ice Lake Intel® Quad-Core™ i7-1060NG7 T2  Iris Plus Graphics  /  Clover Hacky Color 5161  / Opencore 1.0.4 /  God Bless you!
:guitar
2 minutes ago, JhoonCollins said:
If I do this tutorial it will erase all of the data of my ssd? or can i resize the ssd and install on one of the partitions?
the best is one ssd for it, avoid problems ;)
but i think dis0s1 for example u can in partition
10 minutes ago, flash1234654 said:
em processadores 3a geração vai rolar?
veja se tem o suporte
Maybe you can check this:
Pavo said about resize partition:
To resize the physical disk of BigSur when using the img dd method
*Identify the physical disk you dd the img to X is example
diskutil list
https://www.insanelymac.com/forum/topic/344236-pre-release-macos-big-sur/?do=findComment&comment=2727150
36 minutes ago, WindAngel said:
Can i install this .dmg file on Ryzen 5 3500X?
this guy update patches for amd
patches.AMD BIGSUR.zip
Credits
  • AlGrey for the idea and creating the patches.
  • XLNC for maintaining patches to various macOS versions.
  • Sinetek, Andy Vandijck, spakk, Bronya, Tora Chi Yo, Shaneee and many others for sharing their AMD/XNU kernel knowledge
  • 0xD81CF, doesprintfwork and erikjara for readme translations.
  • Thanks 1
Hacks:
Main:
Gigabyte Z390 Gaming X  - Intel i5 9400F - 16 GB DDR4 2666 - Radeon RX 570 4GB - Tahoe 26.0.1
Backup: Gigabyte EP-45-UD3R - Intel Core2Quad 9550 @4.0Ghz - 8 GB DDR2 - GeForce 9800GT - Sierra
31 minutes ago, Carlos Matos said:
My OC 0.5.9 that work in my machine More two options go work? or need be the 6.0?
need compile last, check first post, have a easy way for it
8 minutes ago, asapreta said:
show
Eu vou precisar ver como usa o OpenCore, testar no meu CAtalina e depois ver como seria esse BigSur no meu setup.
Hacks:
Main:
  • Thanks 1
39 minutes ago, nvanh1804 said:
Does it work with Ivy Bridge???
try
-no_compat_check stay work
10 minutes ago, bigbotijao said:
Isso serve pra instalar o Mac Big Sur? Opencore atualizou? é só fazer isso @MaLd0n ? e isso eu faço dentro do Catalina que ja tenho aqui? nunca usei opencore
teste em outro hd
4 minutes ago, MaLd0n said:
teste em outro hd
Então isso ainda não é o hackintosh? no meu caso eu não tenho o outro SSD, so o que eu uso, consigo bootar mesmo assim ?
