Hi, so full DSDT patch will make my hackintosh like a real Mac? And would that DSDT patch will defend future updates not to break?
On 8/16/2020 at 4:55 PM, sabertooth said:
try this again
DSDT is a principal bios/uefi table and we applied all patches like apple tables. apple have a very custom dsdt
So you mean you did what apple did with the real macs? Than I guess it doesn’t matter for the macOS update. Though, it’s needed for the system stability.
5 hours ago, sabertooth said:
after I put the DSDT I have a problem with my DVD ROM, it turn on even there is no disk inside
extract new sendme with ioreg
i need sendme with my dsdt load with no ssdts
1 hour ago, sabertooth said:
here go only with your DSDT, no other files involved
test
Enjoy!
15 hours ago, tan hoang son nguyen said:
Please, resent ACPI and kext new for me.
impossible. what is that?
1 hour ago, YuukiRito said:
please, Patch my DSDT
11 hours ago, tan hoang son nguyen said:
Because my laptop was hackintosh but it error touchpad, sleep wake and audio. I can't fix full. Can you help me.
with this folder is impossible
Hi, I've just got Big Sur Public Beta installed on my new build, graphics and animations are smooth but there are still some errors that I have been wandering around the internet for a few days but not luck. Please help me...
Asrock B460M ITX/ac
Intel Core i3 10100
dGPU: 1050Ti (disable with -wegnoegpu)
iGPU: UHD 630 (iGPU multi monitor enabled in BIOS)
I performed framebuffer patch for the UHD 630 and got graphics run smoothly with UHD 630 detected correctly
However there are some weird problems:
1. Safari web page crashes repeatly and unusable (Chrome and Microsoft Edge works fine)
2. Some app crashes and unusable (OutLook, OneDrive and even Photo)
3. I cannot get Audio worked (tried all of the supported codec with AppleALC), the Audio is ALC887, I got this ALC887 run smoothly on some other motherboards except for this build......audio is not even detected in Hackintool, on hackintool audio tab there is completely nothing.
I followed the above guide and used prebuilt EFI folder for 100.200.300.400 Series with OpenCore 0.6.1
Edited by huyit69
Hello maldol i'm so sorry because at the moment i'm so busy with work.Therefore  i can't donate for you with my debit card.I'm from VietNam.Help me with my dell Xps 9370-i78550U opencore valina guide :
+ audio not working ,
+ camera accepted but not working in facetime or video call
Thanks for advanced.I will donate for you right away i received new debitcard.
DSDT.aml
Edited by huyanmay95
update DSDT avoid problems with runme.app
