no idea
no idea what happens
Hello Maldon
I made other tests with the latest DSDT I have kernel panic, see photo
advice
ur touchpad is load. check ioreg
hi maldon
Please check my Send Me. without kexts, with kexts file is 18mb and used kexts are listed in a file named: Used Kexts.jpg
plz patch my DSDT. trackpad not working at all, nvidia not disable d, boot speed is very slow. can you take a look on my config plz?
Send me Ehsans-MacBook-Pro 2.zip
Edited by h4ktosh
3 hours ago, h4ktosh said:
hi maldon
config.plist.zip
23 minutes ago, bahblo said:
Hello Maldon,
config.plist.zip
On 11/28/2020 at 10:07 AM, bahblo said:
Thx MaLd0n..
8 hours ago, t3s8r8 said:
Hi
remove voodooinput plugin from voodoops2
Hello @MaLd0n
Please I need your help. I have generated a zip with RunMe.app. I am using OpenCore 0.6.4. I have managed to install macOS Big Sur 11.0.1 on a Yoga 910 laptop. I have this installed on an external SSD. On the internal SSD I have a dual boot installed with macOS Catalina 10.15.7 with Clover working perfectly.
With OpenCore in BigSur I did not get the following things to work:
- The most important thing is that it does not detect the internal screen, right now I am using a USB-C to HDMI adapter through which it only outputs a video signal, but I can't get audio.
- The touch screen does not work either, as soon as I touch the screen, it causes an immediate reboot.
- Lastly, I can't get the sleep mode to work either.
I look forward to your help and I will make a well-deserved donation.
Thank you and the entire team for your enormous work and the spectacular guides you do.
Cheers
Send me MBP-de-Vicente.zip
Hello @MaLd0n
Would you help me please?
I've been installing Catalina on my own, and it success booting. Everything is working (the Trackpad, Brightness, Sound, etc). Yet, i still found a problem.
My laptop can't wake up from sleep mode, even i triggered it with keyboard button or opened my laptop lid. It only can be forced shutdown.
I've read some articles that the main culprit were USB Mapping, which i've fixed it but still won't wake my laptop from sleep.
And also, i've found your article that it can be fixed by patching DSDT
Maybe you can fix my laptop's sleep bug with patching my DSDT?
My laptop is Asus X442UR
Thank you so much.
RunMe File https://www17.zippyshare.com/v/VkvqfP4f/file.html
PS : I've run your RunMe.app and i think there's an error on the process but it finished, maybe you can check it out too.  The error was saving the IOReg file, your automation searchin for folder /tmp/send_me and it didn't showed up and your app written "3x ioreg dumping  failed....". I can't upload it here because of the file size, so i uploaded it to other downloadable link
Edited by Mohammad Ar-razaak
Clarify
4 hours ago, robitibillo said:
Hello @MaLd0n
use it Config.plist.zip reboot and extract new sendme
2 hours ago, Mohammad Ar-razaak said:
Hello @MaLd0n
use it config.plist.zip reboot and extract new sendme
I'm sorry, so how can i use your config.plist properly?
I've replaced my copied EFI to Flashdisk, and replace the config.plist with yours, but it stuck and cannot boot.
Should i oc clean snapshot your config.plist to my copied EFI folder?
I attached the stuck image when booting.
IMG_20201130_124500.zip
Attaching error
