Hi,
Inserted _dsm with only slot property to GFX0 and PEGP but nothing happens. "Built In" to GFX0 and "Slot-1" to PEGP.
So, UHD 630 doesn´t show in PCI list, and RX 580 only shown in Graphics/Displays with slot "AirPort"
Do I have to add more properties to _dsm ?
more testing:
Deleting "Name (_SUN, One)" in both devices
fixed _dsm with proper end (Buffer (One) .... ) and mixed results:
-with _dsm in GFX0 (igpu) "Built In" -> ACPI Error in boot
-only with _dsm in PEGP "Slot-1" or "Built In", can boot. Not listed in PCI devices, and no slot info in Graphics/Displays and Ioreg.
I don´t know, i´m using an imac19,2 smbios with headless igpu so maybe this is the normal slot naming for this config (both gpus as "AirPort").
If I have the chance to see this data in friend´s real iMac i will compare info.
Anyway, not important, so don´t waste your time here.
thanks for all!!
Edited by xrimarx
new testing
Hi MaLd0N,
Please if you look at my files what is wrong that macOS Catalina with OpenCore refuses to load.
I made OpenCore as instructed on the Olaril page.
Thanks a lot in advance.
Start PC
EFI.zip My_PC.txt.zip
Intel Core i5 8600T Coffee Lake, 2.30GHz, Mainboard Q370, Memory 16GB, Graphics Intel 630, SSD 260GB
On 7/1/2020 at 8:06 AM, xrimarx said:
Hi,
u can use other slot via Name (_SUN, xx) or inject via _dsm
18 hours ago, Volneix said:
Boa noite
tente com o do clover primeiro
5 hours ago, luky53 said:
Hi MaLd0N,
what happens? post one photo
1 hour ago, dewazildjian said:
Would you tell me how to installed opencore to my CPU?
yes
43 minutes ago, luky53 said:
Attached is a screenshot of where the startup stops.
inject device ec
@MaLd0n Na verdade eu sempre usei o Clover. Com a DSDT com patch que você fez pra mim estava funcionando perfeitamente. Resolvi formatar pra tentar fazer Fusion Drive (Como te falei pelo Grupo do Facebook), pois uso o Photoshop e o disco de 120G sempre fica cheio rápido. De qualquer forma o Fusion Drive não funcionou no Catalina, então instalei novamente e (Essa parte é interessante) resolvi o problema de disco cheio, movendo os dados de usuário para um outro disco maior, através das configurações de usuário. Ficou muito bom. Porém, voltou com alguns problemas. Daí resolvi tentar o OpenCore.
A DSDT do Clover funciona no OpenCore? Eu coloquei a SSDT Olarila e algumas coisas são reconhecidas. Tentei com outras que consegui na documentação do OC e mais algumas funcionam, mas não completamente. Por isso anexei o SendMe, na dúvida.
Grato pela ajuda.
https://drive.google.com/file/d/1a-9QJq05pX7ZZAxm-B5szv0o7k_3OvpW/view?usp=sharing
Cara que privilégio ter alguém tão dedicado e tão humilde como vc @MaLd0n!!!
Se não fosse seu esforço e conhecimento, teria desistido do Hack...
Deus abençoe sempre, e cada vez mais!!!
  • Thanks 1
Gigabyte Aorus Z790 Elite AX / Raptor Lake 13th Intel® Core™  13900K / AMD AORUS RX 6900 XT  2 rev. / Lenovo E470 i5-7200-U Kaby Lake iGPU intel HD620 64 GB Ram / ASUS Prime B365M-K Desktop intel i3-Coffe Lake / ASUS Sapphire Nitro+ AMD RX 580 4GB / Gigabyte B360 i5-Coffe Lake / RX 64 Vega OC Gigabyte / Gigabyte B660 Raptor Lake 13th Intel® Core™ i7-13700K  / Nvidia GeForce GTX 3060 Gainward 12GB /  Gigabyte Z170 XP SLi  Intel® Core™ i7  iGPU /  Mac mini M4 Pro 12/16  24 GB Ram  512 GB Nvme /   MacBook Air 2020 10th Ice Lake Intel® Quad-Core™ i7-1060NG7 T2  Iris Plus Graphics  /  Clover Hacky Color 5161  / Opencore 1.0.4 /  God Bless you!
Valeu, meu camarada!
Abraços!
37 minutes ago, dewazildjian said:
how?
in ur case u need test
and remember...is a legacy
in this list clarkdale does not exist
http://prntscr.com/taux0y
I have done a test using your EFI and the results cannot be booted
I did restore, in step 6 it doesn't boot
Edited by dewazildjian
SS double link
9 hours ago, MaLd0n said:
inject device ec
I assumed you would solve my problem and I wanted to make a donation, but unfortunately there is no solution to my problem on your part.
Greetings
yes. need some test ;) is a good adventure
u need extract ur tables for check embedded controller if ssdt dont solve
4 minutes ago, dewazildjian said:
ok, i will try all options
Enjoy!
Primeiro quero agradecer ao forum pelas varias duvidas que já tirei em longas pesquisas que fiz em varios tópicos aqui.
Dito isso quero compartilhar um problema que venho tentando solucionar ha varias semanas e não consigo que é fazer meu hackintosh reconhecer minha placa wifi e ethernet (estou usando um dongle pra quebrar o galho).
Meu notebook é um HP elitebook 840 G3 (i5 6300u).
Todo o resto funciona perfeitamente menos o wifi/BT e eu ja tentei de tudo e não sei mais o que fazer.
Uso o clover pois é com ele que uso desde meu primeiro hack em 2015.
Minha placa wifi é a Broadcom bcm943224pciebt2 com adaptador ngff m.2. (https://pt.aliexpress.com/item/32849220309.html?spm=a2g0s.9042311.0.0.ec41b90afpljEJ)
Queria saber o que preciso fazer pra que ela seja reconhecida. Devo abandonar o Clover e ir pro OpenCore?
Desde ja agradeço a ajuda.
Tentei upar direto os arquivos mas não consegui por causa do tamanho entao upei pro OneDrive. Segue o libnk do sendMe e clover folder.
https://1drv.ms/u/s!Av2rBHB-VPVviY5s_koz_73JE4_odQ?e=SFmnif
vc tem de ver se essa placa tem suporte. não são todas broadcom que tem
o bootloader não importa, se o suporte existir é só usar a solução
