use 2.2 version
Hello! Thank you very much for this maldon. Can you help me out by patch my DSDT. :D
https://drive.google.com/file/d/11Tk3W6abEFrnmTFCO-d2_xVdRwwV2qbH/view?usp=sharing
Ajoneh
remove acpi renames, osi to xosi, select rebase regions in acpi tab, reboot and extract new sendme
Here is the new sendme.
https://drive.google.com/file/d/1G2DK7pbIv6G6CsgGyvVKTgLJ9C9Wo5yb/view?usp=sharing
Ajoneh
8 hours ago, madvillain_ said:
Hi, thank for the tuto but, how to do all this without a Mac ? Is it possible to easely do the same on Windows ?
use olarila images and replace efi folder if need
Hello can you help me tune dsdt pls, My laptop is Gigabyte P15Fv5 skylake HD530 + Nvidia GTX950M, here is my zip send me
https://drive.google.com/file/d/1At0mYH9oXU2QSJ4tOkfpwEG1F3Acq96Z/view?usp=sharing
I have a DW1560 wifi + bluetooth card
DW1560 Bluetooth 4.0 LE    USB\VID_0A5C&PID_216F
BCM4352 802.11ac Wireless Network Adapter PCI\VEN_14E4&DEV_43B1
it works fine with Mojave + clover, then i upgrade to bigsur 11.2 + opencore 0.6.6, wifi works fine but bluetooth is not working, there is no information in hardware / bluetooth. Hackintool says there is no internal USB for Bluetooth
My keyboard elan, I tried many ways to active Fn+f8 and Fn+F9 brightness keys but it doesn't work. Can you guide me how to do it pls.
Thanks.
Hi MaLd0n,
My Big Sur installation is working fine from the .raw file and I've used the resources folder to amend the boot them which is fine and boots well although I would like to hide unwanted boot screen icons like NVRAM, Preboot, Recovery, etc. and add my Windows OS to the boot screen but my Windows OS doesn't have an EFI that I can mount with OpenCore Configurator and can't add the bootmgfw.efi as I cannot find the PciRoot address for the windows drive and boot file.
Is there any way to add my Windows OS to the OpenCore boot menu without the Windows OS being installed as GPT UEFI?
Attached is my current boot screen.
Thanks.04135857.png.zip
use both system uefi
2 hours ago, mwr_allen said:
Hi MaLd0n,
https://github.com/sarkrui/Hackintosh-Z390-Aorus-Pro-9700K-RX580/wiki/How-to-add-a-boot-entry-in-OpenCore
20 hours ago, anto barreca said:
Hi, Thanks for the info, I've now reinstalled windows 10 to another drive by using Rufus to create a UEFI usb boot drive and once installed it just popped up on my OpenCore boot screen so that's all good.
The next thing I'm trying to get running is the Apple boot chime and I have followed some instructions which has ended up showing this message prior to boot.Archive.zip
I've added images of the error message and also my ProperTree view of my config.plist.
Thanks.
Thanks.
boot chime.zip
2 hours ago, anto barreca said:
ok, I've now raised minimum volume to 60 then tested not working and then changed audio out to 1 and tested not working.
each time has the same error message prior to showing boot menu and also, since I first made changes to the config.plist to give boot chime I lost the Olarila gui and now has just the text only gui boot menu up in the top left of the screen.
Could it be caused by incorrect PciRoot address to the audio hardware at all as I'm not sure if its correct device address.
Thank you for all the help.
And the audio file is present in resources folder.
Can anyone help with a working kext for Gigabyte WB1733D-I 1733Mbps PCI Express WiFi Adapter for use on Big Sur 11.2 using OpenCore?
The same card is working for bluetooth but not the wifi.
Thanks.
what chipset this card use?
do you mean my board?
Board is MSI B360M Pro-Vdh with intel i5 9400f processor.
These are the details of the wifi card.
Gigabyte GC-WB1733D-I Wireless-AC PCI-E Network Interface Card + Bluetooth v5.0-1733Mbps
2x2 802.11ac Dual Band WIFI + BLUETOOTH 5 card GC-WB1733D-I is an exclusive PCIe expansion card that offers support for the latest 2x2 802.11ac 160MHz Dual Band WIFI and BLUETOOTH 5 connectivity.
  • Intel Wireless-AC 9260 included
  • IEEE 802.11ac standards compliant
  • Antenna supports WLAN 2Tx2R transmission
  • High speed wireless connection up to 1733 Mbps
  • BLUETOOTH 5
