inject device ec
8 hours ago, MaLd0n said:
inject device ec
Buenas noches,
Perdona MaLd0n, no se que tengo que hacer con "inject  device ec"
Saludos y gracias.
--UPDATE FIRST POST--
Config Checker Updated
I have an HP EliteDesk G1 with i7-4790 with only iGPU.  I've just install Catalina with OC 0.7.0.  For some reasons, the hack can not shutdown or reboot.  It seems to shutdown with no signal to monitor but the pc's light is still on.  Reboot never works since it can not shutdown.  Could you help me with full DSDT patch please!
Thank you very much!
Send me Jeffs-iMac.zip
On 5/12/2021 at 4:48 PM, Matheus Lopes said:
Hi MaLd0n
HI does it work when I'm currently using Clover with Catalina, and I want to use OpenCore to update to Big Sur?
Asking cause I followed the guide (and also the video) but currently stuck at boot (didn't reach apple logo yet).
Will try again once have this confirmed.
Thank you for the detailed guide.
post one photo in error screen
This is where I'm at.
1. Is the USB with Clover Bootloader.
4. is what I want to get in.
6 does restart but same screen.
4 will just give me a flash then same screen (no restart).
I was at Catalina with Clover. Then I tried to follow the guide.
What should I do? If I can get in the OS somehow I probably can use the old EFI folder (of Clover), but I couldn't get in.
Here's the screenshot where I stuck, the OC_EFI that I created following this guide, and the SendMe capture with the Clover EFI.
https://drive.google.com/drive/folders/1tDE0AUyVyIbl7oV0-pnGaoefv8LkfiSh?usp=sharing
Edited by Le Hai Ninh
12 hours ago, Henrique François said:
Any solution for AMD 6700 XT?
I THINK FOR NOW ONLY 68XX AND 69XX
u can try a fake id
u can try a fake id
How can i do fake id? I dont have no Mac OS installed, just 11.4 Olarila vanilla image ready.
My config plist
hardware:
i7 9700 (no k version), Gigabyte Z390M Gaming and Rx 6700 xt
config.plist.rar
Edited by Henrique François
link fail
Hello ,
My trackpad  ELAN1300, is working again , all are OK now , after fresh instal Big Sur last version 11.4 and OC 0.7.0.
Sometimes after fresh install all come back to normal.
23 hours ago, noloveinmylife said:
I've updated again. Please help me.
