12 minutes ago, MaLd0n said:
Hi @MaLd0n
I have tried the DSDT.aml that you have passed me and removed my old DSDT.aml and all SSDT.aml. I continue with the same kext.
Works:
- Sleep mode.
It does not work:
- Still not detecting the internal screen.
- If I touch the touch screen, it suffers an immediate reboot.
- There is no audio over HDMI.
Thank you very much for your effort, greetings, I hope you can continue to help me.
all things is not about acpi
check useful links
https://www.olarila.com/topic/6129-useful-links/
check useful links
Hi @MaLd0n
Here's my sendme file.
Would you mind to fix the sleep bug with patching my DSDT?
Thank you in advance.
RunMe file https://www110.zippyshare.com/v/JuJHJrnZ/file.html
(idk why is the file from RunMe bigger than the upload limit here, so i uploaded it to downloadable link above)
Edited by Mohammad Ar-razaak
Update SendMe File
2 hours ago, Mohammad Ar-razaak said:
Hi
with this folder is not good
1 hour ago, viniciusnuri said:
Fala @MaLd0n
use rebase regions
28 minutes ago, Mohammad Ar-razaak said:
So what can i do @MaLd0n ? Should i run the app again?
remove all acpi renames and select rebase regions, reboot and extract new sendme
27 minutes ago, MaLd0n said:
use rebase regions
I just copied my EFI From SSD, to Flashdisk, and edit the config.plist just like what you said.
But then, i can't boot it. It said that something like this again IMG_20201130_124500.zip.
I can boot normally when i boot from the SSD, but it always ended up just like the image when i boot into flashdisks
What can i do then?
Hello @MaLd0n,
Please Patch DSDT for me.
https://drive.google.com/file/d/1oTgAeV-mUc_YzQZvl6fnmgnhHDgv-JAW/view?usp=sharing
 i have problem in graphic card intel HD 630 the color screen is orange and blue
https://drive.google.com/file/d/1rSBrzmqICL6yYe3G_qJqKpPKadugNYPs/view?usp=sharing
https://drive.google.com/file/d/1zR26zo_1BQa2vpWi_JkOCE7ONmWwJ98G/view?usp=sharing
i have cpu i7 7700K and matherboard is asus h110m-k
https://www.olarila.com/topic/9860-guide-forcing-rgb-mode-to-fix-problems-on-external-monitors-in-macos/
10 minutes ago, Montaser Al-joubeh said:
mount: / failed with 66
check google
8 hours ago, h4ktosh said:
hi @MaLd0n do you have any idea about this?
no idea bro
Hello MaLd0n,
I have Big Sur installed with OpenCore, everything seems to be working good except the graphics.
I have 2 graphics card on my PC:
PCI Slot1: GTX 970
PCI Slot2: GTX 650
I also have 2 monitors:
-HP OMEN 25 connected to GTX 650 by DVI.
-Samsung C32JG5x connected to both 650 (by HDMI) & 970 (by DP).
When I boot the hackintosh, it starts on PCI Slot1 DP, verbose process finish and stays on verbose.
Both DVI & HDMI on 650 are working fine, but OS X detects 3 displays, not 2.
The problem is I need to mirror displays so I can see the main one, the DVI and HDMI displays connected to 650 are not the principal display.
Do you know what can I do to have just 650 detected so I have only 2 displays not 3? Maybe disable PCI Slot1?
I attach some screenshots for further information and RunMe.zip.
Thanks in advance for your help!!
Send me Vicentes-iMac.zip
Edited by pepe21
check useful links
Hello @MaLd0n
I have followed your guide Mobile Intel HD Graphics / Clover or Opencore for the hd 620 in 7th generation cpu, my processor is a KabyLake-U the i7-7500U but I still do not detect the internal LVDS monitor by BigSur.
Do you have any idea why? I've gone through hundreds of websites and tried dozens of settings but I only get video through the USB-C port to an HDMI adapter for an external monitor, so there I get graphics acceleration.
I pass you my current graphics configuration.
I hope you can help please, thank you very much, regards
config.txt.zip
4 hours ago, robitibillo said:
Hello
use it with macbookpro14,1 smbios
Quote
<key>PciRoot(0)/Pci(0x02,0)</key>
<dict>
<data>AADAhw==</data>
<key>device-id</key>
<data>FlkAAA==</data>
<key>framebuffer-con1-alldata</key>
<data>AQUJAAAIAACHAQAA</data>
<data>AQAAAA==</data>
<key>framebuffer-con2-alldata</key>
<string>&lt;02040a00 00080000 87010000&gt;</string>
<key>framebuffer-fbmem</key>
<data>AACQAA==</data>
<data>AAAwAQ==</data>
</dict>
