35 minutes ago, imacosiris said:
Hi ACPI Eater
1 hour ago, imacosiris said:
Thanks a lot !!
Just enjoy!
I am trying to make an Opencore bootloader for my Asus x99 pro usb3.1 i7-6800k Msi Radeon RX480. I have followed several guides yet I get stuck on boot at pci configuration begin. in verbose. In the opencore debug txt it sticks at [EB|#LOG:EXITBS:START]. I followed all Dortania troubleshooting and can't get anywhere. I modded BIOS to unlock CFG-Lock
AppleCpuPmCfgLock YES Not needed if CFG-Lockis disabled in the BIOS
AppleXcpmCfgLock YES Not needed if CFG-Lockis disabled in the BIOS
Anyone have any ideas where I can go from here? Thanks johnm
Also the only error I get in sanity check is in Security: BlacklistAppleUpdate was deprecated in OpenCore v0.6.0 - See run-efi-updater under NVRAM instead     I don't seem to be able to find any info to correct this error
I'm attaching my OC config.plist  the debug text, and Sanity check from last attempted boot. Thanks MaLd0n
config.plist.zip opencore-2020-07-29-223158.txt.zip Sanity check.zip
x99 need a pci kext patch
9 minutes ago, jmacie2000@yahoo.com said:
Thank you, Is it a common kext patch, or do I need to read somewhere to find this answer. I appreciate your help.
<dict>
				<key>Comment</key>
				<string>IOPCIFamily Patch</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>SIH7AAAAQA==</data>
				<key>InfoPlistPatch</key>
				<false/>
				<key>MatchOS</key>
				<string>10.13.x</string>
				<key>Name</key>
				<string>com.apple.iokit.IOPCIFamily</string>
				<key>Replace</key>
				<data>SIH7AAAAgA==</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>SD0AAABA</data>
				<false/>
				<key>MatchOS</key>
				<string>10.14.x,10.15.x</string>
				<key>Name</key>
				<key>Replace</key>
				<data>SD0AAACA</data>
			</dict>
13 hours ago, MaLd0n said:
<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<false/>
				<key>MatchOS</key>
				<key>Name</key>
				<key>Replace</key>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<false/>
				<key>MatchOS</key>
				<key>Name</key>
				<key>Replace</key>
			</dict>
Will this patch will go into opencore?
Hola, buenas tardes te envío el send me.zip, solo tengo un problema no puedo conseguir aceleración gráfica con nvidia gt 640, y es mi primer ryzentosh con open core y algunas cosas exceden mi capacidad de configuración. gracias .- Por cierto excelente trabajo.
Send me2 2.zip
i think ur gpu loose support in new system
Ok muchas gracias, y cual placa de video seria la recomendable para poder usar dentro de las económicas lei algo sobre la gt710 2SL como la mas barata que funciona bien en catalina/mojave no se si con aceleración de hardware, AMD no tengo idea hace tiempo no las utilizo. gracias
rx 560
Can I request to have my DSDT be patched fully? Thank you for this comprehensive guide, I appreciate this. More power. Attached herewith is my Sendme File as well as the extracted IOreg file because I had an error on saving the ioreg from runme.app
https://1drv.ms/u/s!AortbKCVZXjwjnPaljId0NI0MlUe?e=XAPXK9
https://1drv.ms/u/s!AortbKCVZXjwjnTWucW3NNUOoMO_?e=PoY3yO
Sorry I can't attached file here directly as it reached the max file size for upload.
Ajoneh
use it, reboot and extract new with correct renames
config.plist.zip
My trackpad has stopped working after I use the config, plist. Btw here's the new extracted sendme files.
https://1drv.ms/u/s!AortbKCVZXjwjnbByycF4NlS2jOa?e=Xy8pSz
https://1drv.ms/u/s!AortbKCVZXjwjnVYPqqsHa8hYrhy?e=QZ38tY
Also sometimes I had kernel panic randomly. See attached pic.
https://1drv.ms/u/s!AortbKCVZXjwjneQUSFw2LSYDSr6?e=ubwFBp
Thank you for your hardwork!
Edited by tomqsher
Ajoneh
remove ssdts
about KP, is a video problem. use a correct video patch
