Duduzera Posted April 3, 2021 Posted April 3, 2021 (edited) Olá! você pode me ajudar com um patch DSDT? Asus z97m-plus / br Intel Core i5 4460 24 GB RAM SSD m2 512 GB Kingspec HD 1TB GTX 750 Ti 2 GB Não em uso por não saber como corrigir?Obrigado ADM! ❤️ Download Link: https://drive.google.com/file/d/1msSJbgiMhupq7ePhfAeqVXjmskeuusYC/view?usp=sharing Edited April 3, 2021 by Duduzera
Administrators MaLd0n Posted April 3, 2021 Author Administrators Posted April 3, 2021 this file is just ioreg not full sendme -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Duduzera Posted April 3, 2021 Posted April 3, 2021 54 minutes ago, MaLd0n said: this file is just ioreg not full sendme Sorry, download link updated. https://drive.google.com/file/d/1msSJbgiMhupq7ePhfAeqVXjmskeuusYC/view?usp=sharing
Administrators MaLd0n Posted April 4, 2021 Author Administrators Posted April 4, 2021 15 hours ago, Duduzera said: Sorry, download link updated. use this config, reboot and extract new sendme config.plist.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Duduzera Posted April 5, 2021 Posted April 5, 2021 On 4/4/2021 at 8:48 AM, MaLd0n said: use this config, reboot and extract new sendme config.plist.zip 5.22 kB · 1 download Thanks for you help View here.https://drive.google.com/file/d/1JuXxPUcJxplGgUW_3a6qo1_WAWMrgofw/view?usp=sharing
titeresincabeza Posted April 6, 2021 Posted April 6, 2021 (edited) Edit. Edited April 6, 2021 by titeresincabeza Resolved
Administrators MaLd0n Posted April 6, 2021 Author Administrators Posted April 6, 2021 13 hours ago, Duduzera said: Thanks for you help DSDT.aml.zip 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
iRezaMac Posted April 6, 2021 Posted April 6, 2021 (edited) hello.. thanks for the good tutorial and very understanding as i followed.. Clover runs slow on me so i want to try with OC as they say its future and runs smoother. able to boot after 3 weeks of trying with ur guide.. but whats weird is: after it loads the necessary files to boot and go to the next step my Monitor goes to Sleep Mode .. note: when i install with clover and update to the latest big sur screen goes pink and i cant find the IGPU using IOReg to fix cause i use HDMI not VGA Specs: Asus Prime B365 Plus | i7 9700 | 32GB 2666 | 2Tb HDD | Intel UHD 630 | HDMI | EFI Folder https://www.mediafire.com/file/fq6uhqz0t9flm0n/EFI.zip/file Edited April 6, 2021 by iRezaMac
Administrators MaLd0n Posted April 7, 2021 Author Administrators Posted April 7, 2021 9 hours ago, iRezaMac said: hello use smbios iMac19,1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
saracen22 Posted April 7, 2021 Posted April 7, 2021 hi Mald0n can you help to properly setting my laptop ? spec: Gigabyte Sabre 17 NVIDIA® GeForce® GTX 1050 Ti GDDR5 4GB/GTX 1050 GDDR5 4GB 7th Gen Intel® Core™ i7-7700HQ Processor 17.3" Full HD 1920x1080 WVA Anti-Glare Display DDR4 2400MHz – Up to 32GB 16.7 Million Colors RGB Backlit Keyboard (optional) Optimized 2.0mm Key Travel Distance Flexikey® - Software Macro Function Blazing-fast M.2 PCIe Gen3 X4 SSD: Reach 2000MB/s (optional) Dual Storage System: up to 3TB USB 3.1 Type-C: 10Gbps / 5V 3A 1+3 Displays Dual Array Microphones Sound Blaster™ Cinema https://drive.google.com/file/d/1iX85Y1tWIsF6r26FjBkzpbTxjJWO497V/view?usp=sharing
iRezaMac Posted April 7, 2021 Posted April 7, 2021 2 hours ago, MaLd0n said: use smbios iMac19,1 thats what i am using.. i tried to change some keys as serials and etc but still the same
Duduzera Posted April 10, 2021 Posted April 10, 2021 (edited) On 4/6/2021 at 7:40 AM, MaLd0n said: DSDT.aml.zip 22.88 kB · 1 download Tks ❤️ Edited April 13, 2021 by Duduzera
inter Posted April 27, 2021 Posted April 27, 2021 Hi Mald0n can you help to properly setting my OC 0.6.8 ? By OC 0.6.4 all are OK on my laptop. I update the OC to new version OC 0.6.8 but after update the trackpad is not working . The config.list (OC 0.6.8 ) was updated by PlistEdit Pro and are the settings same config.plist OC 0.6.8. I come back to OC 0.6.4 , and the trackpad is working ,for moment I have any ideea were is the mistake on the OC 0.6.8. I used same Kext from OC 0.6.4 , I updated the kext at last version , but the result is negativ .
anto barreca Posted April 27, 2021 Posted April 27, 2021 1 hour ago, inter said: Hi Mald0n can you help to properly setting my OC 0.6.8 ? By OC 0.6.4 all are OK on my laptop. I update the OC to new version OC 0.6.8 but after update the trackpad is not working . The config.list (OC 0.6.8 ) was updated by PlistEdit Pro and are the settings same config.plist OC 0.6.8. I come back to OC 0.6.4 , and the trackpad is working ,for moment I have any ideea were is the mistake on the OC 0.6.8. I used same Kext from OC 0.6.4 , I updated the kext at last version , but the result is negativ . Moving on to 0.6.8 you have to take the Sample.plist that you find in the release in the Docs folder and edit it as your old 0.6.4 plist. If you have done so, you can check for errors with ocvalidate inside the Utilities folder of the release https://drive.google.com/file/d/18EfX6ryjVlrrAr5Mq_Zsac7sQ1ELxzRH/view?usp=sharing
inter Posted April 27, 2021 Posted April 27, 2021 (edited) Thank you for your replay . I did exactly as in your description, see attached. Screenshot 2021-04-28 at 00.14.57.zip I will do it tomorrow ,new config.list (OC 0.6.8) Edited April 27, 2021 by inter
anto barreca Posted April 27, 2021 Posted April 27, 2021 1 hour ago, inter said: Thank you for your replay . I did exactly as in your description, see attached. Screenshot 2021-04-28 at 00.14.57.zip 1.73 MB · 1 download I will do it tomorrow ,new config.list (OC 0.6.8) Well it looks ok, also tried to do an nvram reset? If that can help you too https://dortania.github.io/OpenCore-Install-Guide/troubleshooting/extended/post-issues.html#synaptics-ps2-based-trackpad-doesn-t-work
inter Posted April 28, 2021 Posted April 28, 2021 I reset the nvram ,but didn't solve the problem. My trackpad is ELAN1300, the question is why is running by OC 0.6.4 and not running by 0.6.8 ? I wait for new update of BS 11.3 and OC 0.6.9.
TBR Posted May 4, 2021 Posted May 4, 2021 (edited) Buenos días, Le envío Send me-pro de Tomas. A veces no arranca y pone que son problemas de Nvme. Saludos y gracias. Send me pro-de-tomas.home.zip Edited May 4, 2021 by TBR
Administrators MaLd0n Posted May 4, 2021 Author Administrators Posted May 4, 2021 2 hours ago, TBR said: A veces no arranca y pone que son problemas de Nvme. use -v and post one photo in error screen -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
TBR Posted May 4, 2021 Posted May 4, 2021 1 hour ago, MaLd0n said: use -v and post one photo in error screen Tomas.rar
