9 hours ago, Alessandro Silva said:
just an ipad where I can access the installer folders. any ideas or solutions? ??‍♂️
all kexts and bootloader is updated?
1 hora atrás, MaLd0n disse:
todos os kexts e bootloader são específicos?
Tell me, is it possible to replace files on the flash drive? Because it is the only thing I can do now with an ipad, I cannot make another image because this was the only PC I have at the moment ??‍♂️
yes. u can mount efi partition in windows and replace
On 11/16/2020 at 10:27 AM, odinista said:
Preciso de ajuda, não faço a menor idéia do que preciso fazer, segui o passo a passo OC.
Por favor me avise se vc conseguir resolver pq eu estou exatamente com o mesmo problema.
vc tem de configurar os quirks
veja no tutorial
Please check my Send Me. without kexts, with kexts file is 3.3mb and im not allowed more than 2.93mb.. kexts I use are listed in kernel list in plist.
Send me 5700XTs-iPro.fritz.box.zip
Haswell Hackintosh: GA Z970N WIFI Gaming 5, i7 4790K, Radeon HD 7970, 16GB RAM
Coffee Lake Hackintosh: GA Z370N Wifi, i7 8700K, Radeon XFX RX Vega 64, 32GB RAM
9 hours ago, iFabio said:
Hello Maldon
config.plist.zip
  • Thanks 1
5 hours ago, iFabio said:
Hello Maldon
yes
19 minutes ago, iFabio said:
I pass you the result of the usb, I use it to boot
use it and done
16 minutes ago, iFabio said:
Ioreg
don't need
is done
OpenCore in the EFI of the hard drive using your config.plist and DSDT crashes on the apple
using my config.plist without DSDT works
advice
advice
post one photo in error screen
