Hello sir!
Awesome guide! The best, most simple and functional I've found. Thanks.
I followed the steps and normal boot on the pre-installed system with clover. Everything seems to be working fine.
The only problem is to boot in the Catalina installation media. Kernel panic ... photo attached in DUMP.zip.
Could you give me a Full SSDT DSDTpatch?DUMP.zip
3 minutes ago, TarsXP said:
Hello sir!
Hi
extract one full dump
I boot normally, but I have no USB port. Completely disabled and without power.
u need create one injector with Hackintool.app
Got it! Tks
I now have working USBs.
Boot occurs normal in pre installation done with clover
The problem continues to load the USB for a fresh installation ... I keep getting this error with KP ... I'm using the same EFI for both
BIOS is properly adjusted;
DSDT in the ACPI folder and commented on config.plist;
config.plist according to dortania and this tread; (maybe missing an ACPI Patch?)
What am I missing? Thank you so much for your help
KP_PHOTO.jpg.zip
On 7/24/2020 at 12:09 PM, TarsXP said:
Got it! Tks
solved
just removed kexts related to the wifi card ... leaving only the essential ones in the folder ... boot -> installed OS -> re-paste kexts and taraaa ... Tks
Edited by TarsXP
7 hours ago, TarsXP said:
solved
Finally got big sur beta 2 working, can you check my sendme file? I upgraded from Catalina and changed from clover bootloader to opencore and its running well. My macOS system sounds appear to be working, but my audio on things like Apple Music and Youtube are not working. I'm also noticing some glitching on video from the graphics like I can briefly see the top menu in hackintool, but once the app loads completely the top menu bar where you can select pcie and other tabs, they are blank. I can upload a screenshot if that doesn't make sense. Anyhow, thanks again for the awesome work! Here is my sendme file. Please help with audio and video...
http://s000.tinyupload.com/?file_id=08310942654144099063
Well, I just realized my smbios changed. I should probably start with correcting that. I’ll bet that helps quite a bit. I’ll still take any suggestions anyone can think of. Thanks.
Edited by rocky_mtn
clarification
New build ASRock Z390 Phantom Gaming 9 i9-9900K MSI RX580 8GB Big Sur 11.0.1 32GB DDR4
First build ASRock Z270 Gaming K6 i7-7700K MSI RX580 8GB Mojave 10.14.6 32GB DDR4
Hi MaLd0n
Trying to play videos on App TV but it doesn't work. The application closes when the video starts.
I did a search and it seems to be something related to VDADecoder.
I used VDADecoderChecker and returned a failure.
Is there anything I can do to solve this?
Last login: Sun Jul 26 11:57:19 on console
/Users/tars/Downloads/VDADecoderChecker ; exit;
tars@iMac-de-Luiz ~ % /Users/tars/Downloads/VDADecoderChecker ; exit;
VDADecoderCreate failed. err: -12473
An error was returned by the decoder layer. This may happen for example because of bitstream/data errors during a decode operation. This error may also be returned from VDADecoderCreate when hardware decoder resources are available on the system but currently in use by another process.
[Processo concluído]
Edited by TarsXP
Any ideas why when I upgraded from Catalina to Big Sur I lost my audio EXCEPT on system sounds? My video is acting strange too. It looks good but theres a flicker if you mouse over a youtube video timeline or if I open hackintool the graphics look fine when I first open it, but then they go to crap and the buttons up top disappear?? The audio is bothering me most though. Please help me troubleshoot these two issues? Again, my system sounds are working, but playing audio from youtube or apple music is totally silent. I did also change from clover to opencore, am I missing a couple drivers that are needed for audio and video?
I think I'm going to just wipe and do a clean install. Everything worked fine on my test hard drive yesterday on a clean install. The problems started when I upgraded Catalina and switched the bootloader. I have to have audio ?
Edited by rocky_mtn
Audio fixed with fresh install, now to figure out why video is acting weird. Might need to update config.plist with the intel onboard video patch.
1 hour ago, TarsXP said:
Hi MaLd0n
what hardware?
use internal graphics or imacpro1,1 smbios
4 minutes ago, MaLd0n said:
what hardware?
I sent SendMe.files to you a few posts ago.
If I enable internal graphics the system will not boot.
I was looking at DSDT.dsl ... this needs GFX0 -> IGPU patch? Mine is GFX0.
Catalina 10.15.6 / DSDT patched by MaLd0n
Gigabyte Aorus B360M / Intel i5-8500 / SAPPHIRE RX 580 4GB /  32GB BallistiX 2666MHz
I have an AMD RX580, not sure why I would do that...maybe I'm not understanding you. I'm building my EFI folder right now after the initial boot and installing the kext for my 10Gb fiber adapter. After a reboot I should know more. This system has always ran using the RX580 and smbios 19,1 and worked flawless in Catalina.
Problems solved! Just rebooted and everything is working as it should. The problem with hackintool was it needed updated to 3.4.4. EVERYTHING is working! Thanks million!!
use iMacPro1,1 smbios instead
enjoy
