X1ft Posted June 21, 2020 Posted June 21, 2020 (edited) Hi, My first hackintosh build and I'm struggling to install Catalina and always end up by getting a black screen of death during install... I have tried the following: - Olarila .raw image - Vanilla USB Apple image with both Opencore /Clover from InsanelyMac @glasgood/@AudioGod - Vanilla USB Apple image with Opencore / Clover EFI folder from Olarila None of them seem to work and I get stuck on black screen after a few seconds, can you please assist? Thank you so much! My hardware: MbManufacturer : Gigabyte Technology Co, Ltd. MbModel / MbBiosVersion : Z390 AORUS PRO / F12d Processors : Intel Core i5-9600K CPU @ 3.70GHz RAM : Corsair VENGEANCE LPX 32GB (2x16GB) 3000MHz C16 GPU : PowerColor AMD Radeon RX 5700 HDD1 NVMe M.2 (Windows10) : Samsung SSD 970 EVO 1TB HDD2 NVMe M.2 (MacOS) : Samsung SSD 970 EVO 500GB HDD3 SATA : WesternDigital WD40EZRX-00SPEB0 * Extracted tables from Clover/Acpi/origin boot screen via F4: <Clover/Origins folder> * DSDT tables from RunMe.app on VMware virtual machine: <DSDT fron RunMe.app> Edited June 21, 2020 by X1ft
Administrators MaLd0n Posted June 21, 2020 Administrators Posted June 21, 2020 use this efi https://filebin.net/cfmwo0nmfm6gwsn4/EFI.zip?t=4ptkro22 clear nvram in clover boot screen with F11 key -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
X1ft Posted June 21, 2020 Author Posted June 21, 2020 Valeu Mald0n! copiei o EFI do seu link e limpei a nvram mas acabou por accontecer o ecra negro de novo... Agora a barra de progresso foi um pouco mais longe (mais de metade) mas não deu para chegar ao fim. Como posso ultrapassar este problema? Obrigado!
X1ft Posted June 24, 2020 Author Posted June 24, 2020 Does this EFI contain the DSDT patched for my system? If not can you please post a pathed DSDT table from the files on the first post? Thank you very much!
