Releases
1 minute ago, João Vitor Viegas Rêgo said:
Could you please patch a DSDT for my mobo, please?
i patched ur dsdt some time ago. use same
enjoy
Hi, I have a problem with my laptop, I use opencore, dual boot Big Sur + Windows 10, on Windows 10 the keyboard does not work, I recompiled the dsdt, the keyboard on Windows does not work.
use bootkey to boot into windows if u have problems
One question: what patches should I put on the dsdt to replace SSDT-PLUG, SSDT-EC, SSDT-PNL, SSDT-XOSI?
My laptop is a Celvo P650.
Edited by Panell
same names
ssdt is a basic things. incomplete solution
When I compile the DSDT I put these patches:
"Fix _WAK Arg0 v2"
"HPET Fix"
"SMBUS Fix"
"IRQ Fix"
"RTC Fix"
"OS Check Fix (Windows 8)"
"Fix Mutex with non-zero SyncLevel" **(forgot if this needs to be patched, won't hurt)**
"Add IMEI"
"Fix _WAK IAOE"
"Rename GFx0 to IGPU"
"renaming B0D3 to HDAU"
"7-series/8-series USB"
"Haswell LPC"
"Rename _DSM methods to XDSM"
All correct?
renames like gfx0 to igpu, b0d3 to hdau u dont need, whatevergreen, applealc, etc rename these devices on-the-fly
Maldon, thanks for the detailed guide.
I am unable to get the sleep working. The system goes to sleep and immediately wakes up.
Once I hit the sleep command, the system goes to sleeps for a second and wakes up again.
Tried to read various forums but no luck, as per the open core guide the reason are many, I do not want to try each of them, nor am I so technical. Any assistance will be helpful.
System details:
Core i7-4790K 4.0GHz LGA 1150 - Haswell
GA-B85M-D3H LGA 1150 mATX Intel Motherboard
Radeon RX 560 4 GB
32 GB GSKill RAM (used it on 1600MHz. with profile 1, and with 1333MHz. as default, no difference)
Intel SSD
Software
Using Catalina 10.5.7
Open Core - 0.6.6 release.
Complete EFI folder attached.
SMBIOS 19,1 iMac
Have removed all the USB except the mouse and the inbuilt Bluetooth as part of the WiFi Broadcom. Still no luck.
BIOS disabled - LAN wake up.
% pmset -g
System-wide power settings:
Currently in use:
standby              1
Sleep On Power Button 1
womp                 1
hibernatefile        /var/vm/sleepimage
proximitywake        1
powernap             1
networkoversleep     0
disksleep            10
standbydelayhigh     86400
sleep                15 (sleep prevented by installer, sharingd, coreaudiod)
hibernatemode        3
ttyskeepawake        1
displaysleep         15
highstandbythreshold 50
standbydelaylow      86400
Not sure if this will add any value - read about this command at https://dortania.github.io/OpenCore-Install-Guide/troubleshooting/extended/post-issues.html#sleep-crashing-on-amd
 ~ % log show --last 1d | grep "Wake reason"
2021-02-26 11:49:02.274801-0800 0x210b0    Default     0x0                  99     0    powerd: [powerd:sleepWake] Wake reason: "<private>"  identity: "<private>"
2021-02-26 11:49:22.960516-0800 0x74       Default     0x0                  0      0    kernel: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN HDEF
2021-02-26 11:49:22.960517-0800 0x74       Default     0x0                  0      0    kernel: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN HDEF
EFI.zip
kill all _prw and use power button to wake
Can you guide how to and where to edit (which file in particular needs to be edited), in the attached EFI folder.
Checked the config.plist using OpenCore sanity checker https://opencore.slowgeek.com/?file=haswell066bZRcaB&rs=haswell066
results attached.
Dropped smbios from iMac19,1 to iMac14,2 as it is the closest match to my CPU. The CPU used in iMac14,2 is i7 4771 & my CPU is i7-4790K.
Removed few kext as per the result form the sanity checker.
Attached revised version of the EFI.
Maldon, I think this is what will fix the issue.
https://dortania.github.io/OpenCore-Post-Install/usb/misc/instant-wake.html
But the issue is I do not know what is required, do I need to copy the .aml files as well as patch the config.plist. I have no idea, what to do as well as how to do. Any guidance is appreciated.
EFI.zip OpenCore config.plist Sanity Checker.zip
Edited by vamoose
Additional Information shared
11 hours ago, Sandeep S S Mishra said:
why my internet is so slow in olarila hackintosh catalina
Olarila is just forum with vanilla images, dsdt, etc
nothing about ur internet connection
stop redtube and try again ?
  • Haha 3
12 hours ago, Panell said:
My Aorus Master motherboard DSDT has 0 errors. Which patches should be inserted on the dsdt?
u just need fix errors for compile. we need patches. check Olarila tutorials
