telepati Posted June 3, 2021 Posted June 3, 2021 (edited) @MaLd0n I made a new USB installer with your OC premade EFI but when I choose the USB Installer I am getting "Prohibited Sign" at start. This is the verbose screen before the prohibited sign. Edited June 3, 2021 by telepati
Administrators MaLd0n Posted June 3, 2021 Author Administrators Posted June 3, 2021 8 hours ago, telepati said: if u used a 11.4 u need remap ur usb for now use usb 2 and start remap https://www.olarila.com/topic/14220-video-guide-usb-port-mapping-guide-2021-bigsur-113-with-no-xhci-port-limit/ 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Henrique François Posted June 9, 2021 Posted June 9, 2021 My 6700 XT is still not supported on Mac OS and I tried the fake id, but it didn't work. Do I have any possibility of leaving the card in the computer for use with Windows and doing a Mac OS installation bypassing the graphics card and using the integrated graphics? I've already tried to change the boot-args line with the -wegnoegpu command but I wasn't successful. CPU i7-9700/Intel UHD 630 config.rar
Administrators MaLd0n Posted June 10, 2021 Author Administrators Posted June 10, 2021 4 hours ago, Henrique François said: My 6700 XT is still not supported on Mac OS no support -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
SiliconDiode Posted June 12, 2021 Posted June 12, 2021 (edited) Hi @MaLd0n!! i have this PC: i7 7700K Gigabyte GA-Z270x-Gaming 7 32gb of RAM Asrock Phantom Gaming X RX Vega 56 Can i gave you my EFI Folder and help me to have a good vanilla install?? (ACPI, USB ports, etc) Thank you! https://send.tresorit.com/a#7q731K-WTx9JAbALlhE7zw Edited June 12, 2021 by SiliconDiode
Administrators MaLd0n Posted June 13, 2021 Author Administrators Posted June 13, 2021 20 hours ago, SiliconDiode said: Hi @MaLd0n!! i have this PC DSDT.aml.zip remove ssdts, use only dsdt check useful links https://www.olarila.com/topic/6129-useful-links/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
SiliconDiode Posted June 13, 2021 Posted June 13, 2021 4 hours ago, MaLd0n said: DSDT.aml.zip 34.55 kB · 0 downloads remove ssdts, use only dsdt check useful links https://www.olarila.com/topic/6129-useful-links/ Thank you!!
Join Madam Posted June 22, 2021 Posted June 22, 2021 (edited) Hi MaLd0n Plz patch my dsdt Send me MacBook-Pro.zip Edited June 23, 2021 by Join Madam
Administrators MaLd0n Posted June 23, 2021 Author Administrators Posted June 23, 2021 On 6/22/2021 at 3:08 AM, Join Madam said: Hi MaLd0n DSDT.aml.zip 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Join Madam Posted June 23, 2021 Posted June 23, 2021 (edited) After copying DSDT.aml to the APCI folder and restarting the computer. After the computer is turned on, I press the F12 button to increase the screen brightness, it works fine, but when I press the F11 button, my computer turns off the black screen and then I press the power button twice and the computer turns on. My computer works properly again and displays the screen to enter the password. How to fix button F11. Thanks. Edited June 23, 2021 by Join Madam
tr4c3r2k6 Posted June 26, 2021 Posted June 26, 2021 hi @MaLd0n , i have a hack running with opencore 0.7.0 everything seems to run fine, but i want to use the full dsdt way not ssdt, can you help me? im deleting applealc.kext becuause the final file is bigger than the file size i can send here in the forum Send me iMac-de-Aaron 2.zip
Administrators MaLd0n Posted June 26, 2021 Author Administrators Posted June 26, 2021 11 hours ago, tr4c3r2k6 said: hi @MaLd0n DSDT.aml.zip select rebase regions in acpi tab -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
SiliconDiode Posted June 26, 2021 Posted June 26, 2021 On 6/13/2021 at 7:16 PM, MaLd0n said: DSDT.aml.zip 34.55 kB · 1 download remove ssdts, use only dsdt check useful links https://www.olarila.com/topic/6129-useful-links/ Hi @MaLd0n!! the system works perfect!, but i have something that doesn't work. I Installed from scratch Big Sur 11.4 (Using OpenCore 0.7.0) and i bought an audio interface (Motu M2) that have USB-C Connection. When i connect the audio interface using the USB-C to USB-A Cable it works perfect, but (since it's my first USB-C device) i wanted to try to connect (using a USB-C to USB-C cable) directly to the USB-C port of the motherboard but it's doesn't appear in any place (system report, Sound devices, etc). The device is USB powered and it powers fine, but i think the problem it's on the recognition from macOS of the USB-C port. What can i do?? Thank you again.
Administrators MaLd0n Posted June 27, 2021 Author Administrators Posted June 27, 2021 17 hours ago, SiliconDiode said: Hi @MaLd0n!! the system works perfect!, but i have something that doesn't work. https://www.olarila.com/topic/14220-video-guide-usb-port-mapping-guide-2021-bigsur-113-with-no-xhci-port-limit/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
SiliconDiode Posted June 27, 2021 Posted June 27, 2021 9 hours ago, MaLd0n said: https://www.olarila.com/topic/14220-video-guide-usb-port-mapping-guide-2021-bigsur-113-with-no-xhci-port-limit/ Thank you for your answer but (i did the tutorial step by step) but still cant connect the audio interface. It's power up, but it's not recogniced by macOS and the USB-C (or "3.1") doesn't appear in system's report or hackintool. This is How looks the USBs in System Report: Hackintool after i mapped all the USB 3: i don't know what more i can do or test.
Duduzera Posted June 28, 2021 Posted June 28, 2021 Hello! How are u bro? I generated Run Me files with My EFI and Your recommended EFI. With me EFI:https://drive.google.com/file/d/1QYwZWobKf9mhgHs56cU9x-vL5GAG-qFi/view With Recommended EFI for Serie 100 and 200 (KabyLake): https://drive.google.com/file/d/17P8u5zsAZTUkPFazX6VpBOCUg8_T6RcO/view You can help-me to patch sending me the DSDT file? I have another issue, my hack not working with two monitors. With one screen in exactly moment for input the password after apple loading, my screen power off and i need to remove the HDMI cable and input again for the screen image working again. Can you help me with this issue too? Im tried to patch video with hackintool following your topic, without success. My second screen not working, i have a one DP port, one HDMI port, One VGA port and one burned DVI port in my motherboard. ?
lastdays Posted June 28, 2021 Posted June 28, 2021 (edited) Hi @MaLd0n, thanks for making a perfect hackintosh tutorial. And I have installed it on my device and it seems that everything is running smoothly. But I want to work with 1 DSDT file. Can you check the runme file of my device and solve the problem?. A very big thank you from me. And this is the runme file I uploaded to Google Drive, because the file is too big. Edited June 28, 2021 by lastdays
Administrators MaLd0n Posted June 28, 2021 Author Administrators Posted June 28, 2021 10 hours ago, Duduzera said: With Recommended EFI for Serie 100 and 200 (KabyLake) DSDT.aml.zip change smbios to iMac18,1 2 hours ago, lastdays said: Hi @MaLd0n DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
lastdays Posted June 28, 2021 Posted June 28, 2021 10 minutes ago, MaLd0n said: change smbios to iMac18,1 DSDT.aml.zip 55.44 kB · 1 download okay @MaLd0n I will replace SMBIOS and put the DSDT file and try it, thank you very much. 53 minutes ago, MaLd0n said: change smbios to iMac18,1 DSDT.aml.zip 55.44 kB · 1 download Hi @MaLd0n after I tested everything went smoothly. But some USB ports don't work, that's why?
Duduzera Posted June 28, 2021 Posted June 28, 2021 1 hour ago, MaLd0n said: change smbios to iMac18,1 My SMBIOS is already iMac18,1... ?
