First of all, thank you for your guide. great job.
I followed your guide and I was able to create the installer USB. However it keeps stopping at the same place. Any ideas where I went wrong? In the OC Sanity Checker I got all the check-marks to turn green, but it seems like something is still missing. My EFI folder is attached.
My setup:
Motherboard: Gigabyte GA-X99-Ultra Gaming (rev. 1.0)
CPU: Intel Core i7 6950X Processor Extreme Edition (Broadwell-E)
Ram: Corsair Dominator Platinum 3200MHz, 64GB
GPU: XFX Radeon RX 580 GTS XXX Edition
EFI.zip
u have a vbios mod?
2 hours ago, tomqsher said:
also my trackpad stopped working after using the config.plist
no idea
11 hours ago, MaLd0n said:
u have a vbios mod?
No, I don’t. Do I need to mod my video card for OC to work? I tried Niresh Catalina, and it worked fine with stock GPU, but a wanted a cleaner and faster boot with your OC method.
xfx is problematic gpu under macos
I took your advice and used a different video card, but it stops at the exact same place with an EVGA card.
What system? big sur?
12 minutes ago, ID Apple said:
Catalina.
try with efi clover folder first
https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/
Thank you. I tried "CHIPSET SERIES 5, 6, 7, 8, 9" (since my processor is Broadwell-E), and it sopped here:
I also tried the "CHIPSET SERIE X99", and it stopped here:
clover?
8 hours ago, tomqsher said:
May I ask what specific things you patched in my DSDT and my config.plist? Thank youuu!
i dont remember. but many. all essentials and apple devices
8 hours ago, thodan36b said:
- Intel Core i5 7400 + Radeon RX470 4G + Ram 8G + SSD 240GB.
enable internal graphics too
28 minutes ago, sabertooth said:
hi Maldon
full solution need ioreg for check devices
9 hours ago, YuukiRito said:
Hi MaLd0n,
