Hi,
I have created a new DSDT patch file for this MB, with BIOS 3604.
Patch is based on the patch file that can be found in the DSDT section.
But there are some difference: for instance, the original patch file add somethings under PCI0.
But with the new BIOS they are already defined but not under PCI0.
Is it required to have it under PCI0?
Speedstep is working correctly, I needed to change CPU0 to CPU1, CPU1 to CPU2, and so on..
Anyway, hope than someone can take a look, simple because I'm not an DSDT expert. ;)
Thanks!
P8H67_M_PRO_B3.rar
