41 minutes ago, MaLd0n said:
use it with macbookpro14,1 smbios
Hello @MaLd0n
Thank you very much for your quick reply.
Exactly the same. I have graphics acceleration when I use the USB-C with an adapter to hdmi to an external monitor. I was already using that SMBIOS definition. I give you a sample of an ioreg and my config.plist. I am using the DSDT.aml that you patched for me.
Thanks a lot. Greetings
files.7z
3 minutes ago, robitibillo said:
Hello
check edid patch
1 minute ago, MaLd0n said:
comprobar parche edid
Hello @MaLd0n
What patch? Please could you specify a little more and give me some more details?
I'm more of a newbie to hackintosh.
I use OpenCore 0.6.4 on a KabyLake-U i7-7500U with HD620.
Thank you very much for the great help MaLd0n, greetings
Check hackintool
Hi could you help me with my install? I have installed Big Sur but cannot get to the setup page. I have attached the screenshot of where it got stuck also a copy of the sanity checker page. The system is a dell precision M6800, with intel core i7 4040mx, Nvidia k5100m (which by the way you helped make work in Catalina DSDT) Would appreciate if you could help make it work again. Thanks
Archive.zip
2 hours ago, ugooh said:
Hi
use watchdog=0 and check if work
Thanks it worked. I have been able to setup the system. I am uploading send file and a link to my Catalina clover EFI folder. I would love to have the Nvidia (K5100M) card as default as before in Catalina install. Thanks for your great work to the hackintosh community.
EFI send_me
Edited by ugooh
On 12/4/2020 at 5:16 PM, MaLd0n said:
Check hackintool
Hello @MaLd0n
It has also been impossible for me to create a patch with hackintool including the EDID in addition to other things. I think I'm going to give up because I've already tried everything I could find with no luck, I only get video through an external monitor, and it's a laptop, I need to get video through the internal lvds monitor but the screen always stays black .
Thank you very much for your help, I am sending you my donation for your DSDT.aml patch for sleep mode and other tips. I'm going back to Clover 5104 with Catalina 10.15.7 where I have full functionality, too bad graphics acceleration for HD 620 with OpenCore doesn't work in Big Sur 11.0.1,
regards
On 12/2/2020 at 9:10 PM, MaLd0n said:
no idea bro
Bro i am using your patched DSDT but when i remove power cord from laptop system will freeze
On 12/9/2020 at 4:40 AM, adatalss1 said:
How do I know which ones should be deleted in dsdt?
70% from our table is a trash. check real apple tables
On 12/9/2020 at 9:46 AM, Quang Trung said:
please help me patch dsdt
  • Like 2
my laptop is dell vostro 3568, i7-7500U, hd620, wifi intel 3165, alc 256.
im using hot-patch. It is well but i wanna make a. custom dsdt for my dell, but i dont know how to delete unused device, and i dont have real apple tables to compare.
so could u show me how to do it?
@MaLd0n
C-ori.zip
Edited by adatalss1
Post one Full Dump with Ioreg.
https://www.olarila.com/topic/10301-olarila-runme-dumper/
https://olarila.com/files/Utils/RunMe.app.zip
17 hours ago, adatalss1 said:
oh, could u help me make a custom dsdt without unsed device and scope
use itConfig.plist.zip, reboot and extract sendme
