have a 5-series, no-uefi board with a Clarkdale i3-540 and AMD HD7750 dGPU, iGPU is disabled in BIOS.  I've just install Catalina with OC 0.7.0.  For some reasons, the hack can not reboot.  It seems to power down with no signal to monitor but the pc's light stays on forever.  Shut-Down works fine.  Could you help me with full DSDT patch please!
Also, this board's native NVRAM doesn't work.  I followed this guide to emulate NVRAM but it doesn't seem to work so iMessage & FaceTime return errors when sign in.  Do you have any solution for this NVRAM?
Thank you very much!
P.S. I removed the kext folder and replace with screen capture of files because the zip file is too big to attach here.
Send me Jeff-PC.tranghang.zip
enable rebase regions in acpi tab
Hi @Mald0n, I have hackintosh Big Sur 11.4 on PC with specs
  • Motherboard : Asus Rog Strix H470i Gaming
  • CPU: Intel Core i3 10100
  • GPU: Intel UHD Graphics 630
  • RAM: 16GB (Corsair)
  • WiFi/Bluetooh : BCM943224
I'm having a problem with the bluetooth part not working, but the wifi is working fine.
Can you help me make a DSDT patch and also make bluetooth workable?
I attached the Runme file via Google Drive, because the file is too big.
Thank you in advance.
With your patched DSDT, reboot still didn't work.  rebase_regions did not help iMessage either.
Reboot and Shutdown worked now with FadtEnableReset enabled
Thank you!
16 hours ago, Agus Suratno said:
But when I run videoproc, the HVEC section is not active.
Then if I boot into Windows, the audio is not detected as in the following image.
https://www.olarila.com/topic/13019-guide-dual-boot-with-opencore-with-full-acpi-and-real-vanilla-solution/
On 7/26/2021 at 8:01 AM, riski kur said:
is my dsdt, please help me to patch @MaLd0n
full dump
Hi sir @MaLd0n , thanks in advance for providing the tools I needed to fix my issues but it seems like I can't get it done yet, and I hope you can help me out fixing this.
I have issue on sleep - wake on my Asus with any triggers whether its from apple menu - sleep or lid close.
Especially for the long sleep. When I put my laptop on sleep and in the short time, let's say 10 min after the sleep indicator turned on, mostly I can wake my laptop up, but every single time I put my laptop to sleep and leave it overnight, it always comes up with black screen and nothing in the screen, even though the power indicator has turned on as soon as I open the lid / press any keyboard button to wake the laptop, and also sometimes there's an error when I turned on the laptop with the "EFI Wake Failure" things on the message, but mostly there's no error message there.
Would you mind to help me to fix this issue?
I attached my Send Me file on link download here :
https://www3.zippyshare.com/v/h7wNYIEJ/file.html
And also here is my laptop specification :
ASUS VivoBook 14 A442U
* Intel Core i5-8250U
* iGPU : Intel UHD 620
* dGPU : Nvidia GeForce 930MX
* RAM : 4GB DDR4 SDRAM/2133Mhz + 8GB DDR4 SDRAM
* Storage : 240 SSD SATA
* Ethernet : RTL8111
* Audio : Realtek ALC256
* Touchpad : I2C
* Screen Size/Resolution : 14"/1366x768
I hope you can help me fix this.
Thank you so much.
3 hours ago, Mohammad Ar-razaak said:
Hi sir @MaLd0n
first run olarila repair
I've run the Olarila Repair, and restart my laptop, but i think i've got another issue, sir
I've triggered my laptop to sleeping mode with lid close, when the led sleep indicator turned on and i open the lid, my laptop shuts down by itself.
What else can i do?
On 7/30/2021 at 8:40 PM, MaLd0n said:
full dump
this full dump, sorry late post. please help me @MaLd0n
Dump_RunMe.zip
full dump
this is my specs laptop
MSI B10MW
Processor : Intel Core i3 10110U
- IGPU : Intel UHD Graphics 10Th Gen
- RAM : 8GB DDR4 (2667Mhz)
- Storage : 1x NVME Kingston 256 GB
- Wifi : Intel AC 9560 and Bluetooth
- Audio : Realtek ALC235
- Ethernet : None
- Keyboard Backlight : Yes (PS2)
- Touchpad : CUST0001 I2C Interface
- Boot Mode : UEFI GPT
- Screen Size : 13.9"
- Display Resolution : 1920 x 1080
link : https://www.msi.com/Business-Productivity/Modern-14-B10X-Bluestone-r/Specification
MSI B10MW
- Ethernet : None
Please help me, and patch my dsdt @MaLd0n
On 6/21/2020 at 2:13 AM, MaLd0n said:
a- If you need a full solution with one full DSDT patched, extract one SendMe with OpenCore running with this app and post here or in DSDT Patch Requests topic, check video first for extract with ioreg
can I do that when booted with Clover bootloader? or must OpenCore? as I know OC guide not recommended include DSDT.aml in ACPI folder?
the idea there is: "stay with ur hack in basic mode". here we don't work with this shit ;)
clover or opencore support override acpi tables, fix regions, etc
  • Confused 1
