e ai @MaLd0n beleza ? cara segui o tuto direitinho mas na hora do boot dá isso aqui na imagem. o meu é um notebook com i3 de 4 geração 4005u
segue o link da minha pasta EFI: https://drive.google.com/file/d/1LrxlXagTlnmU0AH5k_9tmPEwqyLLruFn/view?usp=sharing
to tentando instalar o Big Sur, mas ele não da boot nem no Catalina, pelo Clover consigo o boot
edit: o notebook é um Lenovo b40-70
Edited by Lehiol
laptop model added
3 hours ago, Lehiol said:
e ai @MaLd0n
parece ser algum quirks
tem de fazer uns testes
Tem algum guia ou Tuto pra eles ? Ou se puder me passar eu faço todos aqui sinto muito incomodar realmente tô dando meu melhor pesquisando
verifica no sanity checker
48 minutes ago, נערת ליווי בצפון said:
very good site i like this site
enjoy
vc tem de testar, remover alguns quirks e ver qual está causando o problema
hello @MaLd0n
can u help me and patch my DSDT ?
I tried to install Big Sur beta 10 with vanilla image (premade EFI for skylake+) but I can't install it ( I am new in your community and I really want to get opencore working on my laptop )
https://drive.google.com/file/d/1pj9J8TXDjSpN85eOFZBMRCdgFdlVpM5Y/view?usp=sharing
here is my laptop specification :
Lenovo Ideapad 300 - 15ISK
Intel core i5 6th gen skylake ( intel hd 520 + radeon r5 m330(it's disabled on bios)
8gb ram
240 gb ssd
I am running Catalina 10.15.6 and I am using a premade EFI of someone else that I found on tonymacx86 , I know it's not a perfect hack so please help me )
thank you so much
12 minutes ago, guilty_baby said:
first u need a good folder
try this. if need configure quirks
https://filebin.net/dwq6gkrhlblo3zt2/EFI.zip?t=0i4gckgs
33 minutes ago, guilty_baby said:
hey thx for the reply , I replaced your EFI on my USB and I am getting stuck at this point?
rename ur embedded controller to EC
ok I changed ECDV to EC but I stuck on another thing ? ( sorry I don't have enough hackintosh knowledge )
IOAPIC: version 0x20 vectors 64:111
console relocated to 0x7f00000000
1 hour ago, Lehiol said:
consegui dar boot aqui pelo clover, sou mais familiarizado com ele por enquanto e está rodando bem, obrigado
impossível com essa pasta. muito acpi renames
no idea
51 minutes ago, Lehiol said:
Bom mexendo nas quirks descobri a que estava causando o problema
  • Thanks 1
1 minute ago, Lehiol said:
depois que coloquei na EFI e no OC, reiniciei o sistema o touchpad nem o teclado funcionaram
if dont work idk
1 minute ago, MaLd0n said:
if dont work idk
com o SSDT olarila que usava antes funcionou, coloquei o SSDT ola de novo e voltou a funcionar
Olá @MaLd0n, pode me dar uma força? Não estou conseguindo dar boot na instalação do Big Sur Beta 10, apenas congela, sem demostrar nenhum erro. Aparentemente ele congela na hora de subir a interface gráfica.
O que eu já fiz e tentei:
  • Atualizei o OC para versão mais recente 0.6.2
  • Usei uma DSDT que você já fez um patch para mim antes. Não fez diferença alguma, apenas sumiu os erros de bateria (pois já estava com o patch no DSDT).
  • Passei a config no Sanity Check e está tudo (aqui)
  • Fiz passo a passo as instruções do Dortania para minha config (laptop kaby lake)
  • Atualizei a Whatever e Lilu para versões mais recentes
  • Removi todos as kexts, patches e SSDTs que não são necessárias para subir. Sem sucesso.
  • Copiei os patches que eu usava no Clover no Catalina, sem sucesso.
  • Pesquisei incansavelmente, mas como não demostra nenhuma mensagem de erro, não encontrei a solução.
Foto de onde congela no boot: https://imgur.com/a/Wak1Luh
Pasta OC que estou usando: https://drive.google.com/file/d/1-wMkgHnzr6WSmZKpC6wWRXe3-ZJ87YRJ/view?usp=sharing
Atualmente estou usando o Ubuntu, quero deixar em dual boot no mesmo SSD (já usava assim no Catalina).
Minha config:
Quote
cpu:
                       Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz, 1516 MHz
                       Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz, 2794 MHz
                       Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz, 3295 MHz
                       Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz, 1916 MHz
                       Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz, 2066 MHz
                       Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz, 2554 MHz
                       Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz, 2080 MHz
                       Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz, 3033 MHz
keyboard:
  /dev/input/event3    AT Translated Set 2 keyboard
mouse:
  /dev/input/mice      Microdia USB Keyboard
  /dev/input/mice      ELAN0B00:00 04F3:3050 Mouse
  /dev/input/mice      ELAN0B00:00 04F3:3050 Touchpad
monitor:
                       LM156LF3L01 LCD Monitor
graphics card:
                       nVidia GP107M [GeForce GTX 1050 Mobile]
                       Intel HD Graphics 630
sound:
                       Intel CM238 HD Audio Controller
storage:
                       Intel HM170/QM170 Chipset SATA Controller [AHCI Mode]
                       Samsung Electronics NVMe SSD Controller SM981/PM981/PM983
network:
  wlp3s0               Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  enp4s0               Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
network interface:
  lo                   Loopback network interface
  enp4s0               Ethernet network interface
  wlp3s0               Ethernet network interface
disk:
  /dev/nvme0n1         Samsung Electronics NVMe SSD Controller SM981/PM981/PM983
  /dev/sdb             SanDisk Cruzer Blade
  /dev/sda             ST2000LM007-1R81
partition:
  /dev/nvme0n1p1       Partition
  /dev/nvme0n1p2       Partition
  /dev/nvme0n1p3       Partition
  /dev/sdb1            Partition
  /dev/sdb2            Partition
  /dev/sda1            Partition
usb controller:
                       Intel 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller
bios:
                       BIOS
bridge:
                       Intel HM175 Chipset LPC/eSPI Controller
                       Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16)
                       Intel Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers
                       Intel 100 Series/C230 Series Chipset Family PCI Express Root Port #13
                       Intel 100 Series/C230 Series Chipset Family PCI Express Root Port #9
                       Intel 100 Series/C230 Series Chipset Family PCI Express Root Port #14
hub:
                       Linux Foundation 2.0 root hub
                       Linux Foundation 3.0 root hub
memory:
                       Main Memory
bluetooth:
                       Qualcomm Atheros Bluetooth Device
unknown:
                       FPU
                       DMA controller
                       PIC
                       Keyboard controller
                       Intel 100 Series/C230 Series Chipset Family Power Management Controller
                       Intel 100 Series/C230 Series Chipset Family MEI Controller #1
                       Intel 100 Series/C230 Series Chipset Family Serial IO I2C Controller #0
                       Intel 100 Series/C230 Series Chipset Family Thermal Subsystem
                       Intel 100 Series/C230 Series Chipset Family SMBus
                       Silicon Motion Web Camera
  /dev/input/event9    Microdia USB Keyboard
                       Realtek RTS5129 Card Reader Controller
