u need extract one sendme with config.plist above
4 hours ago, thangvu.97 said:
Hi. Can you help me with this ssdt. Thank you! My folder contains 12 MB of kext so this a little bit oversize.
config.plist.zip
6 hours ago, thangvu.97 said:
Here you go. Used your config.
Remove ssdt
add voodooi2c kexts
9 hours ago, MaLd0n said:
Remove ssdt
add voodooi2c kexts
I found out some more problems:
- Webcam doesn't work.
- Laptop running pretty hot, i think it due to Nvidia graphic is not disable.
- Trackpad show up in setting  but still doesn't work (i tried uptick the "Ignore built in trackpad..." but no luck), bluetooth still doesn't work.
Thank you!
post one ioreg here
1 hour ago, MaLd0n said:
post one ioreg here
Ok here is your folder : https://drive.google.com/file/d/1pXNtbBAtQaYujGmYRhHQTS7XUQv-GuhW/view?usp=sharing
Let me say my problems agains:
Laptop running pretty hot, i think it due to Nvidia graphic is not disable, or something else.
- Trackpad show up in setting  but still doesn't work (i tried uptick the "Ignore built in trackpad..." but no luck).
- Bluetooth is not working.
Thank you!
On 8/25/2020 at 4:43 PM, huyit69 said:
Hi, I've just got Big Sur Public Beta installed on my new build, graphics and animations are smooth but there are still some errors that I have been wandering around the internet for a few days but not luck. Please help me...
Asrock B460M ITX/ac
Intel Core i3 10100
dGPU: 1050Ti (disable with -wegnoegpu)
iGPU: UHD 630 (iGPU multi monitor enabled in BIOS)
I performed framebuffer patch for the UHD 630 and got graphics run smoothly with UHD 630 detected correctly
However there are some weird problems:
1. Safari web page crashes repeatly and unusable (Chrome and Microsoft Edge works fine)
2. Some app crashes and unusable (OutLook, OneDrive and even Photo)
3. I cannot get Audio worked (tried all of the supported codec with AppleALC), the Audio is ALC887, I got this ALC887 run smoothly on some other motherboards except for this build......audio is not even detected in Hackintool, on hackintool audio tab there is completely nothing.
I followed the above guide and used prebuilt EFI folder for 100.200.300.400 Series with OpenCore 0.6.1
Hi, can you please help me with this config?
https://drive.google.com/file/d/1CcIuYOOpL87tZ39ip0WESvZ45VctYkSO/view?usp=sharing
This include the RunMe dump
Thank you so much, and where can I find the information for sending you some donation?
39 minutes ago, huyit69 said:
Thank you so much, how can I use the aml file that you have already patched?
acpi folder and add entry in ur config.plist
