3 hours ago, peter217 said:
Olá, voce consegue me ajudar a instalar o bigsur nessas config em anexo, estou com o catalina com clover. mas queria migrar para o opencore. Report
use restore way
https://www.olarila.com/topic/9679-olarila-big-sur-beta-5-vanilla-image-restore-mode-easy-way-opencore/
check booter quirks DevirtualiseMmio and SetupVirtualMap
Hello guys
Im trying to install Catalina on a Haswell CPU(i5-4590s) with integrated graphics (HD 4600), ive tried using dortanias write up on haswell and this write up but I get stuck on the same place, IOConsoleUsers: gIOScreenLockState 3.
at first I though it has de SSDT, I used a program that DUMPs DSDT and SSDT called SSDTTime, it creates three files SSDT-EC, SSDT-HPET, SSDT-PLUG. When that didnt get me to boot I used the SSDT-OLA.aml creating the plist with oc Gen X.
Im using an HP prodesk 400 2.5G, it has an i5 4590s, with HD 4600 graphics, realtek 8111 ethernet card, a sata hard drive and thats it.
I ran my plist through sanity and everything seems to be fine which is why Im starting to think that its SSDT related.
can someone point me in the right direcction? Ive attached my EFI folder and the SSDTs I created with the SSDTTime program.
EFI.zip ACPI.zip
1 hour ago, maldini237 said:
could you please help me to patch my DSDT files?
post one full dump with opencore running
51 minutes ago, Manny Enriquez said:
Hello guys
post one photo in error screen
is a video problem. for now use -igfxvesa, boot into system and create ur video patch
1 hour ago, Marko Sobloher said:
Hello
4 hours ago, maldini237 said:
i will do fresh installation today and try again
this way is just for installation. after that need start a fine tune
1 hour ago, Guillep84 said:
Hi MaLd0n
The dsdt you generated for clover does not work for me with opencore.
Currently I am using this configuration but when I start the screen it remains black but I turn on the power and it turns on
https://filebin.net/jwpu4vuv707ohbn4
thanks.
I generate my own DSDT, for me it works. Have you installed the modded bios? I use OpenCore. Your DSDT is not the same as mine.
Edited by lukakeiton
AMD Ryzen 9 3900X
ASUS ROG STRIX X570-E GAMING
Sapphire Nitro+ Radeon RX 590 8GB
CORSAIR Vengeance LPX 32GB DDR4 3600Mhz
how did you generate your DSDT?
I know you used maciasl, but how you did it?
I have an Asus prime x570 pro
and 3900x + rx580
and 3900x + rx580
You need to extract it with OpenCore or windows, then you have to disassembly it. Then patch it and assembly again. For your specs, DSDT is not needed. If you are interested on Big Sur, take a look on this!
AMD Ryzen 9 3900X
Hello,
I'm booting from usb, since I don't want to lose clover until I have it properly set to opencore.
I know that your dsdt is for your config but I followed the steps to generate my opencore configuration without dsdt but it did not work, it started.
With your configuration it starts and even the webcam works.
What I can do?
Thank you
10 hours ago, Guillep84 said:
Hello,
What I can do?
Thank you
I took a look to your DSDT, it is not patched at all (DSDT is full solution unless bios update). So, you are using SSDTs or Clover config, but I don't use Clover for years. I suggest you if my configuration works for you, use it! Change serial number and add the kexts you need.
AMD Ryzen 9 3900X
