Easy Brightness Hotkey Remapping on hackintosh
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
Let's Start
Download Maciasl from HERE
Download Lilu and WhateverGreen
1- Apply PNLF Patch or use SSDT PNLF
 PNLF for Sandy Bridge / Ivy Bridge / Haswell / Broadwell / Sky Lake / Kaby Lake processors
SSDT PNLF-KABY-.aml.zip
DSDT patch
into_all device label PNLF remove_entry;
into scope label _SB insert
begin
Device (PNLF)\n
        {\n
            Name (_HID, EisaId ("APP0002"))  // _HID: Hardware ID\n
            Name (_CID, "backlight")  // _CID: Compatible ID\n
            Name (_UID, 0x10)  // _UID: Unique ID\n
            Name (_STA, 0x0B)  // _STA: Status\n
        }\n
end
PNLF for Coffe Lake / Whiskey Lake / Comet Lake / Ice Lake processors
SSDT  PNLF-COFFEE+.aml.zip
DSDT patch
begin
Device (PNLF)\n
        {\n
            Name (_UID, 0x13)  // _UID: Unique ID\n
        }\n
end
2- Brightness Keys
Use BrightnessKeys.kext for automatic handling of brightness keys based on ACPI Specification
On some Laptops, may be required ACPI patch _OSI to XOSI and SSDT-XOSI.
-Credits
  • Like 2
7 hours ago, Deihmos said:
How can I do this patch with an SSDT? I am looking for a way to just use SSDTs with OpenCore.
in this case u need use rename
example
_Q11 to _Q1x and inject SSDT with new remap
example
I have made some progress but not there as yet. This is my final issue that I am trying to resolve. The brightness keys should be fn+f3 for up and fn+f2 for down.
I have the renames but the SSDT has an issue. What am I doing wrong?
SSDT-BLCT.dsl DSDT.dsl config.plist.zip
first u need check what methods _Qxx u need rename
check the name of the device ps2 too
I have done that. It is _Q1C and _Q1D  and I have already done the renames. I am not sure what code I need for fn+f2 and fn+f3.
DefinitionBlock("", "SSDT", 2, "hack", "BrightFN", 0)
    External(_SB.PCI0.LPCB.KBD0, DeviceObj)
    External(_SB.PCI0.LPCB.EC0, DeviceObj)
    External(_SB.PCI0.LPCB.EC0.XQ1C, MethodObj)
    External(_SB.PCI0.LPCB.EC0.XQ1D, MethodObj)
    Scope (_SB.PCI0.LPCB.EC0)
        Method (_Q1C, 0, NotSerialized)//down
            If (_OSI ("Darwin"))
                Notify(\_SB.PCI0.LPCB.KBD0, 0x0405)
                Notify(\_SB.PCI0.LPCB.KBD0, 0x20)
            Else
                \_SB.PCI0.LPCB.EC0.XQ1C()
        Method (_Q1D, 0, NotSerialized)//up
                Notify(\_SB.PCI0.LPCB.KBD0, 0x0406)
                Notify(\_SB.PCI0.LPCB.KBD0, 0x10)
            Else
                \_SB.PCI0.LPCB.EC0.XQ1D()
//EOF
Edited by Deihmos
When I press the brightness keys the PC reboots. I did the rename _Q1C to XQ1C and _Q1D to XQ1D. IS that incorrect ? If not, what should it be?
Edited by Deihmos
u have a dual boot?
46 minutes ago, MaLd0n said:
u have a dual boot?
Yes I have a dual boot but just wanted to see if I can get everything working with SSDTs. This is the only thing I have outstanding and I just can't figure it out. Everything else is working fine.
I do have a DSDT that you did.
ye
devs need fix that
I got it done. The code was not correct. Now I have everything working with SSDTs.
I don't use OpenCore for dual boot because I don't want my PC to act like a Mac. Hopefully an option is added to disable it.
if u dont use dual boot why use a incomplete solution provide by SSDT. use full DSDT patched
3 hours ago, lightpower said:
is there a PNLF Patch for comet lake?
update first post. check
I use dual boot. I also have the DSDT but I don't see any difference between using the SSDTs vs DSDT. I get the same results but can dual boot with the SSDTs.
voodoops2 now handles ACPI notification for brightness keys without any patches.
Edited by Deihmos
have many difference. with ssdt the system is always a little slippery
but if u reaaly need dual boot and need boot windows from opencore, use ssdt
i'm using bootkey
Enjoy!
@Deihmos could you please share the ssdt code (and oc renames) that worked for you?
Im trying to do the same thing with SSDT for HP Elitebook 840 G6.
Edited by miki1987
