@MaLd0n, poderia me dar uma ajuda com esse tópico?
Já tentei de tudo, todos os fóruns, Reddit, Discord... Vocês do Olarila são minha última esperança! ?
Muito obrigado!
P.S tem o tópico em inglês, também:
Edited by robertzero
Adicionando informação extra
Your hair's so dark, just like the night...
Hi, i need help.
I’m use vanilla os Bigsur 20B50. And use EFI premade for coffelake.
after boot verbose done > select language, when I select English for language, the screen come grey with pointer.
i try to select other language, and i choose deutsch language and come to recovery install. And then i try to click install bigsur and that no happens when I click that. I see the logs installer.
logs installers showing that:
https://ibb.co/Pzwz2gD
Anyone can solve that?
my spek pc
i5-8400
Msi B360m
rx 470 sapphire
11 minutes ago, faridh nugraha said:
RX 470
XFX CARD?
no idea what happens
disable csm and try
disable csm and try
I just edit your config on prev-lang:kbd and make it blank.
i can run into macos recovery but when i click install that no happen. And i saw the log and show something like that
https://ibb.co/Pt3tZRv
and yes i use balena etcher for make bootable usb. Vanilla image is BigSur 20B50 from this site
on balena etcher failed check sum like that
https://ibb.co/bPPFQ4X
https://tinyurl.com/y2nu3c2t
I use your dsdt fixed. My case is 6 usb port ( 2 port 2.0, 4 port dual 2.0-3.0) I check in Hackintool is same picture.
The situation is that the USB 3.0 port sometimes fails to connect. I need to restart my computer before I can connect.
https://www.mediafire.com/file/xvty5zuy9lo83pz/Send_me_trungdqs-iMac.zip/file
Edited by Quang Trung
https://www.olarila.com/topic/9390-video-guide-usb-port-mapping-with-hackintool/
Hi, I managed to install Big Sur on my laptop with Opencore after months of panics.
Only problem is I cannot make WIFI to work, it is DW1560 Broadcom WIFI card and whatever I try it doesn't work. with latest Airportfixup.kext I get kernel panic.
Can you please help?
msi GE63 RAIDER laptop with i7-8750h
Hack Pro: Asus Strix Z590i, i9-11900K, RX 6900 XT, 1TB Samsung QVO SSD, RAM 16GB Corsair RGB @3200Mhz (Big Sur) OC
Hackbook Pro: (MSI GE63 Raider RGB) i7-8750H, Intel UHD 630, GTX1070 8GB(disabled), 16GB RAM @2666Mhz (Big Sur) OC
use dev id 43a0 with brcmfix with no plugins
